Question about Mercury P4VM800M7 Motherboard
Mother board creates sound
Dear Madam,
Good Evening, I am facing with my mother board while I fit the RAM in the RAM slot a sound occured for that I am unable to start my PC. Please tell what should I do?
  • Mercury Master
  • 5,568 Answers
It sounds as if you inserted the RAM while the machine was turned on? You may have damaged the RAM, support chips, or perhaps the power supply if contact was made where it shouldn't have been made.
Because some voltage is present even when the machine is turned off, you should either turn off the power with a switch on the back of the system, or pull the AC plug from the wall if no switch is present, before doing any insertion or removal of RAM or add-on cards.
Posted on Mar 09, 2009
How to add RAM
Ram comes is strips and needs another slot on the mother board
Take it to a computer repair shop and if the mother board is suitable , the technicians will fit an extra strip
it already has 2 ram strips then you may have to upgrade the laptop
Feb 27, 2016 | Computers & Internet
Toshiba qosmio x775 ram slot not working
Call for Toshiba Customer Service Phone Number 1-800-204-4427 and get instant result by our Toshiba tech support team.
May 19, 2017 | Toshiba Qosmio G25-AV513 Notebook
Look i have bought a foxconn mother board from ebay and it says its ddr2 but i have ddr in it and the ddr2 wont fit is ther something im doing wrong will u send me a pic of this board so i can see what it...
i think you have placed ram in worng slot , check this pic to set ram in correct sport immortal4u.jpeg
this is ram slot which have two hoke at both end try to fit your ddr2 in this base, surely it will fit , actully all ddr , ddr1 , ddr2 wil fit in most of board but performance will be vary, so you board support ddr2 ram mean fit the name in this slot.
GOOD luck
Dec 31, 2010 | Computers & Internet
Wher do i plug in a 7in1 card reader on a gigabyte ga-ep45-ud3p mother board
If, that's the keyword, IF that M-board has an available USB port on the inside, you can plug it in there. But that's really only good if that unit will then fit into an external slot on the front face of the PC itself.
-a.
Nov 23, 2009 | Intel Motherboard
RAM SUPPORT FOR D 845 GVSR MOTHER BOARD OF 2004
Greetings
Memory support for your d845gvsr board is as follows:
Memory speed - 333MHZ, 266MHZ and 200MHz.
Memory type - DDR SDRAM
Max Memory - Capacity of up to 2 GB
Memory Slots - 2
Memory module size is 1GB (1024MB) for slot.
Thank you,
Let me know if you need anything else.
Ekse
Mar 02, 2009 | Intel Motherboard
Problem in the installation of a RAM
Your RAM slot may be having some problem...
Dec 09, 2008 | Computers & Internet
Pentium 4 comptability with SD Ram
If you know what mother board you have you could check what RAM it can use.
All RAM is installed in the same way, but different types of RAM are keyed differently. That basically means that one type of RAM (for example SD RAM) will simply not fit into another type of RAM slot (for example a DDR RAM slot).
To install ram on a PC
Please note - do NOT touch the connector side of the RAM, handle it only by holding the side or top edge
1. check that you have the right type of RAM. do this by lining up the RAM above the RAM slot and making sure that the RAM is the same length as the RAM slot AND ALSO that the RAM's key (the little hole or notch in the RAM) lines up with the key in the RAM slot. Note there might be more than one key
2. open both clips of the RAM slot by pushing them down and out from the center of the RAM slot
3. gently insert the RAM into the RAM slot
4. check again that the RAM and the RAM slot's key's line up, if they do, firmly press down on the RAM on both corners until both clips automatically click shut on the RAM
That's it! :-)
-Magnon
May 13, 2008 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Intel motherboard 845gvs
intel 845 gvsr motherboard have two most problem
vrm circuit fail IC ADP3168 {between the cpu and core volt connector}
f7338 mosfet ic fail {between the memory slot and ide connector}
Feb 26, 2008 | Intel Motherboard
Display
I have Intel Jetway 945 Mother Board, I checked the Processer and Ram, And SMPS it is working properly, but I am facing display problem.
Oct 29, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Mercury P4VM800M7 Motherboard Logo
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
