Question about Tascam 2488 Portastudio Multitrack Recorder System
Sound of the recording after burnt to a cd is very low
My recordings, after burnt to a cd through the mixer, comes out very low sounding. Whilst I record from a piano i put the faders on just above the bottom line, because i only have a phones output in my piano, therefore i raise the faders so that i can hear myself play. Is there any way I could get a higher volume outcome? also does the monitor control knob have any effect on what the volume outcome will be?
    Problem Solver:
  • 12 Answers
Yes adjust the Input trims to around 75% of max. Then when you burn the CD, try to Master it at a level just below "clipping" thus will make your CD louder with out distorting them, digital distortion is horrible, its a scratching sound. My DP03 has a Normalize function for Mastering, its pretty great, but you must watch the bass levels. Also when recording do you run your keyboard straight to the unit? I suggest getting an Alesis or Yamaha 6 Channel Mixer,(or another brand, these are less than $200, and can be purchased through Musiciansfriend.com for around $100). They help immensely.
Posted on Aug 03, 2015
  • 4 Answers
Also,, what I did after cd- burning, is to put it on a computer, with NERO, and Burn it again...There is a volume button somewhere around that says it will boost up all the songs to one volume, which probably a standard..When I did my songs, if the levels peak on the Tascam, you'll get a very distorted sound...I dropped the slides down and burned at low volume, then turned around and Volumized all songs..It worked for me!!
Posted on Jan 10, 2011
    Novelist:
  • 91 Answers
Adjust your top knob which is called the gain, this will allow the incoming signal to be muchlouder depending on where you set it , the bottom fader is for playback volume and mixing and you should also a avolume control for your head set , follow also the recording instructions in your manual for optimal settings , there,s no reason that your recordings should come out with low volume other then your gain control being set to low , hope i was able to help , if i was please leave a nice rating ,sincerely glenn mayer
Posted on Mar 09, 2009
  • Glenn Mayer
    Glenn Mayer Jun 10, 2009
    turn up your gains and monitor it through the headphones,before you burn the cd ,make shure your levels are not peaking
Recorded my piano playing to CD. On playback, the volume is too low. Is it fixable?
you need a sound mixer software.can get a fee version if you look for one online. next time use a set of mic's and stuck them to the under side at the top of the piano the sound is better.
Oct 28, 2013 | Radio Communications
Recording levels are low
There's no record level adjustment on the Masterlink. Increase the output level of your mixer, or add a variable level preamplifier between the mixer and the Masterlink.
Or, use the level adjustment on the Masterlink once the recording has been done, and before you write it to CD, either with level control or DSP normalisation
May 23, 2013 | Alesis MasterLink ML-9600
How can i recoder from mixer
The CD recorder need to have a Line input usually in the form of RCA Left and Right. Then you need to connect the appropriate cable from the Mixers outputs (line output not from an amplifier for speakers) to the input of the CD recorder. If you have no line outputs then a headphone output will do in a pinch but might be dirty sound. Make sure to keep levels low as in CD recording once you hit O there is no more level like on tape. It will just truncate the data and might give a clipped sound output.
Jan 20, 2013 | Harman Kardon CDR2 2-Disc CD Recorder
I record but the sound is very very low.
If you are recording from a line-out coming from a headphone output from the TV try increasing the TV volume. (and check the signal is strong by testing with headphones).
If you need to still increase the recorded volume... open the Volume control mixer; open the properties for Recording; select an Advanced option and then Microphone boost
Jul 09, 2009 | Pinnacle Dazzle DVD Recorder
I plugged a mic to my dell laptop but it isnt working, do i need a sound card?
No, if you have a jack to plug the mic into you have a soundcard. However the mic is probably muted in the mixer software. Go to the control panel, left click on sounds and audio, then click on the advanced button; this should open the mixer in the play back mode, at the top left of the mixer go to options and select properties, a new page will come up with a radio button showing playback or recording, switch the radio button to the recording list and check everything in the checkboxes including the mic and press ok. A new mixer should come up with your recording deviced, from here you can set your microphone device volume.
Jul 01, 2009 | Computers & Internet
Recording Mixes from IDJ2 to my MAC
I don't know about MACs but I assume most computers are the same in their general anatomy when it comes to the sound system.
ie. Windows has a digital recording system built into the OS that allows you to plug an 1/8" patch cable into the "input" of the soundcard of the computer. Years ago I recorded several things from karaoke songs I sang to pre-recorded song I mixed from my DJ console. The volumes needed to tweeked to avoid sound distortion but it sounded so good I've used my recordings at gigs.
Feb 01, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Audio Recording Problems
try using the windows sound recorder to see if that records music? if it doesnt then you need to go into your sound recording properties and change it from mic to wave
Dec 02, 2008 | E-Mu 0404 Sound Card
Not able to record onto Adobe Audition 1.5
Sounds like you do not have your audio recording source set correctly.  If you're recording from a file on your computer or a CD via the CD-Rom drive of your computer, you need to probably set the recording to either "Wave" or "What you hear", one of the two.  The "What you hear" can be easiest, but then again, if any other sound comes accross your computer at the same time, you'll end up recording that as well, so it's best to stick to "wave" if you can... or make sure all Windows sounds are turned off (Audio settings ->Sounds ->Select "No Sounds" as the theme).
Oct 25, 2008 | Adobe Audition 1.5
Tascam CD-RW4U
Try adjusting the input level so the meter stays close to 0 when recording. It sounds like the levels are too hot.
Aug 04, 2008 | Tascam CD-RW4U CD Recorder
Recording not right
Check the recording buffer latency on your recording software. And so you know, you should max your ram out with that soundcard. or have everyone record there parts in as, 5 ins is alot for a machine to process, especially if youre recording to 1 track..brutal, and the final recording will be real muddy.
Keep me posted.
Oct 25, 2007 | Behringer (UCA202) Sound Card
Tascam 2488 Portastudio Multitrack Recorder System Logo
352 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
