My laptop shuts down and attempt to restart but unable to do so.
This is what is displayed after everything.
640 system RAM passed
894 extended RAM passed
system BIOS shadowed
video BIOS shadowed
ERROR
0200; Failure fixed disk 0.
press F1 to resume. After pressing F1 it's unable to boot again.
please what do i do? thank you.
Acer Aspire 3100 version.
  • 1 more comment
  • Anonymous Mar 26, 2009
    There is a manufacturer fault on the acer aspire motherboards. I am having same issue with an Aspire 3100, and I have ruled the problem down to the IDE controller chip on the motherboard. It was either improperly soldered onto the motherboard, or is loose. You can tell this by putting a little pressure on the controller chip and the system should boot. Fixable by resoldering the chip onto the mb--- not a job for anyone.
    http://www.youtube.com/watch?hl=en&v...
    Hope this helps.
  • mercedes noble Apr 07, 2009
    i have compaq presario r3000. it says a disk read ans error occurred
    press ctrl+alt + del to restart. i did try it few times but still not working, help please
  • Anonymous Mar 19, 2014
    The TFGHT is compressed the TPM has problem the system and video bios shadowed L2 Cache fixed disk 0: WDC WD2500BEVT-00A0RT0 What does it mean
    what can be done
    Master:
  • 404 Answers
Your bios battery is low but also you need to do a clean xp installation.
Posted on Mar 09, 2009
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
Suddenly stopped working ,won't restart my PC?
First of all disconnect all peropheral connected to your motherboard. Take out Your RAM and clean it with soft clothe. Reinsert ram and restart your PC. If you can get display at this point then shut down your PC connect all peripheral back and restart your PC.
If not you will need to replace your ram.
Nov 29, 2012 | Computers & Internet
My laptop is acer aspire 5542G, it is struck on bios shows the following : phoenix secure core(tm) NB copyright 1985-2008 pheonix technologies ltd. all rights reserved v1.05 cpu0=AMD turion(tm)...
Hi
you could try to press F8 on startup eg press power key then press F8 holding down for a few seconds and hopefully it will take you into some repair options
i would try the last known good configuration option to start with
then windows will restart and try to repair it back to when it was good
and if that dont work try the safe mode/system restore
hope you get it sorted
many thanks
Mar 15, 2011 | Computers & Internet
Computer hangs regularly, usually after just over an hour. But occasionally after a few minutes. Attempts to check 1TB disc unsuccessful (Extended WinDlg122) because computer freezes half way through...
Sounds like 1tb hard drive is passing quick test and then freezing extended test. And if it doesnt freeze during the 200gb test then I would guess the 1tb is going bad. Check the event viewer in windows under system and see if there are any Disk errors with a red X and that ideall will say disk drive 1 or 2 cant read it and yeah that would help confirm it is failing.
Mar 03, 2011 | Intel Core 2 Quad Q9400, 2.66 GHz...
I turn on my compaq and the first thing come on screen is CPU=AMD-K6(tm)/300 00000640K SYSTEM RAM PASSED 00064512K EXTENDED RAM PASSED 0512K CACHE SRAM MOUSE INITIALIZED FIXED DISK 0:FUJITSU...
above 06 lines are related with system information, Go to the BIOS check the startup sequence, if everything is ok save and exit from BIOS.
Apr 01, 2010 | Computers & Internet
It keeps shutting down and restarting, every two hours--why??
Turn off windows update
and disable all startup items from msconfig
restart the computer ..
if still problem is there
Reseat and swap your RAM chips
Mar 19, 2010 | Toshiba Satellite L355D-S7815 Notebook
Windows xp on acer aspire 4315 cannot shutdown normally
ARE YOU SAYING YOU SHUT DOWN WITH THE POWER BUTTON.GO TO START RUN AND SHUTDOWN OR RESTART THERE.RICHARDM69
Dec 05, 2008 | Acer Aspire 4315 Notebook
Computer shuts down with Flt. Sim 09
Hmm. Does the screen flash blue before it shuts down? And does it shut down or restart?
Mar 29, 2008 | Computers & Internet
No display
Dear hubult,
There is issue with u RAM because when u remove the RAM it starterd beep it means u r RAM slot is ok. the problem is with u RAM pls change the RAM and then check it and one more thing before u change the RAM do one thing take out the CMOS battery and then restart the system after restarting the system shut down the system and then reconect the CMOS battery and start the system.
Regards,
Bittu_8
Feb 15, 2008 | Intel Desktop Board D845BG (KD845BGPAK10)...
Ram upgradation
The system uses shared video memory, so it will always show less memory than actually installed.
It's a good machine, but needs all memory it can get for Vista.
Good luck
Dec 08, 2007 | Toshiba Satellite A135-S2266 Notebook
Computers & Internet Logo
702 people viewed this question
David Payne
David Payne
