Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Machineflashinf f-05 machine stopped middle of cycle and is flashing f-05
  • Hotpoint Master
  • 19,396 Answers
F05 machine means "Pressure switch jammed"
Try first cutting power to the machine for two minutes, if that reset the code, then the problem was temporary.
If not :
Check if the machine drained, or if water is not being drained.
If drain system works .take off the the lid , locate the switch, it must have a small hose attached.
Remove the rubber hose attached to it, and unlock it by blowing into the hose.
If the water does not drain, this will also cause the pressure switch error.
In this case check the drain hose , and the drain pump.
Finally, ta faulty timer control board can cause the error, you test the control PCB if lid switch and drain system are OK.
Posted on Apr 01, 2009
Machine stopped in middle of cycle ,wash flashing something on screen, tried to restart wont't run water could it be out of level for it not to run water
It's probably flashing an error code. Write down the code and look it up in the owners manual or online to find out what the issue is.
Aug 17, 2014 | Samsung WF328AA Front Load Washer
Washer stops in middle of cycle and flashes error code f 05
F-5 Water temp sensor failure
If during the water heating step in the wash cycle, the water
temperature sensor (NTC) value is out of range, the "F/05" error code
will be displayed. Possible cause/proceedure:
1. Unplug washer or disconnect power.
2. Check the water temperature sensor.
Check connections to the water temperature sensor.
3. Check resistance of heating element, if present on this
model. (abnormal = infinity)
Nov 01, 2012 | Whirlpool Washing Machines
My Kenmore 110-46462501 washing machine stopped mid-cycle
Can you hear the pump running? It might be plugged or not running
Oct 20, 2017 | Kenmore HE2 Plus Front Load Washer
Amana nfw7200 washer stopped in middle of cycle and is flashing ''nd''
is it full of water? if so there is a drain problem and may have to clean out the pump
Aug 23, 2009 | Maytag NFW7200TW Front Load Washer
Machine runs for about 5 minutes on normal cycle than stops and flashes f 05. It works on other cycles
F-05 is the error problem for :Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed in between the running machine.
Check the Water Temperature Sensor, Heating Element and Element Relay and Check connections to the Sensor, Heating Element and Relay
in this case mostly the sensor needs replacement some times its only the case of sensor getting loose.
you can get new sensor from
www.repairclinic.com
thanks.
Jul 13, 2009 | Whirlpool Washing Machines
Cycle ctopped and is flashing f 05
F05 means pressure jammed on full.
Check pump for blockage, or filter if waher has one.
Please rate my solution.
Thanks.
Jun 21, 2009 | Hotpoint Ultima WF865 Front Load Washer
Flashing f - 05
Error f05 is a problem with the pressure system usually caused by a blockage. These are most commonly found in the pipe which is attached to the bottom of the drum.
Take off the access plate at the back of your machine and you can see it is secured by a large jubilee type clip.
Please be aware that there will be water in this pipe.
Hope this helps & thankyou for using Fixya.
Jan 24, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Control panel flashing F05 ?
F05 denotes pressure switch jammed on full, check pump and draining out.
If still no go, then call an engineer.
Dec 05, 2008 | Hotpoint Aquarius WD63 Front Load...
WF320P Water fills on wash cycle drum starts to rotate. After 30 seconds or so middle three red error lights flash and cycle stops.
Hi there swamib lets see if we can help you out. If the lights in the middle of the appliance flash led 1,2,3 that means there is a problem with the heater it is most likely it is open circuit replace this and it should solve the problem keep in touch noffie......
Apr 08, 2008 | Washing Machines
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
138 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
