Question about Brother HL-2040 Laser Printer
Printer prints a duplicate image. Is the drum dirty?
I have a brother HL-2040. I just replced the ink cartridge
Does the problem exist if you try your old cartridge (just for a test)? if it doesn't, then you have a defective toner. Otherwise it is coincidental, and you need to replace the Drum unit.
Posted on Mar 10, 2009
What might cause my Brother HL-2040 to leave black blotches and an overall gray appearance on print outs?
if your drum is new and still you are getting a problem of dark background then you have to replace the toner cartridge.
Jul 26, 2014 | Brother HL-2040 Laser Printer
Faint print on Brother HL-2040
Try cleaning the drum cylinder with alcohol and a cotton ball. Then swipe the corona wire cleaner back and forward making sure to return it to the correct place. Try a print. If it is improved - replace the drum at earliest convenience. If not improved - could be dirty laser lenses or problem with the fuser.
Oct 20, 2017 | Brother HL-2040 Laser Printer
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
Brother HL-2040, The drum light keeps coming on and the left side of the printed page is all black?
Sounds like the toner cart. has toner packed at one end and possibly the drum cartridge is dirty. Remove both from the printer, separate the 2 and vacuum the drum cart. - them blow it clean. Run the drum wire cleaner (purple/blue tab on front edge of drum cart.) back & forth a number of times. Blow out the inside of the printer to get out toner dust. Reinstall toner back into drum cart, then hold GO/Control button down until all lights are on, let go, reinstall toner&drum back into printer, close door. Power down - then back on. That should do it. Worst case, you'll have to replace the drum unit.
Jan 07, 2010 | Brother HL-2040 Laser Printer
Brother HL2040 - Shading of toner all over my page when I print
The drum is a very sensitive part. Should not touch with bare hand, expose to light for long, etc. With what did you clean,it.
May 19, 2009 | Brother HL-2040 Laser Printer
Changing the toner on a brother HL-2040 in my office
It should be one unit??? look at the toner cartridge and look for a shiny cylinder that is the drum.
you can google brother hl2040 drum and click on images on the top right of google to see what it looks like
Aug 21, 2008 | Brother HL-2040 Laser Printer
Lines on papre
Replace the toner cartridge.
There is probably a flaw in the image drum. Replacing the toner will replace the image drum (they are one piece)
Aug 19, 2008 | Brother HL-2040 Laser Printer
Brother hl-2040 printing problem
Could be that there are a mark on the drum itself or some dirt, remove the drum unit and inspect the surface , by rotating the drum , becareful not to touch the drum as it will leave marks on the surface
Apr 25, 2008 | Brother HL-2040 Laser Printer
HL-2040 prints fading images
this is the problem of scanner assebbly (lense section), So open this section & clean the scanner after that your printer will work properly.
Feb 13, 2008 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
181 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
