Question about Amana AOES3030 Electric Single Oven
Amana AOES3030 wall oven. Why is the display/control panel dark?
Amana AOES303 oven. Display/control panel dark.  Only oven light has power.
  • 87 Answers
SOURCE: AMANA SINGLE CONVECTION OVEN CONTROL PANEL SOME KEYS INOP
Usually the keypad is separate and connected with a ribbon cable.If so, you just need to order a new keypad assembly
Posted on Jun 08, 2007
  • 1314 Answers
SOURCE: jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Posted on Dec 29, 2007
SOURCE: amana wall oven
Hi~ According to the manual for this oven, the F2 code signifies - high oven temperature. The only suggestion for any of the codes in the manual is to disconnect the electrical supply. It says" pressing OVEN CANCEL pad or disconnecting electrical supply may eliminate "F code". If failure continues, contact an authorized servicer.
I hope this helps. Linda
Posted on Dec 30, 2007
aborcass
  • 2651 Answers
SOURCE: Amana Convection Wall Oven Model AOCS3040 Does Not Heat in any Mode
sure its possible, sounds like you've blown an over limit thermostat behind stove, gets too hot and for safety reasons cuts off unit untill replaced
Posted on Feb 23, 2008
freetek
  • 5568 Answers
SOURCE: Element Question
In most ovens, both elements are used during the warmup phase even when used for baking and after the set-temperature is reached, the lower element keeps it stable.
You should be able to detect which one is not working with your bare hand. Set the baking temperature for 250-300 degrees, leaving the oven door open. Hold your hand at different heights in the oven and you should be able to sense which element is working and which isn't within a couple of minutes.
If you still aren't certain, then try using the broil element only. If it is heating, then it's obviously OK and that would point to the bake (lower) element by default.
A final check could be done with an open door and hovering with your hand over the lower element; no heat = defective.
Posted on Mar 03, 2009
We have to replace the control panel on our Amana AOES3030E wall oven. We have the part but how do we access the area where the new part needs to go? I'm not seeing how in the user manuals I looked...
To replace the control panel, the wall oven needs to be pulled out about 10-12 inches to access the conrtol panel..it has screws on the side AND in the back of control panel taht have to come off to get into panel...typically it can be pulled out fairly easy a couple of feet without it tipping and falling out of cabinet but only pull out as little as necessary
Aug 25, 2011 | Amana AOES3030 Electric Single Oven
How to replace the oven light
Most ovens have a round glass knob which you turn counter-clockwise or a flat glass panel with clips either side. Remove the glass to access the oven lamp.
Feb 10, 2011 | Amana AOES3030 Electric Single Oven
I have an Amana AOES3030 - we had a power outage and now the only button on the control panel that responds is "oven cancel". The clock is running and where the temperature shows when cooking...
Before doing anything else, turn off the power at the circuit breaker and leave it off for a few minutes... then turn the power back on and it should start up again and be okay...
If this does not fix it then the control board is fried...from the power surge when the power went out...
heatman101
Nov 23, 2010 | Amana AOES3030 Electric Single Oven
Amana AOES3030 oven. There are two control pads. One is the clock/timer that is working fine. The other is the bake/broil/clean which is unresponsive, no matter which button you push. I am considering...
Sam, Lost my chat window once again, but yes those are the part numbers for your control board and your key-panel respectively use them to be sure you are getting the right part.
Jul 10, 2010 | Amana Ovens
The control panel display light is completely dark but the oven still seems to function ok. Jenn Air Model WW30430P double wall oven.
A lot of ovens use a gas-filled vacuum flourescent display module that takes a higher voltage to drive it. The modules can get damaged or the power supply for the higher voltage (usually around 50 volts) may have failed.
Chances are the thing is only sold as an assembly...While the displays are common in auto speedometers that have digital display, those for these ovens are special with wpecial characters and background.
Jan 31, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
I have a Jenn-Air W130 electric range and the display is not working and I think I can make out an L1 on the display. Also, when baking the oven makes a whistling sound. Any help????
HI. This error code is indicating that there are several issue that concern the integrity of the main oven control board. This damaged control board will need to be replaced asap. Once replaced, the unit will operate correctly.
Nov 02, 2009 | Amana AOES3030 Electric Single Oven
Amana wall oven will not heat with new ERC
the heating element needs replacement.that the only solution.its common in this ovens as the heating element breaks down in between so it never heats up.
Mar 03, 2009 | Amana AOES3030 Electric Single Oven
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
F1 error on SS Amana Convection wall oven
The control panel has a design problem, and it gets dirty and worn over time. I have replaced mine once, and it happened again less than 2 years later. I took the panel out, and inspected it. I found a web solution that said to shim the panel out away from the housing slightly because it rubs on the metal housing around it and damages the control board contacts. I could see little scratch marks on the plastic skin around the edge of the button area, so that made sense. I tried it, and it still did not work.....panel was still beeping. Mine seemed to be the timer control buttons that were going on and off. So, I took it out again, and actually peeled the control surface off of the control board. No going back now, I thought. I got it off and looked at the control panel. It looked fine, but there was a lot of gunk and wear marks around the edge of the plastic button area. I cleaned it up with alcohol swabs, and put the cover back on the board. It was still sticky enough to go back on. I reinstalled it, and "bingo" no more problem. It has been fine for 3 months now. Yahooo!
Oct 16, 2008 | Amana AOES3030 Electric Single Oven
Amana AOES3030 Electric Single Oven Logo
116 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
john mabry
Are you an Amana Oven Expert? Answer questions, earn points and help others
