Question about Kenmore 53642 / 53644 Side by Side Refrigerator
My Kenmore side by side stopped working.I discovered that no current was going to the compressor.I disconnected the feed wire and jumped the compressor. It worked fine. My problem now is which part do I replace.
  • Kenmore Master
  • 8,220 Answers
I would make sure the defrost timer is not stuck in the defrost mode first. If that was ok I would next check the control thermostat to see if it was open.
Posted on Mar 09, 2009
  • 163 Answers
I would replace the defrost timer or the relay,overload and capacitor to the compressor
I have a kenmore refrigerator that is not cooling. I found that when I take the production capacitor out of the circuit and jump the two wires together, that go to the capacitor, the comp runs. I bought a...
Your system works with a capacitor and contactor-relay to start the compressor. If you replace the contactor-relay that should solve your problem, if the compressor is okay.
Sep 20, 2011 | Kenmore 50522 / 50524 Side by Side...
I have a Kenmore Coldspot m# 57282791. Last night, it stopped staying cold, and I have not heard the motor/compressor come on at all since then (the part that cools the fridge, right?) There is a small fan...
If the compressor is not running, it could be either a bad relay or compressor.This is not an issue with defrost components or temp. control .If you have experience in repairing appliances, could take all precautions necessary and use multimeter - You could do a continuity check on compressor motor and all combination's. An infinity value on multimeter would confirm bad compressor.
On the side of the compressor you will see a box (maybe a cover) remove the cover if it has one and then remove the wire harness. next you will see the relay with the capacitor mounted to it. give the relay a tug and pull it off the side of the compressor. once you have it off pull the capacitor off and then give the relay a shake. If it rattles the relay is bad. if the relay does not rattle the compressor is bad and you will need to call a service guy to replace the compressor.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 10, 2010 | Kenmore 57029 Side by Side Refrigerator
Describe your Kenmore 53652 / 53654 / 53659 Side by Side Refrigerator Unit is not cooling. Stopped working after power outage
Kenmore Coldspot 106.53652300
I just fixed my neighbors fridge that suffered from a power surge. She explained that she smelt a burning smell in the kitchen and the next day the fridge and freezer were not cold. Of course she did not share the burnt smell part until after I discovered the starter relay and the capacitor were burnt on the compressor. She purchased the new starter kit and capacitor from a local supply company and while installing them I discovered the compressor fan was not running which also meant the compressor was not getting any power. I removed the screws that held the control panel on the fridge side (right side) and inspected the circuit board which I discovered a burnt trace on the board for the compressor control relay. I fixed the board by soldering a piece of solid core wire across it and it works great!
Make sure you shop around for your parts. The BIG local supplier here in Tulsa wanted $65 for the starter kit and $65 for the capacitor. We shopped around and found another supplier in Tulsa that sold them for $25 each and they were FSP parts!
Dec 15, 2009 | Kenmore 53652 / 53654 / 53659 Side by Side...
When I turn on my emachine desktop model#T6520 the screen jumps.
try downloading the current video driver for your computer.As to the speakers, look at the wires coming out of them. One should go to the computer as you've discovered. Is there another one or a jack on the speaker that's not doing anything?
May 20, 2009 | E-Machines eMachines Desktop PC
Compressor not going on after being shut down for months
Unplug and jump the wires going to thermostat. Get me the complete model number and I will try to trace why this happens.
Let me know, Thanks, Sea Breeze
Mar 26, 2009 | Kenmore Refrigerators
Kenmore refrigerator not working
Hi!!! Go to the back of the frig and see if the compressor and condensor fan motor are working.If not then you have a bad current relay.easy fix.its located in the compressor where the wires go into..Good luck.Heres a picture of your current relay..
Jan 04, 2009 | Kenmore 57029 Side by Side Refrigerator
No cooling on eather side
No, white to com, black to the run terminal, and to the start through the capacitor. I suggest you also have a 15-amp fuse or breaker in the line for protection. Given that you say the relay, cutout, and cap check out, and you say there is continuity through the compressor, I have to think that there is a high-resistance connection in the circuit that feeds the compressor. Suspect bad connection at the thermostat or the defrost timer. Be careful, and work with one hand behind you back so you do not receive a dangerous shock.
