Question about Kenmore 44102 Front Load Washer
Wont drain and wont spin
Sounds like I have a load on something or something is slaveing, It wont spin, It washes ok but thats it and this thing is BRAND NEW, this will be the second time we"ve had a tech out, kenmore is nothing but ****
  • Anonymous Apr 10, 2009
    It washes, the dial moves forward, it should drain, but continues to wash. The dial moves forward to spin and it continues to wash
  • 1,550 Answers
It sounds like you have a bad clutch in the washer. To diagnose this failure, you would need to pull off the washer cabinet and pull the transmission. It is likely that you would find the clutch band glazed over. It is probably not exerting enough torque to release the brake and spin the washer.
If you find this problem, you can try sanding the band to rough it up. Reassemble the washer and check for proper spin. If this fixes the problem, you will need to order and replace the clutch band.
This type of procedure is usually performed by a service technician. I don't recommend attempting this repair unless you are completely confident that you can safely perform the work.
Also check the motor drive coupler.
Posted on Mar 09, 2009
Washer wont spin cycle, all other cycles ok.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Feb 18, 2011 | GE WDSR2080D Top Load Washer
I have a Hoover top load 610 and it wont start wash cycle
These are a great little machine,I dont know why they have to go changing things.Anyway this sounds to me like the timer.It fills & the water cuts off so the inlet valve is ok.It drains so the pump is ok.It spins so the motor should be ok.Try it on other cycles like gentle or delicate & see if it agitates.I'm sure it will be the Timer.
May 22, 2010 | Washing Machines
Washer wont agitates and drains but wont spin when it gets to the spin cycle. timer still moves.
Tough to say without doing some testing. First thing to check is the coupling. It may sound like its agitating and may not at all. IF it really does agitate and won't spin, I would start diagnostically testing the timer. That isn't something your average homeowner can do though.
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore elite catalyst wont drain or spin
Did you ever find out what is wrong? This is exactly what has been going on with ours.
Mar 25, 2009 | Kenmore Washing Machines
Motor just humms
Hello, it sounds like 1 of 2 things. 1 you have a bad motor or 2. you might have something caught in the pump. So if you want to and if you can remove the pump and see if the motor spins. If it spins then there is something in the pump. Thank you
Dec 03, 2008 | Kenmore 24032\24036 Top Load Washer
Frigidaire front load washing machine gtlf490e
ill save us some time that washer is one of the best out there i have one my self pop me an email at and check my4 boxes say in e mail front loader wont spin ill send ya something
May 21, 2008 | Frigidaire GLTR1670A Front Load Washer
Washer wont spin
is it draining ok or does it m ake any noises as if trying to spin?
Mar 05, 2008 | Zanussi F1045W Front Load Washer
Wont spin
Terri, if it was the lid switch, you wouln't be able to drain. If it were the coupler, it wouldn't agitate. Sounds almost like you have something in between the basket and tub, or a nail or something in one of the basket holes stopping the spin. You will need to remove the cabinet and remove the top tub ring to check these things out. I will attach a couple of photos for you to see if this will help you out. If you have nothing holding the basket up then more than likley it's your basket drive which is a pretty hard back
Oct 02, 2006 | Kenmore 15864/15862 Top Load Washer
Kenmore 44102 Front Load Washer Logo
336 people viewed this question
Sal De
 Brian Main
Brian Main
