Question about Garden
I did not receive a users manual with my Homelite HP3127S
I did not receive a users manual with my Homelite 3,100 PSI 7 HP OHC Gas Powered Pressure Washer (CARB Compliant) #HP3127S when I bought it. I was told at Home Depot I could easily find one on line and am finding it next to impossible. I have spent 2 days using every search engine I can without any success. Any suggestions?
  • Anonymous Mar 31, 2009
    My problem re the Homelite Pressure washer manual is exactly the same, including the Home Depot runaround. Great machine-Good value , but I sure would like a basic manual.
  • 257 Answers
Hi, I contacted Home Depot in regards to a manual for your pressure washer and was told that it was the stores responsibility to provide you with the manuals for your product. I also visited the Homelite site and there is no literature available as a part. You must register on their website to send an email with your request if you choose that option. I also had your experience in trying to locate a manual online. I believe your best recourse is to contact the manager of the store where you purchased the unit and explain that you need a manual and were advised by Home Depot customer service to attempt to resolve the issue with the store first. Let me know if you need further assistance. Hope this Fixsya!
Posted on Mar 09, 2009
  • Jim London
    Jim London Mar 15, 2009
    Hi, Please do not shoot the messenger! I went out of my way to help you FOR FREE! I did an extensive search, made several phone calls and you give me a negative rating. My ratings are important to me to show customers that they are receiving expert help. You asked for a suggestion and you got one, I am sorry you did not like it. Thanks
  • 3 Answers
Thier manuals can be obtained by calling their customer service at 1-800-242-4672 you will need to provide them with the model number and they will mail it or e-mail it to you. I have had no problem with this.
Posted on May 26, 2010
Homelite Pressure Washer. 2700 psi 2.3 GPM Gas Pressure Washer won't start
I found a small long spring disconnected from my throttle which made the engine run rough It is easy to reconnect and makes a big difference in engine performance. also, if there is a very dirty air filter-oil/dirt it will not start-replace filter.
Jun 17, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Ridgid rd80702 will not start
Sounds like the float is stuck open. A few taps with a screwdriver handle on the fuel reservoir might fix the problem.
Apr 15, 2014 | Ridgid Rd80702 3300 Psi 3.0 Gpm 7 Hp...
Ridgid pressure washer motor runs choppy when choke is disengaged
The choke reduces the air flow into the carb. If you are having problems with the choke off, it means that not enough fuel is getting into the engine and it is running lean. When you choke it, the reduced air flow causes the mixture to be correct and it runs fine.
Feb 09, 2014 | Ridgid Rd80702 3300 Psi 3.0 Gpm 7 Hp...
What spark plug
Go here and input your model number to search for your manual. The number is in there.
https://www.ridgid.com/us/en/literature-search
Jan 02, 2014 | Ridgid Rd80903 3000 PSI 2.6 GPM 5.7 HP...
Will only start with the choke on and runs for only a few seconds and then it stalls. After waiting for a few seconds it will restart only to do the same thing.
you problem is the carb it needs to be cleaned or you may have to rebuild it or you could have water in your gas to check pull fuel line loose from carb and drain some into a clear glass jar you can see the water settle at the bottom .
Oct 27, 2013 | Homelite Pressure Washer. 3,100 psi 2.5...
Honda 5 HP OHC Engine
did mice chew threw the wires to the coil over the winter pull the cover and look
Apr 07, 2012 | ALL POWER AMERICA LLC AllPower America...
Can't get pressure from homelite hp3127s gas pressure washer after using only 1 season. can't find manual to find problem. is there a switch i'm missing?
No,it's probably a bad valve body or the pump itself broke. Homelite isn't the best quality machine.
Jul 14, 2009 | Garden
Need a part for Homelite model HP3127S pressure washer - 3100 PSI
I lucked out when I managed to locate a local rent it centre who sells and services Homelite equipment. I bought my pressure washer at Home Depot and when I approached staff there regarding my problem, they had no idea if there even was a local dealer who sold/serviced Homelite stuff. telephone enquiries finally led to the rental place who ordered the part for me. I was getting concerned!
Jun 19, 2009 | Garden
Garden Logo
2,003 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
