Question about Garden
DID NOT RECEIVE OWNERS MAUAL WITH HOMELITE PRESSURE WASHER
I did not receive a users manual with my Homelite 3,100 PSI 7 HP OHC Gas Powered Pressure Washer (CARB Compliant) #HP3127S when I bought it. I was told at Home Depot I could easily find one on line and am finding it next to impossible. I have spent 2 days using every search engine I can without any success. Any suggestions?
  • 6,784 Answers
Hi there. Unfortunately, this model has been discontinued and excluded from the Homelite main website but, there is still a way to retrieve your manual. you will have to register on the Contact us page. There's a request box below on this contact page. Use this request box to ask for delivery of your manual to your home address. I have provided a link to this page below. one more thing, theres a tab jsut above the request box. make sure to adjust the tab to read Need manual and include your model number.
Click here to be directed to the Contact us page.
Posted on Mar 09, 2009
  • 19,396 Answers
Try downloading or asking the manuals from Homelite website, see:
Homelite :: Home
    Genius:
  • 1,550 Answers
You can get the manual by contacting manufacturer . Provide them the billing information for your product . They will send you the manual by mail within 2-5 days . There is no manual online .
Why detergeant for homelite 2700 pressure washer only works with blue tip?
The chem venturi relys on low pressure to function this is specifically the blue nozzles job, to create a low pressure for the venturi to work.
otherwise you will be wasting chemical the entire time you are using the cleaner.
Hope this helps:)
Brad
Jul 14, 2014 | Homelite For Excell - Pressure Washer Pump...
Why can't I get pressure
Bypass valve may be stuck open bypassing the pressure.
www.homelite.com/service_support
Jun 23, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Homelite Pressure Washer. 2700 psi 2.3 GPM Gas Pressure Washer won't start
I found a small long spring disconnected from my throttle which made the engine run rough It is easy to reconnect and makes a big difference in engine performance. also, if there is a very dirty air filter-oil/dirt it will not start-replace filter.
Jun 17, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Will only start with the choke on and runs for only a few seconds and then it stalls. After waiting for a few seconds it will restart only to do the same thing.
you problem is the carb it needs to be cleaned or you may have to rebuild it or you could have water in your gas to check pull fuel line loose from carb and drain some into a clear glass jar you can see the water settle at the bottom .
Oct 27, 2013 | Homelite Pressure Washer. 3,100 psi 2.5...
Homelite ut80522d pressure washer motor reves up and down then dies
It's surging... your carburetor needs to be serviced. It's not giving the proper air fuel ratio to the engine...
BriMaxSmallEngineRepair
Gibbstown,NJ
Jul 26, 2013 | Homelite Gas Pressure Washer: 2700 psi 2.3...
Remove&replace gas tank on a homelite 2600 pressure washer mod# ut80522
if you are in the UK we have found these parts to be available from Ryobi but they dont often make the engines... identify the engine as this is who will make the fuel tank !
Jun 30, 2013 | Homelite Pressure Washer. 2600 psi 2.3 GPM...
Need Manual for WorkForce Pressure Washer WF80710
http://manuals.homelite.com/system/files/4318/original/HLCA80710_740_trilingual.pdf?2011
Nov 09, 2011 | Homelite Workforce 2500 PSI 23 GPM Axial...
I did not receive a users manual with my Homelite HP3127S
Hi, I contacted Home Depot in regards to a manual for your pressure washer and was told that it was the stores responsibility to provide you with the manuals for your product. I also visited the Homelite site and there is no literature available as a part. You must register on their website to send an email with your request if you choose that option. I also had your experience in trying to locate a manual online. I believe your best recourse is to contact the manager of the store where you purchased the unit and explain that you need a manual and were advised by Home Depot customer service to attempt to resolve the issue with the store first. Let me know if you need further assistance. Hope this Fixsya!
Mar 09, 2009 | Garden
Garden Logo
173 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
