Question about HP PSC 1350 All-In-One Thermal Printer
It says cartride problems the cartridges are in but it wnt work
  • ZOCCO Mar 23, 2009
    I have an HP psc1350 all in one printer. I cahnged both cartridges with the proper replacements ( #56 & #57 ) and now get an error message saying " check print cartridge ". I've tried taking them out again and making sure I put them back correctly. I've tried un plugging everything and then plugging it back in but I still have the error message. What's next???????????
  • 564 Answers
  1. Disconnect any USB cables attached to the printer and remove any memory cards from drive bay.
  2. Restart the computer.
  3. Remove any paper from the paper tray.
  4. Unlock the ink cartridge locking clips.
  5. Remove all printer ink cartridges.
  6. Lock down the ink cartridge locking clips.
  7. Close the main printer door.
  8. Turn off the printer using the power button and wait for the printer to
    shut down before proceeding to step 9.
  9. Unplug the power from the back of the printer.
  10. Unplug the power adapter from the wall outlet.
  11. Remove the rear access door.
  12. Locate the clutch inside the printer.
    The clutch is located in the same place as pictured above in Figure 1, however, you must access it from the left, just above the paper output tray.
  13. Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
  14. Release the clutch and roll the wheels up two more rotations.
  15. Locate and then roll the internal rollers in an upward direction until a clicking sound is heard.
  16. Reinstall and lock the rear access door.
  17. Connect the power adapter to a wall outlet.
  18. Reconnect the power cable to the printer.
  19. Turn the printer on.
  20. Re-insert the paper into the input tray.
  21. Wait for the appropriate missing cartridge error to verify that the printer recognizes this error.
  22. Re-insert one ink cartridge only, to minimize confusion in case one of the cartridges is defective, and print an internal test page.
  23. If no errors are found, insert the other ink cartridge(s) and ensure that they are functioning by performing internal test pages or calibration pages. If an error occurs due to a defective cartridge, perform the appropriate steps for Resolving Ink Cartridge Rejections.
  24. After returning to the main Windows screen, reconnect the USB cable to the computer then to the printer.
  25. Test for printer functionality.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Posted on Mar 09, 2009
Brother mfc-7340 tooner life end
1) Pull out the cartridge and look on the right side of the it. You will see a small hole that has a glass like window in side (round window).
2) Turn off MFC-7420
3) Cover the hole on cartridge with a duct or a piece of paper. Basically block.
4) Replace the cartride back in the printer and turn on the printer.
5) The message should be gone and you should be able to use the copier functionality.
It worked perfectly.
May 30, 2011 | Office Equipment & Supplies
Error 5...ink cartridge is not recognized after refilling
Clean the contact point of the cartridge to the printer before placing it, then **** some ink in the cartride by a cyringe to lessen the level of ink inside the cartridge. full ink cartridges encounter this error because the absorver inside the cartride overflows.
Mar 28, 2011 | Office Equipment & Supplies
Why it can't print?
It won't print if your ink cartridge is empty. Check the black and white and also the color cartrides by doing the following:
1. Slide your hand underneath the front cover and open up the case.
2. Find your ink cartrides usually located on the left on the inside of the casing.
3. Gently pull up (usually) on the cartridge and take it out and shake it. You will know if it is empty or full when you shake it. If the color is full but the black and white is out that is probably the problem. Many printers won't work if the black and white cartridge is empty because that's usually the primary color.
4. Go to Walgreen's or a similiar store and purchase a new cartridge and then just reverse the steps putting it back in. Make sure you take note where each cartride is located when taking them out and put them in their correct position when you put them back in.
This should solve your problem and you should be printing again in no time flat!
Dec 22, 2010 | Epson Stylus Photo R390 InkJet Printer
Receive msg: "Print Cartridge(s) missing or not detected
i thing u have problem with your cartride try to buy orgnal cartride and try if not then you have to go to work shop becoz u r cartride slot if not working properly
Apr 17, 2010 | HP Photosmart C6180 All-In-One InkJet...
Minolta 2530DL cartride reset problem
Take the cartridge to Cartridge World they will fix the issue they have fixed it for me in the past. They really know what they are doing just bring the cartridge to them and they will help you
Mar 29, 2009 | Minolta magicolor 2350 Laser Printer
My hp photosmart 2575 says 'ink cartridge problem, remove and check cartridge on right. Refer to printer documentation
open the front cover the cartriges will come in the centre position where you can remove the cartridges check which cartridge is on your right side remove and clean the brown dotted circuit on both the printer and cartridge with the tissue paper .insert it back in the proper position and then check if the same problem then remove and replace the cartride printer will work properly.thanks
Aug 14, 2008 | HP Office Equipment & Supplies
Problem withColour Cartridge 854 for HP Photomart c4188
it could be the cartridge wasnt properly in place.
turn off unit and manually remove the cartridge again ensure that you install correctly.
Aug 06, 2008 | HP Photosmart C4180 All-In-One InkJet...
HP PSC 750 PROBLEM
Had the same problem. Cleaned the copper-colored "contacts" on the actual printer. Where the printer and the cartridge touch ... you will see them when you take the cartridge out. Hope that helps.
Feb 17, 2008 | HP PSC 750 All-In-One InkJet Printer
HP PSC 1350 All-In-One Thermal Printer Logo
220 people viewed this question
Ben Johnson
