Question about Compaq Evo N600c Notebook
I tried to use a c.d cleaner and now it does recognise and disc
My c.d drive doesnt work and my wireless doesnt work either
  • christian Abong May 11, 2010
    about your cd drive...a problem is the reader or lens ,....and about your wireless..did you check in your device manager if your wireless in installed...? if installed try to re-install the driver it..
My lg dvd drive does not recognise dvd disc when inserted
try to download the firmware for your DVD drive from the manufacturer website and reflash the firmware
or you can try deleting upper filter and lower filter for that download MS utility from this link
http://support.microsoft.com/gp/cd_dvd_drive_problems
Oct 17, 2010 | LG Computers & Internet
It would not play the game disc
First i would try a laser lens cleaner. If that doesnt work try several discs and movie's to ensure that it is not isolated to a few discs. If the cleaning doesnt help then either the motor on the disc drive has gone bad or the laser itself has gone bad. Either way you will then need to replace the disc drive. Thanks, Midwest-tek
Aug 31, 2010 | Sony Playstation 3 (PS3) Console
It doesnt rcognise the recovery disc 1 year ago my son formatted the hard drive soi installed windows xp from a new disc, and it worked fine untill now when th pc ceased to work properly. so i put the xp...
probably ur cd/dvd rom drive is down or the cd frm where u r installing is corrupted..copy it from elsewhere n try..or try downloading....
..contact ur system admin/vendor....
Oct 27, 2009 | Computers & Internet
Computer does not seem to recognise disc. I keep
Hello !
Either your disk or disk drive is problematic.
Try your disk in another PC to test. If the disk works, your CD drive is faulty. Try another disk in your computer's drive. If the disk doesn't work, you have confirmed that the drive is faulty.
If the drive is a problem, I would suggest to purchase a disk head cleaner, first. Then, if the drive is still a problem, it would need replacing.
Hope this helps.
Sep 10, 2009 | Lexmark Office Equipment & Supplies
Cdrom doesnt recognise blank dvd. error message
Its only cd writer burner and can only that it can read dvd disc also. That is why its called combo. But burning blank dvd it can't. But if you want buy some dvdburner too.
Apr 19, 2009 | Memorex (32023244) CD-RW/DVD-ROM Combo...
Need to install liteon dvd rewriter
try cleaning the drive using lens cleaner, also if it is sata drive install proper drivers for that it works, gudday !!
Jan 20, 2009 | Ahead Software Nero 6.3 Reloaded (60096)...
DEll 2400 - cd-dvd drive stopped working
try to clean the lens using lens cleaner...
Dec 02, 2008 | Dell Dimension 2400 PC Desktop
DOESNT RECOGNISE DISC
There are several causes for this problem.
1) Faulty DVD drive. Most drives have a dual laser, one for CD, and one for DVD. Check the player with both CD, and DVD. If it reads one and not the other, then it is most certainly a faulty laser. The laser assembly or whole mechanism will need changing.
2) Dirty or dusty lens. If the unit is kept in a dust environment, dust and dirt can be drawn into the machine by the fan. Try using a DVD lens cleaner. If this doesn't work try a CD lens cleaner. (Dual laser - see 1))
3) Condensation. Condensation can build up on the laser lens if the unit is kept in a humid environment. Also, this can be caused by a cold environment. In this case, condensation forms as the unit warms up. In either case, leave the unit in a warm dry environment for an hour.
Jan 12, 2008 | Philips LX3600D System
CD-ROM won't read discs
there is no problem with the system. only you need to clean the lens using CD/DVD cleaner.
Jan 05, 2008 | Gateway (5500778) Internal 32x CD-ROM...
Compaq Evo N600c Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
