Question about HP OfficeJet 6110 All-In-One InkJet Printer
Need scematic for hp 6110
Need to see assembly to put WHITE PLASTIC RIBBON BACK ON.
How do i scan my documents to PC ie .. on my hp6110 all in one printer.
Posted on Mar 11, 2009
We have been getting white horizontal lines on our documents. Both print heads were recently replaced and that did not solve the problem. What part is needing replaced?
I had this same problem and none of the printer services (clean printhead, align printer, calibrate linefeed) fixed the problem. After trying every solution that I found on the internet with no success I was able to fix the problem by cleaning two critical parts of the printer.
1. Turn off the printer and open it as though you are going to change the printheads.
2. Towards the back of the printer you will see a thin clear plastic ribbon that has very small black lines on it. Very, very, very gently clean this ribbon. I used a lint free cloth and some glass cleaner. Spray the cleaner on the cloth and slide the cloth against both sides of the ribbon. Do not pull on the ribbon. This ribbon is used to tell the printhead how far it has moved from side to side.
3. Next locate the silver bar that runs across the back of the printer. This bar is used to feed the paper through the printer as it is printing a document. On the left side of the bar you will see some plastic guides that hold the bar in place. On the outside of the plastic guides you should see a clear plastic disc made of the same material as the ribbon above. This disc also has very small black lines on it. Again very, very, very gently clean this plastic disc. This disk is used to tell the printheads how far it has travelled down the page. This is the one that was causing the problem. The dust or dried ink or whatever was on the disc was causing the printer to incorrectly calibrate the linefeed and was causing the white lines to appear on my documents.
4. Use the "calibrate linefeed" function of the printer services to recalibrate the linefeed and the white lines will hopefully be gone.
Jul 26, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Cannot align cartridge
ok, now clean the encoder strip with clean cotton. encoder strip found and the back of the printer ink assembly look like a plain white plastic. wipe that till it clean.
Apr 14, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I have an HP officejet 4255 all-in-one printer. The plastic ribbon on which the cartridge assembly rides in both directions has come off. How can I put it back on? Thanks Caesar
its a difficult situation....
if you are having good skills in servicing electronic equipment you may open the top cover sincerely and access to the mounting arrangement of the timing belt (transparent ribbon). It is easy to place it properly back on position.
Better to contact nearest HP service centre, if you are doubtful about your skills for the same....
Dec 12, 2009 | HP OfficeJet 4255 All-In-One InkJet...
My HP officejet 6110 only prints in black and white
Every time I try to print I get a message saying that The Spooler service is not running, what should I do?
Feb 07, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Hp 6110 printed page does not drop into tray freely
it sounds like the plastic pushers are broken off.
parts not available. sorry
Jan 25, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Mazda Millenia tail light bulb replacement
Problem has been solved. I very gently pulled on both ends of the lens assembly and it popped off. The white plastic pieces housed plastic attachment 'tabs'. They can snap right back in place once pulled out to put assembly back.
Jan 03, 2009 | 1999 Mazda Millenia
Screen is black but pointer is still lit
Yes. I know exactly how to fix this because I had the same problem. Most likely what happened was the ribbon that attaches your screen to the motherboard has gotten loose or fallen off. All you need to do is remove the small screw (the only screw) on the back near where you remove the batteries. Then pop off the top rubber part on the front. Now you can pull the entire center piece out from the plastic case and you will see two ribbons. Make sure each one is secure to the motherboard. Put everything back in the casing, put the screw back in and it should work. It worked for me.
Nov 22, 2008 | Leica DISTO A5 Rangefinder
Child damaged HP6110 - Help
It stretches from left to right behind the cartrige assembly and the assembly slides on it. It's a sensor strip for positioning the cart. asm. I'm not sure how it attaches, but you'd have to take the unit apart to do it.
Good luck...
Geno
Mar 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Not ledgible
Your printers alignment is out thats why it wont print ,
Take out the ribbon and look on the ribbon drive assembly for a white plastic screw ? press the outer ring (also white plastic) down it should be spring loaded.while this is down use a small screw driver and turn the screw counter clockwise and than release the spring loaded gear it will shot back up.Try this a few times till the printing gets better.
Good luck
Dezzi
Dec 27, 2007 | OKI MICROLINE 520 Matrix Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
Ben Johnson
