I have a 2007 G6 with 172000 miles. Had slight misfire you could feel but no light. So, 10k later i a tune up new plugs and wire.After, i was done light comes on so take it all apart again re gap spark plugs and double checked the wires had good ohms. coil was getting power and putting power to wires. and at idle one cylinder one is missing and when i move up to 1000 rmp its 1-5.I'm thinking egr valve clogged, crank sensor, or a type of compression issue. need help dont wanna burn up the cat. and o2 or anything that will make more of a problem
At this mileage i think the head gasket needs renewing ,Check compressions as it could be valve issue which is not a common day issue like the older cars from the 50s ,yes iam a dinasaur i admit it . but these modern cars head gaskets are not as good as the old copper ones from the prehistoric age .
SOURCE: miss fire in cylinder #1, 1998 subaru legacy outback
fuel injectors getting ground from pcm?
SOURCE: S10 pickup misifirng when light highway load
I had to rebuild my engine at 97000 miles cuz of low engine oil pressure and bad berrings
SOURCE: 1998 Cavalier No Spark in cylinders 1 & 4
ignition mod. grounds,pcm or timing belt could all be it but, I would have to look at timing first.
SOURCE: 99 4runner 5vz-fe 3.4 misfire
I know this post is old, but right on the engine theres a sticker that says use multi-ground plugs only. I read a similar problem like yours and it seemed to turn out that the spark was arcing to ground over the ceramic on the plug. So maybe it could have something to do with the single ground plugs.
P0303....Cylinder 3 Misfire Detected
P0304....Cylinder 4 Misfire Detected
sounds like a new set of HT leads and plugs wouldnt go amiss(fire wires) weird name that fire wires HT stands for high tension leads in proper english .
