Question about HP Computers & Internet
I have a VoodooM780 that is not seeing the hard drives.
It runs post then says no bios installed, but when i hit the F2 button it goes into the phoenix utility where is still see no hard drives.It didnt come with an OS. I am trying to install a fresh XP and it also says no drives attached.Help
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 144 Answers
Your computer is failing to see that hardisk because it is not formated. download a DOS 6.22 bootdisk. boot from it, and type fdisk
hit enter
then type 1, hit enter
tell it to make a primary partiton
follow the onscreen instructions.
once you are done it will ask you to reboot
put the cd in the computer and hit enter
then type format c: /s
it will make c: a bootable drive
then run your windows installer
Posted on Mar 09, 2009
My Hdd is locked on my Dell XT2 I have the password but I cant find where to put in the Password
Restart the computer and tap F2 key during POST to enter System Setup (BIOS). This should prompt for the Hard Drive (HDD) or BIOS password. Knowledge Base
This should help.
While the computer is powering up keep tapping f2.
Turn it off. Press the power button again and keep hitting f2.
Aug 11, 2016 | Dell Latitude XT2 Tablet PC
No bootable device, hit any key
The bios cannot find any device it can boot from. This can occur because of hard disk failure, a loose connection or file corruption. There usually is a boot menu that you can get to from the bios by hitting some key specified by your bios manufacturer during the POST bootup process. Usually there is some message on screen like 'press esc for bootup options' or 'press f2 to enter bios setup' or something similar. As your machine starts up, try hitting ESC, F2, F5, F8 or F12 -one at a time-hitting each key several times during bootup (maybe your manual can give you a hint). If you get into the BIOS setup screen, look at the screen that tells you what the BIOS thinks you have attached for storage. If you don't see a hard disk there, you have a definite hardware problem. If you get into a boot option screen, try putting a Windows Installation CD, or a recovery CD from your laptop manufacturer, in the CD-ROM drive of your computer and enabling the machine to boot from the CD-ROM. If the PC boots from the CD-ROM, you may be able to use Windows Recovery mode or your manufacturer's recovery disk to get your hard drive working again. If you have any files you can't live without on your hard drive, look into getting your hard drive out of your laptop and into a USB drive enclosure that you can use another PC to try and read those files from the hard drive prior to attempting any recovery options, as some of them erase all files on your hard drive. Also check to see if your PC has manufacturer diagnostics that you can boot into to check your hardware with before attempting any other type of repairs.
Sep 04, 2014 | Gateway Computers & Internet
Well i just bought a dell optiplex gx620 (full tower) and im trying to install windows pro but every time i put the disk in the pc and turn it on it keeps saying that theres no bootable device...so i tryed...
From the info you supplied...
Boot (power off/on) and go into the BIOS (Usually hit F2 as it powers on and the white bar goes across the bottom for self test).
F2 will probably be listed as an option along the top (right). You only have a limited time to hit the key.
One of the menus should show what devices are connected (CD, hard drives). Make sure the system sees you're hard drive and CD-DVD. If the CD/DVD is not listed anywhere I would guess it is not installed correctly. I am not sure if the 620 will support an external USB C/DVD. This is another option and again, boot order would have to be changed.
Another menu has boot order. Make sure CD/DVD is at top of the list since you stated the drive is blank. I would make sure hard drive is second in the list. Save/Exit BIOS
Be CAREFUL MAKING any CHANGES to the BIOS.
Jan 11, 2011 | Dell OptiPlex GX280 PC Desktop
I've got an Dell Inspiron 9300 LCD
Try running diags Fn + Power button see if anything fails
Since you can boot to the BIOS, then the system is posting, so I suspect you have either a Windows issue or a hard drive issue.
If the HDD passes diagnostics, I'd try booting to the XP CD and see if you can press R for recovery console and run the command CHKDSK /R and see if that resolves
Post back with the results
Jul 19, 2010 | Dell Inspiron 9300 Notebook
I was playing an online game and suddenly everything was blocked. I hit del/alt/ctrl buttons and i restarted laptop but mouse pointer is still frozen and i can't enter windows. i have a lenovo laptop, it's...
1. Lenovo's are top of the line laptops.
2. anything could have happened.
your hard drive died. your video card crapped out. your motherboard burned a diode or a component, your power adapter spiked in voltage. you got hit with lightning. you were infected with a virus.
lenovo laptops usually have a blue button to hit or you can hit the F2 key during startup. In some cases it might be the delete button.
See if you can enter the bios screen?
If you can post back and tell us where it hangs with more information.
Jan 23, 2010 | Computers & Internet
My Dell Latitude will not boot. it says no hard disk detected.
The first thing to do is go into the bios. To do this, power up the laptop and hit F2 at start up. Sometimes it requires hitting the F2 button numerous times. You should see message in the top right corner that says "Entering Set Up". Once in the bios screen, look through menu to see if your hard drive is recognized by the bios. If it is not recognized by the bios, it may be a defective hard drive or problem with the motherboard. You might also try removing the hard drive and checking for any problems with the connector then reinstalling the hard drive and trying to boot up again. If this does not work, I would recommend replacing the hard drive.
Dec 24, 2009 | Dell Latitude D600 Notebook
I have a Dell Latitude 600 when you turn it on it fires up,goes through the bios dell page can hit f2 or f12 and can get into there ok.It WILL NOT start in safe mode ,f8 not going to mode or f7.Pulled out...
During the POST, press F2 and look through the BIOS tabs until you find the page that lists the installed drives. Usually this is the 1st or second page.
You should have 2 drives installed. Your HDD and an Optical.
If both show up, then the problem is likely unrelated to the ATA Controller (which is part of the Motherboard).
The Dell Recovery CD can be requested from Dell, or you can enter your service tag number on their site to see if it's available as a download.
Oct 16, 2009 | Dell Latitude D600 Notebook
Dell Dimension E521 ''Diskette Drive 0 seek failure''
Is there a diskette drive installed?The bios is looking for a device that was enable but not there.If you prefer to ignore this problem you may do so,however the fix is very simple,unplug the computer remove the cover,there is a coin battery which stores the configuration of the computer you may need to remove it.This will erase the configuration stored in the bios,or you can install a jumper on the motherboard which will clear the bios setting .Remember to return the jumper on the pins it was on.
good luck
Jul 01, 2009 | Dell Computers & Internet
Dell dimensions 3100
sounds like your floppy drive is failing, you could get it replaced or simply turn it off via the BIOS.
to turn it off simply hit the F2 key. On the first screen usually it will list your Hard Drives, CD ROMs', and the Floppy. scroll down to the floppy and hit enter ot the corresponding key form the bios's legend at the bottom or right hand side of the screen untill you see disable.
Next you can navigate to Save & exit or hit F10 to do the same. G/L.
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
Hd is there but not there
You have to do a resart and hit f2 key to go into bios. Change the startup device to the cd-rom drive. What ever os you are running you must put that disk in and you need to hit a key to run from the disk. You have to format the drive and install OS. If this is just a data drive, you still have to format drive but don"t install OS.
Apr 25, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
20 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
