Question about iLO XM-MP3-CD Car Stereo
No sound from boat stereo speakers
I installed a new stereo in my boat. Good power to the stereo and everything seems to be working fine, but when I hook up the speakers, I get nothing at all. I have checked and rechecked the wiring and even changed speakers, but still nothing. All the settings on the stereo are correct for sound to be there, but still nothing. Any suggestions? Thanks in advance.
  • oldiegoldie Mar 17, 2009
    I just bought a repo Bayliner 185 and the stereo faceplate was missing. I bought a new face plate and installed it, unit powers up, shows FM signal, lights all work and it plays CD and ejects. All controls work but no sound. Disconnected speaker and plugged in new speaker and still no sound. Is this a common ground issue or is the internal amp fried??
KaeZoo
  • 156 Answers
SOURCE: No Sound - boat stereo
Assuming that the four speakers are connected to the amplifier, then the amp is the most likely problem component. Does the amplifier show a power light when the system is turned on? Note that there is probably another fuse in the amplifier power wire, near the battery.
Posted on Mar 16, 2007
zeusfaber
  • 247 Answers
SOURCE: Boat stereo/speakers
Wonder if the return line from both speakers was wired to a common earth, and you've lost that connection? If that happened, you'd end up with the two speakers in series instead of in parallel, and just playing the difference between left and right channels (so very much quieter). Check also the stereo doesn't have a separate fuse (possibly internal) for the power amp stage. A.
Posted on Mar 30, 2007
sgregg
  • 133 Answers
SOURCE: Is this considered clipping in marine boat stereo help!!!!
if your radio is puiing more power your ground might not be good enough, use the same spot but remove the ground and rough it up a little on the base with some sand paper or add a metal o ring to get a better ground.
Posted on Jul 30, 2007
  • 55 Answers
SOURCE: Stereo display works fine, but no sound to speakers.
The wires may have gotten wet and fried something in the sound output in the stereo.
Posted on Aug 30, 2008
  • 110 Answers
SOURCE: replacing a stereo into a 2005 Saturn Ion
not sure if your still looking for a solution or not but here you go. that orange and white wire is normally the wire that controls the dimmer within the stereo. when you dim the dash light the factory radio lights dim and that wire is suppose to make the new radio do that also. in my past i have found that only about 30 percent of the aftermarket radios actually do that when hooked up. give this a try and let me know. good luck
Posted on Feb 28, 2009
Buzzing sound in my car speaker after installing stereo with install kit
That is alternator noise install a 12 volt noise filter inline with the power to the deck.
Jun 28, 2017 | XO Vision XD103 FM and MP3 Stereo Receiver...
Model-m 255 clarion installed in a pontoon boat. RADIO WAS WORKING JUST FINE, THEN I INSTALLED A (NEW) BATTERY FOR MY BOAT, HOOKED EVERTHING BACK THE SAME WAY. NOW, I HAVE POWER BUT (NO) SOUND...
Disconnect all the speaker leads and then hook one speaker (a new, known to work speaker) up directly to the radio using a short (6"-12") piece of speaker wire. Does that speaker work then?
Jan 03, 2011 | Clarion M255 AM/FM Marine CD Player
Just got a used boat with a JVC KD S590 stereo and a JVC KS AX302 amp. The stereo works fine with the in boat speakers but the tower speakers do not work, I checked them both on another system and they...
take a digital volt meter and check the power cable and ground on the amp to see if you are getting any power . should read 12.5 or more if no power then check fuses and the ground connection
if you have power then replace the equipment that not working
Oct 29, 2010 | Car Audio & Video
Head Unit of boat stereo cutting out at higher volume
check your ground wire ..
then check battery has enough charge..
usually fault is in where your stereo is connected to your ground source.. good luck ,if no luck try your checking your speaker wires for a short..
May 14, 2009 | Kenwood Car Audio & Video
Radio troubles for 1985 Chevy Caprice
If the car has a built in amp/s for speakers would need to hook the wire from car amp/s up to amp turn on or power ant from radio
Jan 21, 2009 | 1985 Chevrolet Caprice
Jun 16, 2008 | Pioneer DEH-1900MP CD Player
Do I need a new equalizer?
Karla, Equipment and water especially SALT water (AND SALT AIR) don't mix very well. The constant high moisture environment affects all the connections (the wires) the rca connectors (where one thing plugs into another, AND the switches. The wires may LOOK good but the connections may not be. When you say "all seems to be in good condition" tell me specifically how you checked them. Sometimes they LOOK good, but ar not making connection. While your stereo is ON, get in there and wiggle everything and see it the speakers come back on.
My first guess is your amplifier/reciever. Does it have speaker switches? If it does, move them up and down or click them many times to see if you can work the corrosion a little. This may help.
I'll try and help, let me know some of the stuff I've asked fo above.
Feb 22, 2008 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
NO SOUND FROM CLARION XMD3
I have a XMD3 with Sirius on a Larson boat. Had same problem - everything seemed to be fine on unit (everything lit up and CD showed different tracks and time changing), but no sound. I suspected a ground problem and checked wires I could see. Found one speaker wire that had been frayed due to faulty installation. As soon as I wiggled that wire I got sound on all speakers. Not sure why one faulty speaker would kill all sound, but it did for me.
Oct 19, 2007 | Clarion XMD3
Jul 30, 2007 | iLO XM-MP3-CD Car Stereo
iLO XM-MP3-CD Car Stereo Logo
606 people viewed this question
Top iLO Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Libran Moreno
Are you an iLO Car Audio and Video Expert? Answer questions, earn points and help others
