Question about Sony Handycam HDR-HC1E HDV Digital Camcorder
My Sony HDR HC1 will not power on.
The screen is completely black with a white flash of light every 5 seconds. I have tried it with a fully charged battery and the electrical cord.
  • 1,894 Answers
This is some problem with the internal software or hardware. nohting to do with externals. check it out by doing a hard reset.
Posted on Mar 09, 2009
HDR-HC1 flashes when recording outside only but not when recording inside. the LCD screen blinks light & dark. thanks john
This is a fault in the electronic aperture control and will probably cost you $800 if you have it repaired by Sony. However, There are many qualified independent repair shops that will do the repair at a discounted price.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have it repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on
Oct 04, 2011 | Sony HDR-HC1 Mini DV Digital Camcorder
Camera LCD screen
Perform the following troubleshooting steps and check whether it helps;
1. Check whether the issue persists with all the tapes. If the issue persists with a particular tape, the issue is with the tape. change the tape. 2. Check whether the battery is fully charged, 3. If the batteruy is nit fully charged, connect the Camcorder to the wall outlet using the supplied AC adaptor. 4. Then, reset the Camcorder by pressing the RESET button using a sharp-pojnted object while it is turned ON.
5. If the issue still persists, remove the battery pacjk and disconnect the Camcoredr from the wall outlet; then slide the power switch to ON position for at least 30 seconds. Then reconnect the AC adaptor to the Camcorer after 1 minute.
If the issue still persists, service may be requuired. Please cointact ur Camcorder manufacturer to get it serviced.
Oct 15, 2009 | Sony Handycam HDR-HC1E HDV Digital...
The lcd screen is almost black/ very dark, but i still see that it works. it looks like the light is out. sony hdr hc1
The LCD screen may be turned OFF. To turn the LCD backlight off or on, press and hold the DISPLAY/BATT INFO button for a few seconds. After the backlight has turned off or on, release the button.
Aug 07, 2009 | Sony Handycam HDR-HC1E HDV Digital...
I'm having the same problem
find nearest trash can and toss in sony CCD F-401 and all accessories and accoutrements..........problem solved.....worked for me!!!!
Jun 15, 2009 | Sony HDR-HC1 Mini DV Digital Camcorder
How do you fix the touch screen on my hdv 1080i mini dv,
touchscreen problem on the HDR-HC1 is usually caused by a broken flex cable. service manual is a must-have; it illustrates the correct disassembly and replacement procedures for the cables.
Jun 05, 2009 | Sony HDR-HC1 Mini DV Digital Camcorder
With camera powered on try depressing the "Reset" button with a pencil/ball point pen. Then try again it may help.
Jan 17, 2009 | Sony HDR-HC1 Mini DV Digital Camcorder
HDR-HC1 power keeps cycling
I had this exact problem, and the cycling would stop after about 30 sec. and then function properly. I believe a circuit was confused, mainly because I used an older battery and let it run out till the batt was dead - accidently - and when I put in a fresh batt, it no longer cycled and works perfectly to this day.
Now if I can get my computer to recognize the camera via firewire, I'd be golden.
Mar 07, 2007 | Sony HDR-HC1 Mini DV Digital Camcorder
Sony Handycam HDR-HC1E HDV Digital Camcorder Logo
244 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