Dec 18, 2008 | Kenmore 53642 / 53644 Side by Side...
Air suspension not working
on the passenger side inside the wheel well there is a high current relay for the air compressor it is a silver metal relay assy 4 wire plug two smaller wire are the relay power two larger wires are compressor feed. if you jump the two larger wires and the compressor works check the smaller wires for power and ground if ok the relay is bad. usually these relays go bad due to compressor drawing high current and usually need to be replaced
Nov 26, 2008 | 1998 Ford Expedition
Kenmore refrigerator compressor relay and overload switch wiring diagram
The method of starting the compressor on very old units was that a real relay would close its contacts for a few seconds shorting the connection of the start(S) post on the compressor with the run(R) post thus feeding power to the start coil in the compressor for a few seconds. Well, I guess the bright design boys/girls were told to design for less cost and eliminated the real relay altogether. In its place they made a little plastic holder that has a disc type thermistor inside it. Normal resistors have a negative temperature coeficient meaning that as temperature goes up the resistance goes down. Thermistors do the opposite so as temperature goes up the resistance also goes up. They stuck one of these little thermistor discs about the size of a penny and just about as thick between the S and R terminal posts on the compressor so that when the thermostat in the refrigerator calls for more cooling power goes to the R post and through the thermistor disc to the S (start coil) post thus energizing the start coil in the compressor and giving it the jolt it needs to get going. Since the thermistor is left connected across there it heats up from the current going through it. I measured the cold resistance of one disc at exactly 5 ohms. Using ohms law of voltage squared divided by resistance gives us for a 120 vac circuit quite a bit of power: 120 X 120/5 or around 2880 watts that might be needed to be dissipated by that little disc thermistor every time the compressor kicks on. Of course the thermistor gets really hot and its resistance goes up thus limiting the current and everyone is happy...for a while...years if you are lucky. Back in the 1960's I worked at Western Electric Co.'s Lees Summit, MO plant and was responsible for lines making thermistors including the disc type...they do a great job for the telephone company where not much current goes through them...but for high current applications such as controlling starting of refrigerator compressors the "black cookie dough" they are made of gets real hot...I mean really hot...and the dough dries out even more and finally breaks down often shorting out and leaving a black carbon mess all over everything plus the heat can cause a fire...so the old design was better as far as I am concerned using relays that often lasted 40 years with no maintenance. I digress...again... I just repaired yesterday a Kenmore side by side that was thrown away on the street...with melted run terminal post on the compressor from the blown up thermistor and it was thought by them and the service guy that the compressor was bad as well. An ohmmeter check showed indeed that all the compressor terminals were shorted to each other and to the compressor case ground. I then unbolted the compressor and gently bent the freon containing copper tubing allowing me to pull the compressor out to give good access to the terminals. I wire brushed the three terminals and around them on the compressor real good and cleaned it up using carburetor spray cleaner, allowed it to dry completely and retested with my meter and...behold...no more terminal shorts to anything and the resistance measured of the coils inside the compressor were good readings.... so... I then made a test cable which would plug into a 120 vac outlet. I then connected the 120 vac between the common(C) and run(R) compressor terminal posts while simultaneously using another wire through a push button switch to feed power also to the start (S) terminal for perhaps 2 seconds...alla kerzam...the compressor started and ran fine. I left it running for a while and found that a cup of water froze in the freezer compartment in about 1 hour. Then I installed a new thermistor unit and jerry rigged a way to make connection to the melted stub on the run(R) terminal, put the whole compressor etc. back in the unit, put the cardboard cover on and it has now been doing an excellent job of cooling ever since. You may not want to go to all this trouble...but..hey...I got a 2 year old side by side kenmore that the people said they paid over $1000 for and I only spent $22.88 on it on internet for a new start thermistor/overload module...even so, I would have preferred to use a start relay.
Sep 18, 2008 | Refrigerators
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
205 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
