Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Thumping Noise I have a frigidaire top load washer that is almost 2 years old. It makes a thumping noise during agitate and spin cycle it was also leaking some water out of the bottom. any Ideas?
    Guru:
  • 1,894 Answers
It must be due to the damaged belt inside the motor. check it out.
thank you
Posted on Mar 09, 2009
Washer squeaks during agitation, both wash and rinse. also makes thumping sound for few seconds after spin cycle stops.
Hello Chris, thank you for your post!
I see that the washer on your Frigidaire laundry center is squealing during agitation. This noise could be coming from the motor or transmission and you may need to have the washer disassembled to locate which component may be causing the issue. For proper disassembly you may need to seek assistance from a professional technician. A technician will have the appropriate tools needed for complete disassembly of the washer without causing personal injury or harm to the laundry center. Hopefully this information is helpful towards your repair. -Matt
Apr 20, 2016 | Frigidaire fex831cs stacked washer&dryer...
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
I have a 2012 top loading frigidaire gallery washer. It recently started making a loud thumping noise during the wash cycle. When it spins out it smells like burnt rubber. Any ideas? Thanks
There is a rubber belt between the motor and the rotating cylinder.
If it is frayed, then part of the belt is hitting something during the "wash" cycle, and rubbing much faster during the "spin" cycle.
Replace the belt.
Aug 27, 2015 | Frigidaire Washing Machines
The washing machine makes a lot thumping noise during the drying cycle. Sounds like it is bout to take off. A lot of rubbing during the wash cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Dec 12, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Very noisy and loud vibrations on spin cycle of Frigidaire FTF2140FS front load washing machine
Is it just during the spin cycle that it machine is noisy or the noise is less during the wash cycle? Also is the noise a thumping type of noise or is it more of a whining or steady noise? If is a whining noise, it probally means that water has seeped past the seal and corroded the bearing of the washer. The noise is the failing bearing.
Jun 30, 2010 | Frigidaire GLTF2940ES Front Load Washer
Makes loud noise when on spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jan 09, 2010 | Amana 3.2 cu. ft. Top-Load Washer
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
Thumping/knocking/rattles during wash agitation cycle
Mine is doing the same thing. I opened it up to see what was happening and it was the drive belt tension arm bumping around. Soon, the belt started slipping during the spin cycle. Now it won't spin and the belt starts to smolder from the friction of the drive motor. If you haven't checked your belt, that's a good place to start.
Jun 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washer makes loud thumping after finished spin cycle
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
133 people viewed this question
Sal De
fordexpert
Robert Rankin
