Question about Dedicated Micros Digital Sprite 2 RS Video Recorder
Sprite 2,digital recorder
Sprite 2 digital recorder,
screen freezes up every day,stops recording,has to turn off and turn on again to re boot.
please tell me whats wrong.
  • Anonymous Mar 27, 2009
    Having the same issue around roughly the same time.
  • Anonymous May 14, 2009
    même problème , blocage des fonctions et led verte presence tension passe en clignotement rouge alim +5 volts et +12 volts correct.???
    what wrong
  • 3,660 Answers
Have you checked the system fans and hard drives as it maybe over heating. the fans don't last long around 15000hrs and stop cooling the system, that makes the hard drives over heat and the system board.... now I don't know why but if the system board goes over 40c inside the system will freeze up cameras pictures will stay on screen but frozen. but if a hard drive fault happens on slave the system will not record but the cameras will still be displaying movement but not record or say live just a red flashing power led. If it does these then change them. if the psu is at lower end of its life the voltage must be checked. the capacitors in side will need changing and the cooling fan you will need a 2200uf 25v/ 2x 470uf 16v/ 3x 3300uf 16v/ 1000uf 16v. and new 12v fan. you should easy spot the ones gone as the tops go rounded. This also may help you to stop problems happening as it has worked on mine. inside the system put a board in-between the hard drive/s and system board leave an inch gap at the end near to the fans. I have found this helps vent the heat out better. you could if you are able to fit some fans into the board. may help cool them down better. now for why the system fails at 40c. the system fails as there is not enough ventilation now normally here in the UK it is fine, but with temp's getting into the 30c's in the summer times, the systems need to be in tip top condition. so replace fans every 2 years and hard drives every 4 years. hope this helps some of you out.
Posted on Sep 14, 2013
  •  Russ Hill
    Russ Hill Oct 06, 2013
    I have found the problem. there are 2 chips in the unit on the left side take them out remembering what way they went in clean the pins on them as they just slot in to the board. clean both of them. put them back in and it should work fine after this. it would seam they lose connection when they get hot. I was give one to look at last week and it would crash every 1 to 2hrs. now this is all i did and now has been working with no problems for 5 days.
  • 4 Answers
Have you tried replacing the PSU, these units are fussy about their power requirements.
Posted on May 08, 2009
Error Code Trouble Shooting
The Boot Sector was damaged and the startup files are missing. May need factory service.
Dec 11, 2013 | Dedicated Micros Digital Sprite 2 RS Video...
Digital Sprite 2 screen freezes, reboot good for a few hours then freezes again.
check the system fans they need changing every 2 years. check the hard drive-s are not over heating should be changed every 4 years. check the psu is giving out the right volts can be checked on the hard drive plug when system is plugged in if voltage is to low 12.83v is fine 5.8volts is fine under the 12v or 5v mark it makes the system crash freeze up or just the red light flashing and a buzzing sound coming from the system. psu if you don't hear a fan going round then the psu has over heated and the power coming out will have dropped. replacement capacitors and fan can be found on the bay cheap make note were they are and replace. fan is a bearing type and costs a bit more. can use a none bearing type but it will need changing every year. 12v type think it was a 30mm or 40mm type.
Jan 30, 2013 | Dedicated Micros Digital Sprite 2 RS Video...
Sprite 2 GOTO mode not working. date keeps reverting back to the year 2036
you need to remove the cover with the power off. inside you will find to chips in caddes. remove the both. remebring where they went. un plug the hard drive/s and put power back on without the chips in should come on screen saying systerm error. turn off put avery thing back in and turn on now should start up and ask you time and date program it in and it will rest. should start up with the date and time you set now.
Jun 20, 2011 | Dedicated Micros Digital Sprite 2 RS Video...
Old DM Sprite 2, 16 Ch. C: - HItachi Deskstar 500GB Boots ok, no problem. Just installed a second drive, exactly same type as C, as a slave. Initializes ok, boot loader comes up for a second. Soon as...
format on the new hard drive has to be in FAT32 new hard drives are not formatted. psu should be fine as long as the fan is working and none of the capacitors have blown. the way you are doing. putting the cable on slave drive after is just making it a dead drive and is not being read at all from the system. when installed properly it will start up and a message should come on the screen 5 seconds after the cameras are seen on the screen to say new drive and merging files. then it puts 2 folders on the slave drive for recorded film files and advents .
Jun 08, 2011 | Dedicated Micros Digital Sprite 2 RS Video...
Error number = 6019 Get this message which won't
its a hard drive fault. change thye hard drives. and instal new firmwear. hard drive have to be formated to FAT32. download softwear from dedicated and the 3 files to the new hard drive you are going to use as master first file is Boot and other two files no note pad or think its dv softwear. put the hard drive in cctv, then turn on should boot up and the add the files to its system from the zip file. after it has finished it will set up slave drive. down load the manual as well so you can rest the system for how many day to record for and save video for how meany days etc.
Mar 14, 2011 | Dedicated Micros Digital Sprite 2 RS Video...
Keeps freezing
there are 2 chips on the left side of the mother board take them out remembering the way they go, give them a good clean on there pins and put back in theses are the system memory chips like ram in a pc or laptop
Dec 21, 2010 | Dedicated Micros Digital Sprite 2 RS Video...
How to check the IP on Digital Sprite 2?
I have no idea what Digital Sprite 2 is , but one universal way to check an IP of a device is to put it after DHCP server and check that server's IP allocation table.
Most home routers have those DHCP servers built-in and functional, so maybe the real question here is "how to check the IP lease allocation table of my wireless router" :-)
May 25, 2010 | Dedicated Micros Digital Sprite 2 RS Video...
Forgot admin password Dedicated Micros Digital Sprite 2 RS Video
You can't. You have to send it back to dedicated micros, unless of course you can use hyperterminal.
Feb 07, 2010 | Dedicated Micros Digital Sprite 2 RS Video...
Won't record
is the unit setup , sounds like the factory did a reset . go thru dm site for set up and repost
May 10, 2009 | Dedicated Micros Digital Sprite 2 RS Video...
Televison & Video Logo
887 people viewed this question
Top Dedicated Micros Televison & Video Experts
jason
electracon
 Russ Hill
Russ Hill
Are you a Dedicated Micros Televison and Video Expert? Answer questions, earn points and help others
