During the fill cycle, water dribbles out on the floor. The amount is now increasing. It is NOT the hoses which have recently been replaced. It is a maytag.
My Hoover 7700l ...on "fill" cycle, the water dribbles in. Takes hours to fill so we use buckets to reach the required level.
Tried: Swapping cold and hot water inlet hoses, making sure that dial is in "hot". This solved the problem for filling, BUT when "rinse cycle appoars, it's back to the dribble again.
the "HF" code is initiated when the water turbine(counter) sees an
excess amount of water to fill the machine to the prescribed level-
many things can cause this problem,however simply throwing components
at the machine will not necessarily fix it. here is what i have run
across on at least 3 occasions; the w/l switch tubing(air tube) is
supported by a small retainer that establishes the tubes routing toward
the side of the machine near the cabinet- if the hose falls out of this
retainer,it is allowed to dangle in the danger zone near the spinning
pulley/belt- the belt contacts the hose and wears a thin spot in the
tube just enough the machine to fill and begin to wash initially, but
air escapes slowly and machine goes back into fill mode,eventually the
water counter sends feedback to the controller that it has filled with
an axcessive amount of water and defaults to the "HF" condition. the
cure is simple-replace the rubber tube and secure it along the side of
the machine away from the moving components. its certainly worth
checking out.
REGARDS
IVERSH
A VERY HELPFUL RATING IS APPRECIATED FOR ANSWERING YOUR QUERY....
Washing machines need to be drained into a standpipe. This is a drain that is about 36" off the floor. The drain line on your washer will work fine if you have it installed in a standpipe. by putting it down into a floor drain, you're not going to allow the machine to fill. The stand pipe will allow your machine to fill and still pump the water out during spin cycle.
Make sure there's a drain hose with a hook on the top. k
You may want to double check you have the inlet hoses around the correct way as if you have the cold hose going to the hot valve it would cause this fault. If the machine doesnt spin properly also it could be a faulty Out of balance switch. cheers.
The drain hose needs to be lifted above the high fill level in washer.The easiest way to fix this is take the drain hose (if your drain hose starts from the bottom of machine and goes up)tie or strap it to the back of the washer so it cant sag or drop down and start syphoning the water.Remember the washer will drain out the water if the drain hose is lower than the amount of water in the tub.Thats why your making sure by tieing the drain hose to the highest point before it makes it way to the drain .
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water
when is filling only, check the following:
1.Fill
hoses
2.The water mixing valve 3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the
following: 1.The pump 2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the
following: 1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses 5.The stem & seal
What is your model number?
