Question about Sharp AL-1641CS Laser Digital Copier
Copier flashing P when after trying to copy
My copier has a P flashing after I try to copy.
  • 4 Answers
Make sure that the tray has paper in it and that the copier is using that tray(there should be a light for the tray selected) . If it is set to use the manual bypass tray and there is no paper it will give "P" in display.use tray select button to select tray with paper in it.If trays have paper and still gives "P" try to clean feed rollers ..
Posted on Mar 09, 2009
Blue center light flashing, won't copy from any computer
So Sandra, it will make copies but does not print from any computer. Have you installed print drivers on the network? Can you ping the copier?, any resent changes to the network? Check the network connection at the copier, green light flashing/orange lights flashing? Can you print a doc. or a pdf., or email or web page try different programs? Check the network setting at the copier, go to admin setting default pw 12345678.
May 12, 2015 | Konica Minolta bizhub C250 All-In-One...
We are trying to make copies and there was a light flashing and it said 1L and we are unable to make copies the copier has been reset and the toner and drum have been replaced already and i have also...
I have a tip posted here at Fixya that covers the Sharp AL Series Copier L1 code.
Here is the link:
http://www.fixya.com/support/r4378514-sharp_al_series_copier_l1_l_1_error_code
If it helps you with your L1 code then please return here and provide some feedback.
Thanks,
WheatlandServices
Dec 16, 2010 | Sharp AL 1631 Copier
Copier is Canon PC 720 Copier turns on, but makes
You said you unplugged your copier, did you unplug it for 10 to 15 minutes before plugging it back in, plug it into a differed
outlet that you know works and plug it directly into a wall outlet instead of a power strip. Check to see if your copier reaches stand-by mode then make a test sheet.
If this does not work then you have probably have an internal processing component which requires attention.
Apr 02, 2017 | Koutech Systems PC720 (IO-PC720) (IOPC720)...
The copier is flashing L and 1 and won't function
Hello sir; try to make a copy without cover then you may easy to watch the mirrow is they moving ,then you can easy to find where does it cause the problem.
Jun 04, 2009 | Sharp AL-1642CS Copier
Sharp al-1631 copier wont copy
It probably the toner cartrisge is empty or if there's an error code H4, the heater lamp is spoiled
Apr 02, 2009 | Sharp AL 1631 Copier
Toner error message on copy machine
Is "CH" steady or flashing? If it's steady, the door is not shut properly.
If it's flashing, the machine doesn't detect the presence of the toner cartridge (defective toner cartridge). Try another toner cartridge (an empty cartridge will do).
To get the blue handle to stay locked sometimes takes fiddling with it when the cartridge is in.
Dec 07, 2008 | Sharp AL 800 Copier
NP6412 Canon Copier
No, The copier should try to make a copy and try to feed a piece of paper through the copier. If it does this and continues to run for a couple of minutes it will either give you a add toner light or flash an error code of what problem the copier may have. If it powers up and you can't change the copy count then the switches in the control panel PCB maybe bad. The last time I checked on the price of a Canon control panel PCB it was less than $40.00 US. Good Luck.
Oct 16, 2008 | Canon NP 6551 Black and White Copier
Trouble with my canon copier ir 2870
E000602-0113 means that the hard drive is having problems booting up. You may try to remove the boot chip and clean the contacts with rubbing alcahol and reinstall it and turn the copier back on. Most likely you will need to replace the hard drive or try to re-flash the hard drive.
Mar 13, 2008 | Office Equipment & Supplies
Sharp AL-1641CS Laser Digital Copier Logo
110 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
