Question about Zoom Music
My zoom 505 2 distortion pedal for my guitar will not function with batteries and the ac adapter slot is loose in the back, please help
    Novelist:
  • 157 Answers
I have had this same problem with mine, since the adapter jack is loose it's probably broken loose from the circuit board inside. I had to carefully dis-assemble and re-solder the adapter jack back to the circuit board. This is un-fortunately a weak point on some of Zoom's pedals, when you or if you get someone who is good at soldering to do it for you ask them to beef the solder joints up a little to help keep it from coming loose again. I re-did mine and I've never had another problem with it.
Posted on Aug 28, 2009
How do we get to replace a transistor 2933BD
bro
did u know what is the solution for replace the 2933b? foirm my zoom 505 2
Jun 28, 2014 | Zoom G1x Guitar Multi Effects Pedal with...
Noise
This seems to be a battery problem unless you use an AC adapter. If it does it on AC, I would check my guitar cord and power supply. The wrong power supply could do that and a bad guitar cord can as well. If you use a speaker cable as an instrument cable, it could do the same.
Mar 26, 2014 | Zoom G2 MultiEffects Guitar Pedal
It blinks with "be" and turns off
It may be "but" that you're seeing, which indicates the batteries are low. Use the AC adapter made just for this model only, and the guitar needs to be plugged in to turn the unit on. A full manual for this Zoom model can be found here:
https://www.zoom-na.com/sites/default/files/products/downloads/pdfs/E_G1_G1X_3.pdf
Dec 01, 2013 | Zoom Samson Technology Zoom G1XN Multi...
My zoom g1x displays BT even though i don't use any batteries for it
You need to replace the power resistor R54:
http://gisywall.blogspot.it/2016/01/zoom-g1xn-continuously-shows-bt-on.html
Sep 28, 2012 | Samson ZOOM G1x Guitar Effects Pedal
My DD3 pedal doesn't work. Checked the battery and the adapter. The light won't go on it will only light momentarily when I click through the modes. Any help would be appreciated. Greg
Check all connections including the battery clip if you use a battery, and the adapter jack if you use the AC adapter. Also check you guitar cable connections as the pedal turns itself off if the guitar plugs have a loose connection. Make sure the guitar jacks on the sides are tight and don't need tightening. Any of those issues could cause the pedal to operate sporadically or not at all.
It could also be and IC problem internally on the pedal's circuit board, but before you open anything, check all the connections non electrical issues can occur more often on pedals.
Feb 19, 2011 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
The zoom g1x is dead. no power. tried adapter from my other zoom pedal but nothing. opened it up and everything seems in tact. was working fine saturday, dead sunday. only one month old.
The first thing i would check is the ac adapter .Make sure you are getting the correct voltage from the adapter.If you know how to use a voltmeter or know someone that has a volt meter,check it with it unplugged from the guitar pedal,most of these have a voltage range from 9 to 12 volts dc.you could also take it to your local radio shack or local repair shop and they will be glad to check it for you for free.after you confirm the adapter and it is ok then the next thing you will check is the input jack assy on the pedal,input jack assy are soldered onto the board at the factory,these jacks ,no matter what it is are famous for cracked solder joints where the pins of the jack go into the board because of stress delivered to it during plug ins and plug outs.if you dont know how to use a sldering gun or dont want to you will have to take it it to your local repair shop-cost should be around 15.00, 20.00 tops,make sure that your guitar cables are good,check the 9volt battery inside the unit if it takes one,if its dead that could be your problem,if all above fails i would send it back to the factory or wherever you bought it.,good luck been playing for about 30 years myself,rock on
Jan 24, 2011 | Zoom G1x Guitar Multi Effects Pedal with...
I have a Zoom 9000 Guitar effects processor, and although I have its original adapter, and although its red light flashes and power is on after plugging in everything, I could not get any sound from my...
I'm a Zoom 9000 owner (since '93, I think) Did you try batteries only? Are you plugging the guitar into the "in / power" jack and not mistakenly using another jack? When you plug in the guitar, in to the Zoom 9000 does the window come on with the settings shown? Sorry, I know some of these are obvious but always the chance of us being human. If all that seems fine, then I would read though a manual to see if maybe it is a setting problem, i.e., sound somehow got inadvertently turned off. If you don't have one, an internet search will lead you to one. Sorry, wish I knew more.
Oct 14, 2010 | Zoom A2 Acoustic Effects Pedal
Will this amp have metal distortion if i add a distortion pedal
The amp can accept most anything you can get out of a distortion pedal. If you play it too loud you can damage any amp.
I would HIGHLY recommend you either take your amp to the store where you are buying your pedal and try it with your guitar before buying.
ALSO don't forget to get a power adapter as the pedals "eat: batteries.
May 02, 2010 | Fender Frontman 65R 65W 1x12 Guitar Combo...
My MT-2 wont distort my guitar.
A few things to try....
Usually the adapter will over ride the battery when used.
1) Make sure your 1/4" cables are working properly without the pedal "in-line".
2) Take out battery, and use just the adapter only. Make sure it is the correct and proper adapter that works with Boss. Usually the PSA-120. If you are not using a Boss Adapter, make sure yours is a direct replacement with same specifications. 9V/200mA. And "tip negative". DO NOT use Radio Shack stuff, nothing against them, but there adapters just don't mix well with Boss products and the like.
2) Try just the battery, no AC adapter. Remember to unplug the input when not in use. Saves battery.
Basic rule of thumb...when using correct AC adapters for all your pedals all the time, and all sounds good, then take out the batteries.
If you still experience problems, it would be an internal IC chip most likely. From there post another question maybe.
Apr 01, 2010 | Boss Mt 2 Metal Zone Effects Pedal
Music Logo
450 people viewed this question
Top Zoom Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Barry Webster
Level 1 Expert
Are you a Zoom Music Expert? Answer questions, earn points and help others
