Question about Remington Electric Pole Saw
I have a Remington Electric Pole Saw , the part that part that locks the pole in place , once it is extended is broken and I do not know where to get a replacement. Other than that the Saw works perfectly.
5 Suggested Answers
SOURCE: what type of oil do I use for a Remington Electric Pole Saw?
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
Posted on May 25, 2009
  • 188 Answers
SOURCE: pole saw lock broken when i extend handle need new lock
I just contacted Master Parts and they have that part available (121560-01). You ca contact them toll free at 800-446-1446 or you can find them online at www.masterparts.net. I hope this helps!
Posted on Jul 20, 2009
VtToolMan
  • 704 Answers
SOURCE: where can I find a replacement locking nut for the
Without the model number, I can't provide you with the part. However, you can go to masterparts.net and click on the Remington chain saw link and with your model number, get a line drawing and list of all available repair parts and pricing.
They have almost all the parts for even most discontinued Remington chain and pole saws and have a toll free number you can call, once you have your model number to provide them with. 1-866-672-6040
Hope this helps and best regards!
Posted on Jul 31, 2009
dontbother10
  • 2220 Answers
SOURCE: The plastic Pole Lock (Thumb Latch)on my Remington
RemingtonPower is no longer in production, The "Coupling Nut" was replaced by a "Thumb Latch" neither of these nor the entire pole assembly are available.
You might try this (no promises).
http://store.poolcenter.com/shared/StoreFront/product_detail.asp?RowID=167966&CS=poolcenter&All
Someone recommended using a hose clamp in place of the nut.
I think these are band-aids and eventually you will need a part that cannot be found.
We rarely get inquiries for McCulloch or Poulan electric units. Might be worth a look.
If you care to try on your own start here:
Remington.com
http://shoppingcart.msservicecompany.com/Default.aspx
  • Type "YourModelNumber" into the "Search for your unit by Model:" window, then click search.
  • Click the “YourModelNumber” - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Diagram" link.
  • Type "YourPartNumber" into the “Search for your parts by Part #:” window, then click search.
Sometimes you can find NLA parts (use part number for above) offered here:
Master Distributors
http://www.masterparts.net/remingtonelectricchainsaw.html
If you have more questions or need additional help please reply below and I will get back to you. and Good Luck. HTH
Lou
Thank you for using FixYa.
Posted on Apr 18, 2010
  • 4088 Answers
SOURCE: Am I wise to purchase a Remington Pole Saw or
Remington Saws have ceased operations and, unless you like to make your own replacement parts, they are prone to failure. The gearbox is sealed and the motor brushes are not available anywhere. Look elsewhere!
Posted on May 11, 2010
How do you attach the chainsaw to the pole?
You simply mount the saw between the two metal plates.
There are two screws holding the plates together.
Look in the owners manual and it will guide you how to attach the saw.
Once the saw is attached, plug in the power cable that is on the end of the pole. One word of advice....there is a large locking collar ring that enables the two poles to extend and lock together. There has been numerous reports that the locking collar ring splits due to overexersion. You can add a stainless worm clamp (similar to a radiator hose clamp) around the rind and tighten it securely. Be sure it is a heavy duty wide clamp. This will help to keep the ring from splitting under pressure.
Jun 25, 2014 | Remington Electric Pole Saw
I need a Coupling Nut for my electric pole saw
lots of luck there, if you have tried Remington, with no luck may i suggest a automotive hose clamp and a piece of inter tube.
Nov 07, 2013 | Remington Electric Pole Saw
The plastic female part of my Remington telescoping pole saw coupling nut split and won't hold the extension pole in place. I'm trying to find a replacement or a fix.
Okay here is the Fix for the Remington Pole for the remington saw. Lowes has a plumbing part that will work as I just purchased it 12/2010 The part is by GENOA and its a 3/4" pvc Union and the threads match. Its Lowes part 98996 and its < $6.00
Oct 13, 2010 | Remington Electric Pole Saw
Am I wise to purchase a Remington Pole Saw or should look for another manufacturer? Which Remington Pole Saw would you purchase: a. 18V Cordless b. 10" Electric
May 11, 2010 | Remington Electric Pole Saw
Remington pole saw
Problem is most likely in the trigger switch on pole. Bypass switch and test bu plugging lamp into power cord coming from pole
Jan 07, 2010 | Remington Electric Pole Saw
Does my remington chain saw model #m15014AS go with the remington ext.pole model #rps96
No, the largest electric pole chain saw that can be attached to a pole with the Remington Pole Saw kit, is a 10" saw.
You can go to Master Distributors to find out more detailed info about your situation and speak with one of their reps.
http://www.remingtonchainsaw.com/
Hope you found this very helpful, best regards!
Aug 07, 2009 | Remington Electric Chain Saw
Need locking latch for Remington Electric Chain saw
You've got the one version of the Remington Pole Chain saws that doesn't have a separate parts breakdown online.
However, here's a owners manual for your pole saw and a parts breakdown that can be used for most replacement parts, as the RPS-96 is a similar version of your model.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/RPS96/RPS96_OM.pdf
http://shoppingcart.msservicecompany.com/msservice_net/product_files/RPS96/RPS96_BD.pdf
You might want to contact the factory to verify that the parts are the right ones before ordering them by calling 1-866-672-6040
Hope you find this very helpful and best regards!
Aug 07, 2009 | Garden
Where can I find a replacement locking nut for the pole? For 10" Remington pole saw
Jul 31, 2009 | Remington Electric Pole Saw
Pole saw lock broken when i extend handle need new lock
Jul 20, 2009 | Remington Polesaw Wizard
I have the model 108526-01 Remington pole saw which has the round pole with a plastic compression nut (which recently broke). Can I buy the newer octagonal pole and if so, does it use the same saw mounting...
I have the sollution, had the same problem with the broken compression nut. Just use two hose clamps, one to hold the pole extended and the other clamps around compression base. Its a cheap easy fix and it work great fo me. The Real Mr.Fixit
Apr 03, 2009 | Remington Electric Pole Saw
Remington Electric Pole Saw Logo
158 people viewed this question
Top Remington Garden Experts
EugenesDIYDen
EugenesDIYDen
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
