Question about Casio Parts Cash Register PC Desktop
Cash Register 2124ER making alarm noise when switching on
When I switch on the cash register, I get an alarm which I can't turn off by turning the key around unless it's on off. Is there anyone who can help me sort this problem out please. Thanks
  • 737 Answers
Wow. You must be the last person on earth with one of these. The printer rubbers have usually disintegrated on them by now.
We'll see what we can do for you.
First thing to do is to try turning the key to each position and press clear, then CASH in each position.
Posted on Mar 10, 2009
I can't get the key to turn into the SM mode to clear the grand total history.. I would like to do this before I use the machine
Cash Register Help: SAM4s ER-650 Cash Register
May 1, 2008 - I really like the SAM4s ER-650 Cash Register and ER-650R Cash Register. ... By the way the SAM4s ER-650 and ER-650R is the same as the Samsung ER-650 and ... I can't seem to figure out how to program it to track ticket/check #'s. .....also, neither the Reg Key or Mode Key will turn to SM mode. help?
Samsung Cash Registers ' ER650 Bar Code Scanner ... > ... > Cash Registers
If not, you will need to go to the SM mode and configure either RS-232 port 1 or port 2... Press enter (cash key) through the rest of the options. ... I could not get the curserinto the plu numeric field once i entered the plu. .... There are manuals for the SAM4s ER-650 at and if you are looking for ...
Samsung Cash Registers ' Samsung ER 650 Deleting PLUs ...
Dec 01, 2015 | Samsung SAM4s ER-650 Cash Register
I have a Royal 9155SC register. The display shows 0.00 and no key is working with continuous beeping. Please help.
Half Sysem Clear
a. Turn the key to the "PRG" position.
b. Unplug the cash register from the power source (pause
for 10 seconds) and replug the cash register.
c. Continue with normal operations.
Full System Clear
a. Turn the key to the "PRG" Position.
b. Unplug the cash register from the power source and wait
at least 15 seconds.
c. While holding down the [CLEAR] key, replug the cash
d. Re-program the cash register.
e. Continue with normal operations.
Oct 28, 2014 | Royal Office Equipment & Supplies
How to fix E00 sequence error
To clear the error code do the following:
Turn key to P mode
Turn power switch off
Hold Subtotal key down
Turn power switch back on (while holding the subtotal key)
Wait for print out
Turn your key back to Reg position.
After you do this it will "Close" the register so you will have to log back on.
Jun 07, 2014 | Samsung Sam4s ER-5240M Cash Register
Turn you key to HALF PAST then switch it on then turn the key back to reg. If it does not turn on call a technician
Feb 13, 2014 | Sharp Royal Alpha 9155SC Cash Register
Till roll print says power fail. cannot open the cash draw.
The power has been turned of before the sale was finished. Make sure it has a new roll of paper in the printer, then turn key to PGM and switch the power off. Hold down the SUBT key while you turn on the power - display will say INITIAL or something similar. Turn key back to R and see if it works.
Dec 23, 2013 | Samsung SAM4s ER-650 Cash Register
This ino might help: Cleaning ERRORS: ______________________________
1.- Turn the Mode lock to OFF
2.- Press down the RECEIPT FEED button
3.- Turn the key to PROGRAM
4.- Lift up RECEIPT FEED button (FFFFFFFFFF)
appears on the display panel
5.- Press SUBTOTAL (wait for receipt to issue)
6.- Turn Mode Switch back to REG and use as Normal.
Also another bit goes like this:
RESET: _______________________________________
1.- Insert the OW key and turn to OFF
2.- Hold down the JOURNAL FEED button and turn the key to PROGRAM mode
3.- Release the JOURNAL FEED button. The display should shows "00000000".
4.- Turn the key to OFF
5.- Turn to REG1. The display shows "INIT" and "0.00"
6.- Press the number 10801 and then press SUBTOTAL. Initialisation is completed when the printer stops operation. The display shows: "_ 0.00"
Hope this helps in restting to factory settings................................sodeep
May 12, 2009 | Casio Parts Cash Register PC Desktop
My Sharp Cash Register (ER-A410) won't turn on in manager mode
It is usually caused by a faulty or dirty mode switch. The first thing to try is squirting a bit of electrical lube down the key hole (WD40 or similar works fine), then turn the key back and forth a few times. Otherwise, the contacts inside the switch may have failed. I have also had a loose connector on the main board cause this in another model, so you could try pushing the connectors inside and make sure they are tight.
Hope this helps. You can set the void button to work in REG mode if you don't want to get the MGR mode fixed. Just let me know and I can look up the codes for you. You should be able to refund items as well (unless this has been set work in MGR mode also).
Dec 11, 2008 | Casio Parts Cash Register PC Desktop
Casio cash register not working
error code 1 on your cash register is due to Mode switch position changed before finalization
you can fix this error by Returning the mode switch to its original setting (does not beep) and finalize the operation
Jan 19, 2008 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
67 people viewed this question
Top Casio Retail Supplies Experts
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
