Question about Gaggia Coffe Deluxe Coffee Maker, Espresso Machine
Gaggia Deluxe - Excessive steam discharging into filter holder
When the steam switch is on we have an excessive amount of steam discharging through the filter holder. Machine has been thoroughly cleaned but the problem persists.
    Novelist:
  • 137 Answers
Your seal of non teturn valve of group, just above metal part where you put upper filter. open the valve and carefuly clean, check the seal and spring.
Posted on Mar 31, 2009
Excessive amount of steam remains in microwave after it cooks stuff
Exhaust fan not working or path, exhaust air is blocked, filter (if any) clogged.
May 22, 2016 | In Microwave Ovens
Causes of excessive fuel consumption
Hello, There are several causes for excessive fuel consumption . Dirty or clogged air filter, leaking gas hose or fuel lines, under inflated tires, wrong sized tires, excessive weight in the trunk, a heavy foot on the gas pedal are only a few.
Mar 17, 2015 | Cars & Trucks
I have a gaggia deluxe coffee machine which won't dispense coffee. the pump works with the steam nozzle and I've checked the guidance on the possibility of an air lock, and dispensed a lot of water...
it can be 3 problems, you can eliminate them 1 by 1 in this order:
  1. Calcium in the boiler > you unscrew the filter&filter holder(2 bolts) than you unscrew the screw in center (you see it after disassembling filter holder). If it is full with calcium, the pipe which goes vertically up for few centimeters you can drill it with 3 mm drill BUT AFTER YOU TAKE OF THE FINAL 4TH BOLT. You continue and release the short pipe and provide flow from boiler, test it and clean it than with decalcifications'(it will be more easy for you)
  2. We suppose case 1 isn't, and u have flow after unscrewing the 4TH bolt, than you must check the pressure valve (it returns the higher pressure with dispensing water back to container. Follow the short rubber pipe and you will find it. check the gasket and functioning of it
  3. Pump could be to week with pressure that she can't open the spring of valve above 4TH bolt, in this case you need to change pump.
Mar 02, 2011 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia Titanium. . coffee not hot even though
Remove the filter holder and brew some water into a small plastic cup and check temp, it could be the thermostat for the coffee temp is damaged.
Apr 29, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
When I'm making coffee in my Gaggia Classic, the brewing basket tries to unscrew (twist to the left). I have a feeling some part may have warped and need to be replaced. What would it be?
The only part up there is the group gasket, it will move the handle if there is an excessive amount of pressure, try adjusting the grind and or tamp and if that does not work then replace the gasket.
Apr 08, 2010 | Gaggia Classic Espresso Machine
Gaggia Coffee Delux Steam pressure probem
1: do you pres the switch for steam and wait until it is ready? 2: how long time machine needs to be ready for steaming?
solution 1 = if you don't press the steam switch on you will have very small amount of steam. solution 2 = if the machine gets ready only for few seconds to steam, than you must change your steaming thermostat attached in boiler(there are 3 of them: 1 security 2 coffee brewing 3 steam
i hope you fix it soon and enjoy in perfect espresso
Apr 04, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia Titanium Espresso machine problem: steam venting into inside compartment after pulling espresso shots.
Normal, depending on the amount, when the hot water goes through the coffee and the pressure builds up the excess has to go somewhere when it stops, usually the drain tray, so there is a little steam loss.
Mar 04, 2010 | Gaggia Titanium Espresso Machine
Gaggia Synchrony Compact Digital Problem
I think you have get air in the system, try to find a bellows pump or similary. Fill it with water, open the steam knob and take of the water tank, put the pump in the water inlet and press. When the water begins to flow, close the steam knob and put the water tank back.
Best regards
/Mirran
Nov 01, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia evolution- water doesnt flow through the brewer
Make sure your filter in the machine and in the filter holder is clean, the filter in filterholder there you will see a little light in the middle if you head it to light, else you have to replace the filter.
Feb 23, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia Coffe Deluxe Coffee Maker, Espresso Machine Logo
203 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
