Question about Ricoh Aficio 2015 Copier
RICHO 2015 HI I HAVE RICOH 2015 NTWORK SCANNER NOT WORKING PLZ NOT OPEN THE WEBIMAGES CREATD THE USER PATCH I WANT SCAN THE DOC ANY ONE GO TO USER FOLDER
  • Anonymous May 11, 2010
    Excuse me? it the web image monitor won't open with the IP address? is that correct? if that's the case then it must not print either? Which means that you don't have the Ip address set correctly. That's the first setting you need to make.
  • Ricoh Master
  • 2,794 Answers
Make sure there are no firewalls turned on your computer. All firewalls should be controlled on a router.
Are you using the web interface from the copier to download them?
Posted on Mar 10, 2009
Scanner not working
describe problem in more details about what technic u are using to scan , desktop binder or scan to email?
Mar 27, 2014 | Ricoh Aficio 2015 Copier
Installing Printer/scanner kit to Ricoh Aficio 2015
the main part of the kit is a dimm card. the dimm has the fax/scan/print stored on it. the problem adding this to your machine is drivers, only twain scanning, no scan to folerd, no internet faxing, no winodws 7 drivers. if you get a whole kit you need to add the fax pcb and also get the nic for it to scan properly. good luck
Dec 23, 2009 | Ricoh Aficio 2015 Copier
I have Richo Aficio MP 1600 all in one device-- Faxes fine, copies fine; Cannot get scanner to connect although Twain drivers are installed & device is connected to the network with its own IP address,...
Make sure the gateway is entered correctly, are you scanning to file or E-mail? Using web immage monitor is the easiest way to do it either way. if you have questions e-mail them to quennie@wcvt.com -Carl
Jul 07, 2009 | Ricoh Aficio MP1600SPF Copier
Scanner broblem
there are 2 ways to setup scan to folder. one is through a direct link to the folder of choice. the other is to use a program called scanrouter.
Apr 02, 2009 | Ricoh Aficio 2015 Copier
Richo color scanner is760d don't have option auto feeder
This scanner can be controlled by PixEdit so you may scan any amount of sheets. Even easy continue scanning to one document when not enough space in the ADF for the hold stack
Dec 08, 2008 | Ricoh IS760D Flatbed Scanner
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Jul 08, 2008 | Ricoh Aficio 2015 Copier
Ricoh Aficio 2015 Copier Logo
261 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
