Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
The engine makes a funny noise and the brushes make sparks.
How do I get access to the motor to check the bearings, etc. I have an Electrolux E-2000
  • 134 Answers
Hi
The bearings are not replaceable. If the bearings have gone you need to replace the complete motor
Posted on Mar 09, 2009
Brush makes noise when engaged, I put a new belt
You don't say what kind of noise, but if it is a bumping noise or squealing noise, make sure both ends of the brush roller are clean. It may be binding.
Oct 05, 2014 | Vacuums
My electrolux vacuum has a red light that won't turn off and my brush roll won't work
Check the belt and the end bearings are free by hand. (electric off plug out) if not free remove plate to access roller/brush, remove clear any obstruction (Hair/string/thread) replace and test. ensure you site belt back on to spindle and roller/brush correctly...
Aug 22, 2014 | Electrolux Vacuums
My upright electrolux persicion vacuum when turned on just makes a horrible sound both on bare floor and on carpet brush does not turn
Hi, sounds like you need a new belt or brush and bearings . Sometimes when a belt goes it makes a bad noise as one of the belt teeth make be worn out. Hope this helps.
Jan 22, 2014 | Electrolux Vacuums
Compact electra C9 vacuum power head wont turn on
Have you checked the electricity is getting to the motor? You can replace the motor if necessary.
Jan 17, 2014 | Electrolux Epic 6500 Vacuum
There are sparks coming from the underside of my oreck xl vacuum.
You probably need to take that in and have it serviced at a repair shop. They can check the motor to see if it needs to be replaced or just cleaned. The noise could be bad bearings or a fan problem as well.
Feb 21, 2013 | Oreck Vacuums
The ball bearings are stripped from the roller brush of the power head for my electrolux model N115M
you will most likely have to replace the roller brush wth bearings. i just recently had to replace my wifes on her electrolux. i was able to order the parts online at sears parts direct, but there are many places to get them online. you will need the model and serial number. hope this helps.
Apr 11, 2012 | Electrolux UltraLux 2000 Bagged Canister...
My machine ran over some string,made a funny noise and emitted some smoke,the hand suction pipe at the rear works perfectly, the motor runs fine,but the front of the vacuum will not work.thankyou very...
the string bound up the beater bar (brush), keeps the belt stationary, and the motor spindle is just rubbing against the belt and melting it. remove the belt guard, remove the brush, and the belt. clean off the brush bearings (at the ends of the brush) of the string and make sure the ends spin freely from the brush. replace the belt with a new one, and put it all back together.
Aug 17, 2009 | Panasonic Vacuums
Sparks in the el. motor of Electrolux Canister.
check the wiring it might have gone bad
Jul 07, 2009 | Vacuums
Loud 'drilling' noise from motor area when turned on.
Sounds like bad bushings/bearings in the motor -- need to replace them.
May 27, 2009 | Electrolux Vacuums
Vacuum Repair
Take the screws out of the bottom plate. Take the 2 screws out of the drive motor- opposite end of where the belt goes. Loosen the 2 screws where the belt goes, put the belt on and replace the screws. Make sure to thoroughly clean the brush while you have it apart. Don't oil the bearings. Oil will only make the dirt stick and jam the bearings.
Aug 15, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
179 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
