Problem for samsung e250... the java based games or software cannot be install or played from the memory card...please,suggest how to get over this problem.
Have you ever wondered how to install high memory games and software to your samsung mobiles!<br />well, its time to get rid out of your long wait to play those awesome high memory games and to install that 2 m.b. Oxford dictionary:-)<br />you just have to press *#52828378# to your standby screen of samsung mobile. And go to "OTA MEMORY SETTING" and increase your java heap size memory to as high as your memory requirmenu of your software.<br />ex:- if you want to install a game of 650kb then increase java heap memory to 650kb, and yes you can now install them from the memory card and can play them if they support your mobile.<br />well before installing any game look your application internal memory should be blank to the level you want to install.<br />best of luck, happy gaming!<br /> <br />regards!
I had the same
problem on my s3550. And now i found out from myself what the problem
is. I Assume you have memory card and u are trying to install the games
from the memory card. That is the problem. Just copy the game you want
to install into the telephone memory and install it from there. It will
solve your problem. I am so happy to help you. i hope you see this.
download the games in to phone memory, don't copy in your memory card. It will not install from your memory card. Before installing please activate the java. Instially In SGH-P310 java will be in inactive position.
Type this code on your main screen to activate the java
I have a Dual SIM Sciphone i68 and have downloaded Java to activate the games i have on my phone. I just found that on the phone it'self under the Memory Card i have accessed the download that was saved on the phone but on the options menu there is an option to download the software? Please advise, anyone!
To Install Java Games On Your Samsung-E250,You Have To Download "Softick" PPP and A "Java game Uploader"(search it on Google)..........
lnstall java games using usb data cable SAMSUNG E250
Install\Run SoftickPPP221 from the Softick.PPP.v2.21 Folder. Ignore any errors about usbsync.dll by pressing OK.
Leave the option use usb in shared mode checked.
Run when finished installing. You will get an error message about being unable to locate usbport.dll, just click cancel.
Plug in your usb cable and turn phone on.
Right click on softickppp running in your taskbar and select settings.
In the usb tab uncheck accept ppp connection on usb and tick both use usb in exclusive mode and overide usb compatability,
Click on ok and completely exit softickppp by right clicking then exit.
Run softickppp and again goto settings. On the bluetooth\serial tab tick the correct com port.Mine is com3. Then click ok
On your phone key in *#52828378# press 2 ota type setting and select serial bearer ota.
Run samsung java uploader and add your jad file
On your phone select 3 serial test , 1 ppp up , 2 usb
Your phone will now reboot. While its rebooting right cklick on softickkppp in your taskbar and choose shutdown ppp
When your phone has rebooted again key in *#52828378#
Right click softickk ppp and activate ppp
On your phones java test menu press 3 serial test , 1 ppp up , 2 usb , 2 serial download
Your game should install and start running.
how to apply themes for samsung e250
