Question about Pioneer VSX-917V-K Receiver
I Have a VSX-917V-k When I put up the volume past 25 it works for a minute or two and then its says overload and shuts off. The speakers are older than the system but they r 15" Technics which work at 8 Ohms and Say 200watts (music) and 100 watts (DIN) on back of speaker. They work great I had an older piooner receiver with less power and it didnt have any problems with them but this on overloads and shuts off when I put up the volume I only have those two speakers no sub. or sorround speakers. and its not up enough to were it distorts or anything it just overloads.
    Novelist:
  • 98 Answers
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Rewire if necessary..
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. I could guide you a bit. If not, then a local service center will change the local labor rate. Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further. Thanks for using FixYa!
Posted on Mar 10, 2009
  • Sachin
    Sachin Mar 10, 2009
    Just check your speaker as well....whether they play all right thru another receiver or amplifier. Since they are old, it posiible they could be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
Pioneer vsx-d510
Disconnect all the speakers, and then check. Connect the speakers, one by one, and find which one makes it overload. That speaker is faulty. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 15, 2016 | Pioneer Audio/Video Home Theater Remote...
Overload pioneer vsx 808 rds
if it's shutting down when you increase the volume, this usually indicates a bad speaker.
Jul 03, 2013 | Audio Players & Recorders
I have a Pioneer VSX-917V. After using it for a couple hours and everything working good, the center speaker quits working. I can reset the unit, re-ajust all speaker settings to my prefrence and the...
If new unit, don't waste your time, sounds like a faulty "Sound Card". possibly a slight hairline crack which only shows up when it warms up, yet after a few mins switched off, cools reconnects and so plays?
Dec 26, 2010 | Pioneer VSX-917V-K Receiver
Receiver shuts down when setting volume above certain range.
disconnect all your speakers and if it still does it, yes, take it to service. if not, check all your speakers and wires. good luck
Feb 09, 2010 | Pioneer VSX-815-K Receiver
My pioneer amp vsx d508 reads overload.what to do?
Sounds like a bad amplifier IC.
Unhook all speakers at the back of your pioneer. turn it on and turn down the volume. If it's no longer in overload you have a bad speaker or speaker wires touching somewhere.
If its still in overload it's prlobley a amp IC and will cost between $25-$60 just for the part if you can replace it yourself.
Dec 27, 2009 | Pioneer VSX-D508
VSX-D608 Overload and shutdown
Overload is displayed when the amp draw is excessive, and can be caused by different faults.
when Overload is detected, the protection circuit will shut down the unit to prevent further damage.
The first thing to try is hard reset. Shut down the unit for about one hour to drain power completely.
This can fix minor problems that can cause overload, for example electrostatic charge accumulation on internal capacitors.
If that does not fix the problem, then you must find the fault.
Overload can be caused by shorted speakers, wrong impedance speakers, or by a contact on speakers wiring.
Check speakers connection and test different speakers with 6, or better 8 Ohms impedance.
Another test can be done by unplugging all speakers, and reconnecting and testing them one at a time, at a very low volume.
No more than two 4 Ohms speakers can be connected to the unit, or you will get overload.
If the speakers are OK, then preamp, shorted input/output connectors, main power supply or faulty output transistors can draw too much amps causing overloading.
In that case it is recommendable contacting Pioneer at the number listed on the owners manual.
Jun 22, 2009 | Pioneer VSX-D608 Receiver
I have a pioneer receiver and when i try to increase the volume past the half way point the screen flashes"overloading" wtf i have exactly the same problem as mtloans....pleeeeease give us a...
I would check your speakers OHM input requirements, usually an "overloading" indication is clipping the receivers internal amplification capabilities, also check speaker polarity to confirm exact + - connections
Feb 20, 2009 | Pioneer VSX-917V-K Receiver
OVERLOAD Message followed by receiver shutting down.
The First step in this would be to Check the Ohms Limit in the Manual and Compair to the Ohms on the Speakers that you are running and the Ones that came with it. Usually when you By the "Kit" the Speakers are Factory Matched with the Reciever. Let me Know!
Jan 02, 2009 | Pioneer Audio Players & Recorders
Bose 901 connection to Pioneer VSX-917v Receiver
any pre-out should work. i believe the bose have a rca jack connector for attaching to the receiver. look at the new receiver connection diagram. any output that is rca designed for use by a recording device will send a signal that the 901's can see.
always check the manual on both before connecting for any precautions.
good luck
mark
Dec 28, 2007 | Bose 901 VI Main / Stereo Speaker
Overload Problem
If your rec'vr worked with the original front and rear speakers, the new speakers are either defective or ar the wrong impedance.
Also, I find this confusing: "I connected the wiring for 1 of the front speakers to the connection on the rear of the receiver". This may indicate wrong wiring connection. Make sure you have connected the speakers properly
Dec 04, 2007 | Pioneer VSX-D608 Receiver
Pioneer VSX-917V-K Receiver Logo
294 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
