Is the shut-off valve either to or from the booster pump open? Does the booster pump operate or just hum? Is the main system running?Is the shut-off valve either to or from the booster pump open? Does the booster pump operate or just hum? Is the main system running?
Check several things if these pool cleaners stop moving. Check the filter screen in the in-line filter and clean, if necessary. Clean the skimmer basket, pump basket, and pool filter. Check all of the hoses, connections, and swivels for leaks that could cause loss of water pressure. Make sure that your wheel RPM is between 28 and 32. Adjust your thrust if necessary to get RPM to that level.
Are you talking about the wall fitting..
