Question about LG 42LC2D 42 in. LCD HDTV
I lost some channels on the tv and can't get them back
Cable line is working fine
  • Anonymous Mar 10, 2009
    the problem is on LG 42PC5D it is the same even if i did an automatic and manual scan, does the tv carry any form of a card?
  • 3 Answers
Hey this is Victor. You probaly might if messed around with the contoller and somehow deleted the t.v channels or the antenna is not working properly
Posted on Mar 09, 2009
My Lorex SV-01-RCV Wireless A/V instructions were lost in our move and I need help with the set up. Could you please help? I can not remember the correct connection.
You should have a 2-wire cable with Yellow, White and Red RCA plugs on each end.
The Yellow line is video out.
The White line is Left channel audio out.
The Red line is Right channel audio out.
Since your RCV only has two RCA jacks use the Yellow line for video and the White line for audio.
You should also have an "F-connector for co-axial cable.
If your TV set does NOT have audio and video jacks hook that to the co-ax antenna connector on the back of your TV set.
Set the RCV for either channel 3 or channel 4 and do the same with your TV set.
The RCV unit has four receive channels which must match up with the channel selected on the CAM or TX unit.
You can scan all four channels either by auto or manual.
If you only have one CAM or TX unit it probably doesn't matter which of the four you use unless you have a computer ROUTER which interferes with one of the four channels.
If so, select the 1, 2, 3, or 4 channel which has the least or no interference manually.
Bil Munsil
K1ATV HAM TV
Mesa AZ
Hams should be seen as well as heard.
Dec 30, 2009 | Home Security
I have 3 digital tv's one in the lounge/bedroom and kitchen for some reason last night, the tv's in the bedroom and kitchen lost all digital channels and the analogue channels were very poor to view snowy...
Loosing digital channels is equivlent to a snowy analog channel, check you cable connections, and splitters to the tv, since you have two of them out, it does not make sense that it is your tv. It is a conneciton in your cable line somewhere.
Sep 02, 2009 | Televison & Video
Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Oct 12, 2008 | Tivo Series 2 80-Hours Video Recorder
Lost ba channel
if You have cable maybe you have a bad line
but if you just have an over the antenna lots of station are switching to digital early so maybe your station is not brodcasting analog then you would have to buy a Digital Converter Box
Sep 07, 2008 | TruTech PM1919BXA1 19 in. LCD TV
I lost my instruction manual and can only get local, non cable channels.
Go into the menu to channel setup and change the setting from tv back to cable(catv).
Jun 26, 2008 | Durabrand DU1301 TV
Sharpe LCD TV...model LC-195K24U-K...can't get to change channels
what causes a line down the middle of my screen
Jun 08, 2008 | Televison & Video
Video channel has diagonal lines
check the connections from your video to your tv, sounds like you have a loose wire,
If not re-tune your tv , it might have lost the tuning a bit , but its probably a loose connection
Feb 28, 2008 | Televison & Video
Tv guide/tuner problems
Most likely the TV Guide is broadcast from the OTA PBS channel. I don't know why its being lost. I'm thinking its probably a firmware problem of some sort. Adding the PBS channel back in, making sure the signal comes in ok and leaving the TV off for a while might help.
Dec 25, 2007 | LG 26LX1D 26 in. LCD HDTV
Lost channels 2 through 52
I think the low band (Channel 2-6)in your tuner is not working. This could be in the tuner itself or in the band switching circuits. Possibly she deleted the low channels or locked them out. Stargazer
Jun 14, 2007 | RCA F32632SB 32" TV
LG 42LC2D 42 in. LCD HDTV Logo
97 people viewed this question
Computer Repairing
Computer Repairing
