Question about Philips Ladyshave HP6305 Electric Shaver
My ladyshave HP 6305 electric shaver does not shave properly any more, the blade is not working properly and shave is painful. From where could I replace the old blade.
SOURCE: Carrera Shaver NC accu
Contact the Carrerra Customer Service Hotline at: 1-888-476-1785
Posted on Mar 08, 2008
bajaboyextra
  • 3 Answers
SOURCE: norelco 8883 xl problem
Amazon has the Shaver Head Holder for $14.69 and the Retaining Plate for $6.99. You will see the spring clip on the new head holder that pushes into the shaver body; you'll want to push the old one down gently with a thin flat tool to pull the head off.
195b4d0.jpg33d13dc.jpg http://www.amazon.com/Norelco-4222-036-05840-Retaining-Plate/dp/B001500YBO/ref=pd_bxgy_hpc_img_a
Posted on Dec 22, 2008
SOURCE: my philips beauty ladyshave model hp6304 -spare blade
MY DEAR OLD LADY (OLD) MESH ON HEAD BREAKING APART - CAUSING BAD & PAINFUL SHAVE - THIS OLD LADY CAN'T AFFORD NEW ONE AND CAN'T BE TRUSTED WITH REGULAR RAZOR LOL - HOPE I CAN GET A REPLACEMENT HEAD THANX FOR YOUR HELP MARIE NANAMARIE7@CABLEONE.NET
Posted on Jan 16, 2009
SOURCE: Need screen blade
 i want extra blades
Posted on Apr 09, 2009
Blondie Girl
  • 25 Answers
SOURCE: can i use shaving cream with a norelco electric
According to the Phillips website, it is NOT a waterproof shaver, therefore it is not advisable to use any liquids prior to or during shaving.
However, as a hairdresser and having experience with shaving men for many years, you can use the tried tested and true method of either shaving AFTER you get out of the shower so that your hairs on your face are softer from being in the moisture, or if you are not planning on having a shower, you can just use a hot face cloth on your face for a few minutes before you shave. This will soften the bristly hairs on your face and make it easier to shave.
I hope this helps. Please remember to rate my help. I would greatly appreciate it!
Posted on Apr 26, 2009
Need a replacement blade
got the Manuel? order 1?! or enter OSP ELECTRIC SHAVED ICE HAWAIIAN in the question bar in goggle or i.e. LOL.
Mar 18, 2014 | OSP Electric Hawaiian Shaved Ice Shaver...
Tip
How to use an electric shaver
If you are a using an electric shaver for the first time, I hope that this article will get you going. Proper techniques will ensure the best, closest shave possible. Maintaining the razor by properly cleaning and recharging it will also ensure that the razor works correctly and does not malfunction during use. Proper care and maintenance of the electric razor will also ensure that the razor will last for years to come. Consider this article as a shaving-best-practices template for your first electric shaver.<br /> <br /> Firstly, clean your face and dry it. Electric shavers do a better job when your face is clean. Turn the electric razor on and begin shaving against the direction of hair growth, moving the shaving head linearly and in circles. Circular motion Stretch the skin with your other hand to make the hair stand up straighter so the razor blades shave closer.<br /> <br /> After shaving, turn it off and rinse the cutting heads under warm water. You can also use jet clean system once a week to clean your shaver. Make sure that you charge it for the time specified in user manual. Overcharging may cause damage to the battery.
on Mar 03, 2011 | Health & Beauty
Trimmer of my Panasonic EX3833S is not working
panasonic es3833 replacement foil and blades
panasonic WES9979P combo set for electric shaver panasonic es3833 replacement heads.
panasonic WES9941P outer foil for electric shaver panasonic es3833 replacement parts.
panasonic es3833 replacement blades
panasonic WES9942P replacement blade for electric shaver part panasonic es3833 replacement parts.
Aug 25, 2013 | Panasonic ES3833 Electric Shaver
This is the first time I am shaving with an electric shaver, is there anything I need to know?
If your switching to electric shaver or it is the first time you shave you will need to give your face three weeks to adjust to electric shavers. Try not to fluctuate back and forth between blade shaving and electric shaving during the first three weeks.
Feb 06, 2013 | Health & Beauty
What is an electric shaver?
Not like shaving razors, electric shavers work by shearing the whiskers, the hair enters the perforated metal heads of the shaver and is cut by the moving blade inside.
The norelco shaver i have does not shave
If the shaver is running ok but does not shave well, the blades either need cleaned or replaced.
You will find replacements for 8175XL model at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq9-replacement-heads-p-252.html
Scroll down the page for tutorial video showing how to remove blades for cleaning or installation
Oct 07, 2011 | Philips Norelco 8175XL Electric Shaver
Scratching and slight pain
Possible issues: 1. Shaver not charged 2. Shaver not powerful enough 3. Shaver's blades dulled
Try using electric shaving gels/ointments like Lectric Shave or something like that.
Jun 07, 2011 | Health & Beauty
Is the Braun Activator8595 a good shaver for extra sensitive skin
The Braun foil shavers are well designed and I find they work well for sensitive skin if you prepare properly. Make sure you apply a hot towel to your face followed by a shaving conditioner. When applying the shaver, press lightly. Don't be afraid to go over the same areas several times to get most of the whiskers. Once you do this for about a week, your skin should begin to adapt to the sensation of electric shaving. You'll then be able to use the shaver more aggressively and get a thorough shave.
Apr 04, 2010 | Braun 360° Complete 8985 Electric Shaver
I have a Philips Ladyshave HP6306. It needs a new
Try Electric Shaver Service. You can go to their website and call them to see if they have your shaving head for your model shaver.
www.electricshaverstore.com
I tried looking it up your model number and the part number you provided, but it might be listed under another part, as many shaver heads are used in other models. So give them a call and see if they can help you find your part. 1-888-476-1785
Hope you find this Very Helpful and best regards!
Sep 16, 2009 | Health & Beauty
My philips beauty ladyshave model hp6304 -spare blade
Nov 21, 2008 | Health & Beauty
Philips Ladyshave HP6305 Electric Shaver Logo
43 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
