Question about Toshiba Satellite A215-S7422 Notebook
Need buying description for audio/video cables from DVD in Toshiba Satellite laptop to new Samsung flat screen HD TV. guntherd20
  • 564 Answers
You can purchase DVI cable.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Posted on Mar 09, 2009
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
I have a toshiba satellite p755, it use to be able to hook up to my HD TV with the HDMI chord but now its not connecting..whats the problem?
Make sure all connections Power ,HDMI and any other connecting leads have secure dust free connections also check each lead for any kinks / bends .
Connecting a Toshiba Satellite Laptop to a TV is an ideal way to enjoy videos, photos and other media on the laptop on a much larger screen.
Satellite Laptops can be connected to TVs using VGA, S-Video and even HDMI, though the TV has to have compatible inputs as well.
Connect the RGB cable or S-video cable to an open input on the TV.
Depending on the type of TV, it may or may not have a RGB input.
S-video may have to be used instead.
Connect the 1/4 inch to RCA Y-cable into the TV using the same input as the VGA or S-video cable.
Connect the other end of the VGA or S-video cable and the audio cable into the laptop.
The video ports are on the sides of the laptop.
The audio cable should go into the headphone jack of the laptop.
http://www.svideo.com/compaq1700.html
Aug 09, 2013 | Computers & Internet
I am trying to hook my toshiba HDMI DVD player to the television with a video chord and two audio chords. It's not working. Help
You wrote in your problem description that it is an HDMI DVD player - if your TV has an HDMI input (most flat panel TVs do) then you should be using an HDMI cable. HDMI carries both the video and the audio signals from the DVD player to the TV so that is the only cable you will need. They can be expensive so buy the length of cable you need and not too much more. Also, stay away from Monster brand cables, they are a rip off.
Mar 15, 2011 | Televison & Video
I have a Toshiba Satellite L505D-S5983 Laptop with Windows 7 and a Philips HDTV flat screen TV. I want to run a cable from the laptop to the TV so I can watch online shows on my TV screen. My TV has an...
The price difference in the cables are what type of metal wire that is in it. One might have copper or even gold plated and the lower price one might have some low end metal. I have not seen any difference. Yes, all you have to do is plug it in and Windows 7 will recognize your TV. You might want to go into the Control Panel and open Sounds and make sure you have the audio turned on for your HDMI connection. Your laptop screen and the TV will be displaying the same.
Sep 04, 2010 | Toshiba Satellite L505DS5983 Notebook
Direct TV satellite to TV connection issue
hi cable from the wall into the box then a cable from the box into the tv or hdmi cable from the box to the tv thanks
shaun
Jun 13, 2017 | Toshiba Televison & Video
Recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Jan 17, 2009 | Toshiba DVR610 DVD Recorder/VCR
S-video Problems
After you plug S-video connector to your laptop, and hold Fn and press F5, you will see from screen, which ask you what video out put you want, you should choose TV, and you will can watch your DVD on TV screen, but you have to using audio output from your laptop too..if you want to use TV speakers or other speakers you need buy some thing else.
Nov 12, 2008 | Toshiba Satellite A55 Tecra Notebook
Hooking up DVC/VCR to HD cable box/TV
Hi Seve.
Not sure what is meant by 'HD cable box'.
If you mean a DSD (Digital Satellite Decoder), then the built-in firmware prevents recording (of composite video signal).
In our country the SP requires that you buy a dedicated 'Explora' decoder which allows recording.
HD cable technology may have introduced similar anti-piracy measures.
{reminder to me: Google "HD cable TV" :)
Oct 06, 2017 | Televison & Video
Connecting a samsung dvd-vr to TV with cable & rf modulator
my coaxial cable hook up is broken from the plasma. Can i fix it?
Jun 15, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
Cant get sound from speakers
That is because you didn't have the audio input connection right.
1. HDMI cable going from the Samsung tx72 output to Your Samsung TV HDMI input 2.
2. Non HD directv box Left and right audio output should be connected directly to the Samsung DVD receiver under Satellite input.Select"Satellite"for the sound from your Samsung tx72.You are good to go!
Joe
Feb 03, 2008 | Audio Players & Recorders
Toshiba Satellite A215-S7422 Notebook Logo
37 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
