Question about Sony DSC-T7 Digital Camera
Sony DSC T7 'Access' freeze when switch on camera
I have a Sony DSC T7 digital camera. All of a sudden, when I switch on my camera (open cover or switch on button) I get the 'access' wording on my screen, and that's it. Nothing change if I switch to 'preview' mode or 'recording' mode. I've taken out the memory card, put it back again - nothing. Even if I connect via USB, my pc does not pick up the memory card. How can I fix this?
Try getting a new memory card
Posted on Mar 15, 2009
I LOST MYMANUAIS FOR MY DSC T7 DIGITAL CAMERA HOW CAN I ORDER ONE.
You can download the manual and more from the manufacturer's web site at
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCT7#
Aug 06, 2011 | Sony DSC-T7 Digital Camera
Re Sony Cyber-shot DSC-T7/S Sliding lense cover wont travel down far enough to clear the lense. Message on screen says --lense cover closed Sydney Sony repair centre says discard for new. Seems a...
Hi your camera is very simply in mechanically. It may has loosen screws go around and stuck inside. If you are careful, you can try on open and look for the piece. If you are willing to, then let me know. Thanks and best regard!
May 25, 2011 | Sony Cyber-Shot DSC-T1 Digital Camera
I have a Sony Cyber-shot DSC-T7 Digital Camera how can I reset it
To reset camera follow below procedure:
Press MENU, select SETUP, select SETUP1 and select INITIALIZE and press OK to reset DSC-T7 camera.
Hope this info will help you.
Thanks.
May 22, 2010 | Sony DSC-T7 Digital Camera
Sony Digital Camera model DSC-T7, displays error message "C:13:01" ?
this problum is related with your memory stick please formate the memory stick & then try if the problum not remove please chang new one
Apr 24, 2010 | Sony DSC-T7 Digital Camera
Sony cybershot dsc - t7. the display says ''lens cover closed''
It appears that you have already tried what I'd have suggested as a last resort. Apart from cleaning the contacts and removing the battery for 15 minutes there is not much that can be done.
In my opinion it is better to purchase new camera than to spend so much on this one. Note that sony may also charge you a checking fee if you decide to send the camera in hope for less costly repair than they estimated.
And yes, it would be fruitless to dismantle the camera if you are not qualified for this stuff. There are no user serviceable parts inside and also there are timed mechanical switches which can be difficult to reassemble without a proper schematic.
PS. Please do not use Vodka for cleaning electronic components as it contains small amount of moisture. Use Isopropyl alcohol.
Nov 28, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Lcd screen of my dsc-t7
You can either buy one off ebay, or send the camera in to sony and they will fix it for $50
Jun 22, 2009 | Sony DSC-T7 Digital Camera
How to Remove the Lens Cover on a Sony DSC-T7
It is only six screws, and you have to GENTLY wiggly the front cover off....Start at the bottom, and wiggle side to side to get it unattached at the top of the panel. I just got mine off. I'm having black screen problems....
Jul 17, 2007 | Sony DSC-T7 Digital Camera
Will not charge battery
Please contact the nearest Authorized Sony Service. If you need more info please advice. Arpi
Feb 16, 2007 | Sony DSC-T7 Digital Camera
Lens Cover Closed
the switch inside that activates the camera is probably loose, or worse, broken.
Sep 09, 2006 | Sony DSC-T7 Digital Camera
Sony DSC-T7 Digital Camera Logo
209 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
