FixYa.com
Tags:
Vivitar 70-210mm f/3.5 Series I Lens for Minolta
Tamron SP 70-210mm f/3.5
By Gary10 - usenet poster
Any thoughts on the Tamron SP 70-210mm f/3.5 zoom?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Grant
Grant - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
in my opinion, it needs a tripod mount, but tamron doesn't have one
built-in, and the way the controls are configured, there is no obvious
way to attach an optional collar.
also in my opinion, the Vivitar Series 1 70-210/3.5 62mm filter thread
version is a better buy on the used market. This latter lens is shorter
and has the long end of the zoom range set when the push-pull barrel
is closest to the camera, and in my experience, the combination of the
two features allow this lens to get by without a tripod collar.
I own one of these and it is only a little bit heavier, but no longer
than many 200/4 fixed focal lenses, and works fine without a tripod mount.
I used to own the Tamron SP 70-210/3.5-4 which was the pre-cursor to
the one asked about. This earlier lens did have an optional tripod
collar. And this lens is the same length and slightly lighter weight
than the current model f/3.5 constant aperture version. My experience
with the 70-210/3.5-4 was it was no acceptable with camera mounted on a
tripod so the tripod mount was important, hence it is clear to me
that the f/3.5 version needs this.
The f/3.5-4 Tamron also wasn't as good as the Vivitar at close focus either.
This applies also to the tokina ATX 80-200/2.8 that I tried and found the
close focus image quality to be lacking.
I have previously owned the 67mm filter thread version of the Vivitar lens and
found it not to be as good. I've heard from others that the 67mm filter
thread (earlier) version had problems with sample-to-sample consistency,
so that may have been the problem, but the 62mm filter version of the lens
I have now works quite well.
Joseph Albert
Copyright Joseph Albert 1998. All rights reserved.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Camera Lenses problems?
Camera Lenses
af motor required for a canon...
HI, My name is Nick, I'm trying... Answer This...
Camera Lenses
test dont answer
test dont answer Answer This...
Camera Lenses
i will never shop here again...
best buy, my foot best buy has... Answer This...
Camera Lenses
pc camera 6028 vga
i want to make installing to my... Answer This...
Camera Lenses
camera not compatible with...
i have an intex it-305WC web... Answer This...
Repair Service
Find Camera Lense Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
