Question about Sony Cameras
My problem was not answered due to an error in the transmission .
    Guru:
  • 1,894 Answers
Can you explain me the situation?? where you in chat with a expert and you lost the expert due to loss in transmission?? what happened actually?
Posted on Mar 09, 2009
2000 civic ex D4 light flashing
Maintenance Warning light. The Transmission Control Module would trigger the D4 light to blink to indicate an error has been detected in the control system.
When the speedometers intermittently fails due to a faulty Vehicle Speed Sensor, a trouble code would be stored in the TCM.
The VSS is failing and replacement is due. Scanned the module in order to know specifica fault code.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 13, 2012 | Cars & Trucks
I am getting this error code that "Solenoid 1 or
Those solenoids are supposed to move that valves inside the transmission, they are used to change the gears. If they are mechanically faulty then they are jammed.
This means that the valve assembly has been damaged beyond repair either by a mechanical shock (you hit something and the assembly broke) or you used the wrong transmission oil.
The valve assembly will have to be completely replaced. The transmission will have to be dismantled for that.
Jul 12, 2011 | BMW X7 Series Cars & Trucks
DMA driver error CRC error G sonyDVD RW AD 72605
CRC errors can occur due to many different types of problems. Some of these problems are:
  1. Damage to file during the transmission process.
  2. A problem occurred when the file was being sent.
  3. Problems with the device that is accessing or opening the file.
  4. Problems with the file itself.
Resolving CRC Errors
Let's now have a look at the methods you can use to resolve some of the common CRC errors on your Windows system.
Fixing Transmission Problems with Network and Modem
You may encounter CRC errors while trying to transmit files over a network or a modem connection if there are problems with the connection you are using or there are data collisions occurring during the transmission due to heavy traffic.
Additionally, you may receive CRC errors if you are not transmitting your file in a format that is compatible with the protocol being used for transmission. For instance, if you are sending a text file through an FTP or Telnet session, it must be sent in Text mode or as an ASCII file. Non-text files, however, must be transmitted as binary files.
To resolve these problems, you can try the following:
  • Ensure that there are no problems with your network or modem connection.
  • Try to retransmit the file.
  • Try sending the file using some other method or connection.
  • Ensure that the file was sent using the correct format.
Dec 06, 2010 | Sony (CRX320AE/U) CD-RW/DVD-ROM (Combo)...
I have a problem code...its says check EO
Signal transmitting/receiving
error
(Indoor controller does not
respond to remote controller
signal.)
During individual unit control
1) Bad contact of transmission
wire
2) Signal transmitting/receiving circuit
is abnormal.
1) Check the transmission wire.
2) Check with another remote controller. If "EO" is
still indicated, replace the indoor controller
board.
If other check code appears. replace the original
remote controller.
P3 Signal transmission error
(Remote controller does not
respond to indoor controller
signal.)
wire
is abnormal.
3) Wrong operation due to noise
wave emitted
Nov 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Error code #0005 what does it mean? and possible causes?
Found the cause of the error, basically the other end is having trouble most likely poor line conditions.
##005 [ TX ] Failed G12 reception during G2 transmission.
A. Cause: Other party cannot properly receive the G12 signals due to poor line conditions.
Solution: Have the other party boost their transmission level so they can properly receive G12 signal.
B. Cause: Other party confused by echo and does not send G12.
Solution: Have the other party lower their transmission level so they will not receive echo signals.
Apr 15, 2010 | Canon LaserCLASS Fax 710 Printer
TI-89 i am very frustrated... i used graph link to transfer notes to my calcaultor but it said send failed. why? its really urgent i need notes to be transferred to my calculator. thanks!
My first answer is obvious: you can type them in the Editor.
Why did the transfer fail?
  1. File type incompatible with the OS.
  2. Not enough memory left to hold the file.
  3. Transmission error due weak batteries.
  4. Transmission error because the graph link end of the cable that goes into the IO port of the calculator is not fully inserted.
  5. Baud rate of your computer Serial port may be too high. Set it at 9600 bauds or less.
These are all the reasons I can think of. You may try to upadte the TI Connectivity software to the latest 1.6 version, if is not already 1.6
Hope it helps.
Thank you for using FixYa.
Nov 20, 2009 | Texas Instruments TI-89 Calculator
Frequent TCC message Lincoln continental 1999
go to autozone and get the codes. they will test for free.
Message Center Display
The following messages may be displayed on the message center.
This message center will display CHECK TRANSMISSION if the following codes have been set.
DTC Codes Possible Faults P1746, P1747, P1760 Electronic pressure control solenoid P0743, P1767 Torque converter clutch circuit P0750, P0755, P0760 Shift solenoid circuit P1714, P1715, P1716 ISIG P0731, P0732, P0733, P0734 SFT error P0741, P1742, P1743, P1744 Torque converter clutch error P1783 Over temperature P1700 NEV error P0712, P0713, P0710,
P1710, P1713, P1718 Transmission fluid
temperature error P0705, P0708, P1704 Transmission range sensor error P0500, P0503 Vehicle speed sensor error P0715 Turbine shaft speed error
NOTE: For codes. For additional information, refer to Diagnostic Trouble Code Chart.
Sep 25, 2009 | 1999 Lincoln Continental
Local mechanic says they can't check fluid level
"Sealed" means there's no dip stick tube.
The Explorers and Lincoln LS have this also.
It is nothing new and you can still change/flush the fluid as usual.
A special procedure is used to check the fluid level.
Not having the dip stick tube is one less place for dirt to get into the transmission.
please rate my answer
Jul 07, 2009 | 2005 Ford Explorer
What is the code p3 at Mr Slim thermostat
Signal transmission error (Remote control does not respond to indoor unit)
Causes:
Bad contact of transmission wire
Signal transmitting/receiving circuit is abnormal
Wrong operation due to noise interference by another appliance
Mitsubishi recommend replacing the transmission cables, the controller or the indoor board. Had the same problem myself one, I ran new temporary transmission cables. The unit ran no bother. Swapped the transmission cables for the original and the fault disappeared.
Jun 10, 2009 | Dometic Rooftop RV Air Conditioner
Mr.slim thermostat flashin and display p3
Causes:
Jun 10, 2009 | Heating & Cooling
Cameras Logo
21 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
John Peabody
John Peabody
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
