Question about Motorola Mobility H500 Wireless Headset
H500 has worked well until recently. Now when I power up it dials the last called. Any ideas what is going on.... Thanks
    Problem Solver:
  • 6 Answers
The button might be sticking from use, with a small flathead screw driver carefully pry off the silver part above the button area close to the charging port, you will see 2 tiny screws, next carefully with a tiny flat head screw driver, remove the cap over the bluelight area (the one with the symbol "M") and there is another tiny screw there. open it carefully and once open inspect closely the area that holds the button assembly and see if the contact point is either ripped or dirty or if the rubber is just not flexing anymore....
Posted on Mar 14, 2009
I have a new droid by motorola and an old h500 bluetooth headset. It still pairs beautifully with my old blackberry, but won't pair with the droid. HMMM? Any tricks? What am i doing wrong?
You need to put your H500 into "pairing mode" by pressing the call button until the light turns steady blue, instead of blinking. Your droid will then see it when you are in the Bluetooth Settings screen under Networks & Wireless. I just did this myself last night and it worked fine. Be forewarned, however, that you cannot voice-dial with your bluetooth - only answer calls. There are several forums out there that are bashing Motorola & Google for not having this basic functionality.
Dec 26, 2009 | Motorola Mobility H500 Wireless Headset
I need help pairing my motorola h500 to motorola i580 phone
  1. Make sure your phone's bluetooth is on.
  3. Scroll to power then press change.
  4. Scroll to ON the press select to turn on the bluetooth feature. Bluetooth feature remains ON until it is turned off.
  5. With the headset power off, press and hold the CALL button for 6-10 seconds until the blue light indicator turns on and remains steadily lit. If it does not stay lit, turn off the headset. To turn it off, press and hold CALL button until blue light stops.
  6. While holding the CALL button on the headset, on your phone select MENU > SETTINGS > CONNECTION > BLUETOOTH LINK > HANDS-FREE > LOOK FOR DEVICES. The phone lists all bluetooth devices it finds.
  7. Select Motorola H500.
  8. Press OK or YES to pair the headset with your phone.
  9. Enter the passkey 0000.
  10. Press OK.
Oct 08, 2009 | Motorola Mobility H500 Headset
Motorola Razor V3M and H500
This is a common issue with headsets is they stop working properly when they go bad. Not all of them of course, and the symptoms are different. Take it back and get a replacement.
Aug 25, 2008 | Motorola Mobility H500 Wireless Headset
New phone can not find bluetooth H500
Power off the H500. Hold down the power/activity/main large button (have no idea what Moto really calls this) for 6 to 8 secs. The LED ring should stay lit solid at this point and is in discovery mode. Now have your phone search for the headset. Default password on the device is 0000.
Aug 05, 2008 | Motorola Mobility H500 Wireless Headset
How do you turn on Motorola H500
Just press and hold the call button until indicator light flashes- its the button that has a phone icon on the H500- just check this link click HERE
Pls rate as fixya if it helps- thanks!
Jul 04, 2008 | Motorola Cell Phones
Pairing works, but no connectivity
I had the same problem and went through several iterations. The AT&T store gave me the idea of powering off the BlackBerry and H500 but this did not correct the problem.
What did correct the problem was powering off the BlackBerry, then pulling out the battery and waiting a minute, then reinstalling the battery and powering up. I had the H500 off as well and powered it up into pairing mode at the same time. Back in business now, so that seems to be a way to clear the error.
Good luck
Jun 11, 2008 | Motorola Mobility H500 Headset
How do i connect H500 to my phone
Hey guys. found it. Go to
then go to manuals
than click on the H500 Bluetooth.
It will walk you through step by step its pretty easy..
Or, you can do it easier.
- Press and hold the Power/Call buttom for 6-10 seconds, until there is a steady blue light
- when there is a steady blue light, go to your phone's Menu, then click on Bluetooth, than Handsfree, It will then start locating your bluetooth. In about 3-5 seconds it will pop up as H500.
-Connect to H500, or push Yes to Connect. (which ever way your phone tells you)
-It will then ask for a password. ALL PASSWORDS ARE THE SAME;AND CANNOT BE CHANGED.
- YOUR PASSWORD IS 0000. typle that in.
Congratulations! Your Now Connected.!
Good luck guys.
Any questions, im on here usually every other day
Feb 18, 2008 | Motorola Mobility H500 Wireless Headset
You can't program numbers vocally to you headset, you can only program vocally to your phone only if your phone has the voice dialing option. I have a H500 and can inform you of what I know. To turn on, hold button until blue light flashes once or twice, to turn off is the same thing. To pair your headset with your phone you have to hold down the call button until the light stays on then you use your phone to pair. After pairing the headset will flash quickly then discontinue. If you are using your headset and receive another call, you press the call button on the phone to answer the other line and to also release the call. The volume up and down buttons are found on the top and bottom of the headset, up and down is dependant on which ear you wear your headset. To mute, hold both the volume up and down buttons at the same time, this also unmutes the call. Hope this helps!
Sep 08, 2007 | Motorola Mobility H500 Wireless Headset
Can not hear on bluetooth
my headset works fine if I get a incoming call.When I dial out no one can hear me.
May 09, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility H500 Wireless Headset Logo
533 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
