Question about Dell Latitude D600 Notebook
The date & Time reset as you unplug the adaptor and also the battery won't charge but the laptop comes on fine
  • vinayrc Mar 10, 2009
    I replaced the cmos battery but same problem need helf
    need help
  • 170 Answers
Sounds like you need to replace the CMOS battery on the motherboard, and replace the battery, the CMOS will cost you about 2.00 the laptop anout 50.00
Posted on Mar 09, 2009
Batery won't charge new battery n plug
You may have the wrong AC adaptor, Dell is very picky when it comes to Power adaptors, it must be original OEM Dell for the laptop to recognize it, any after market no name brand even though it has the right specs and is made for your model will power your laptop but the circuit to charge your battery will automatically be closed
Nov 17, 2012 | Dell Studio 1737 Laptop
My laptop is completely dead, fine yesterday. Today no lights, sounds nothing. I tried removing the battery , unplugging no response. Thanks,
Remove the battery for at least 3 minutes... Then put it back and then plug in the charger and switch on the charger. If the battery is completely drained, it would take a while for the charging to initiate. Please have patience and leave it on charging even though without the charging indication for at least an hour. After that still if the charging indicator doesn't lit, then its definitely your charger or laptop. You will need to take it to a service centre in that case.
Nov 03, 2011 | Compaq Presario 2170US Notebook
While charging on AC works absolutely fine. But while discharging i.e. Running on battery, shuts down unexpectedly. The same also happens when the the AC adaptor is plugged out at random. Lastly, the...
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 10, 2011 | Computers & Internet
My hp 540 in battery mode while powered on switches off automatically within 4 second even before display appears, booting takes place whereas in adaptor it is reatsrting automatically
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Apr 21, 2011 | Computers & Internet
There is an issue with the laptop charging circuit as the machine indicated plugged in, charging. However, it did not charge at all. Laptop work fine with AC Adaptor.
How old is your battery? Lithium ion based batteries normal life is 2 years starting from the date of manufacture, sometimes even less. Try using another battery and see if it will charged properly. You can also use the adapter in a compatible laptop and check if it will charge the battery.
Jan 11, 2011 | Computers & Internet
My laptop wont charge. if i unplug the ac adapter and plug it again it wont charge... how to fix it?
Check for physical damages on the power cord or teh power brick try it as well on a different Laptop if it does the same thing if the adaptor works fine in a different laptop try plugging the adaptor without the battery on the system try unplugging and plugging it back in if it will work properly without the battery then most probably either your battery needs to be replaced or your systems Motherboard....
also you can try updating system BIOS which is risky, check your Manufacturers website or call them for any information about BIOS updates for the system.
Jun 03, 2010 | Computers & Internet
Want stay charged
Sounds like a bad battery cause its not keeping a charge. Try a new or known good battery and see if it will charge and then unplug the ac adaptor to see if the laptop stays on.
If the laptop stays on with a different battery charged then your old battery is bad. If your laptop doesn't stay on with a known good or new charged battery without the ac adaptor hooked up then its a bad motherboard.
Feb 14, 2009 | Toshiba Satellite A100-S8111TD Notebook
Laptop won't turn on, battery won't charge
I had a similar issue with the Armada M700 from Compaq. Never did figure it out exactly. But I do know this. When you unplug the power chord and take out the battery and plug the power chord back in while the battery is out usually for some reason it turned on allowing me to replace the battery which would then begin charging. Your problem interests me because I can really relate!
Jan 14, 2009 | Compaq Presario 1200 Notebook
Pc is telling me to plug it in when the battery is at 90%
The battery needs to be conditioned. To condition a battery, plug in the AC adaptor and charge it to 100%. Unplug the AC adaptor and run the battery completely down to 0% or until the computer shuts itself down or goes into a hibernate mode. Once this occurs, plug the AC adaptor back in and fully re-charge the battery to 100% again. You should now be good to go.
Let me know what happens and if this has solved your problem. Thank you, Binary Bob
Dec 07, 2008 | Acer Aspire 3680 Laptop
Date/time problem on *ist d
There is a small re-chargeble battery inside the camera that charges of the main battery. Chances are that battery had just drained when the date/time reset occured, but should be fine after you recharge.
Sep 08, 2005 | Pentax *ist D Digital Camera
Dell Latitude D600 Notebook Logo
Alun Cox
