Question about HP PSC 1410 All-In-One InkJet Printer
I dont want to print test page - HP PSC 1410 All-In-One InkJet Printer
    Sergeant:
  • 254 Answers
As when you get the test page while you on the printer.to stop it.just place the printer side of the test page on the scanner glass.and press the scan button on the printer.the green light will blink for 1 minute.then automatically stop.after that remove the paper from scanner glass.and now you will not get the test page again n again.
Posted on Mar 09, 2009
2 Suggested Answers
fotomohamed
  • 321 Answers
SOURCE: Every time prints test page
check out printer properties remove tickmark from that box
Posted on Jun 18, 2009
My Officejet 4315 All-in-One is printing very very slow How do I fix this problem? I have restarted it and unplugged then replugged it and have restarted the computer and it still prints really really...
The very first thing you need to do determine whether the issue is in the Hardware or in the Software for that on the printer .
1. Load plain paper in the tray.
2. Press the Setup button
3. Press 2 to select Print Report
4. Press 4 to select Self-Test Report . The self-test page prints.
Measure the time (in seconds) it takes for the test page to prints.If the test page prints in less than 60 seconds , this is normal print speed and you do not need to troubleshoot.If the test page prints in more than 60 seconds , go to the next step.
Important ;
Some products print faster than others. If the test page exceeds 60 seconds, and other documents you print typically take as long, the print speed is normal. Troubleshoot this issue only if your product is designed to print faster than about 60 seconds a page or if printing is slower than usual.
***** IF THE PRINT SPEED IS MORE THAN 60 SEC.
Check the power supply. to check the power supply you need to follow these steps.
1. Turn the product so that you can access the rear side.
2. Unplug the power cord from the back of the product.
3. Remove any devices between the product and the power outlet, such as surge suppressors or power strips.
4. Plug the power cord directly into a wall outlet.
5. Print and time a self-test again.
If the test page prints in 30 seconds or less , the problem relates to the power supply. Replace devices between the product and the power outlet, or leave the product connected directly to the wall outlet. If the test page takes significantly longer than 30 seconds to print, continue to the next solution.
CHECK THE CARTRIDGE COMPATIBILTY.
Incompatible cartridges can cause the slow printing problem.
Which cartridges you use depends on your country or region. To check the cartridge compatibility you can go to this site (for hp printers) http://www.hp.com/buy/suresupply and check The number on the cartridge label must match the numbers listed on HP SureSupply.
PERFORM A RESET.
1. Press the Power button and turn off the printer.
2. unplug the power cord. Disconnect the data cable(USB,Ethernet depending upon the the product set up). wait for 30 secs. reconnect all the cable and than try to print a test page.
if these steps resolves the issue than you dont need to continue troubleshooting or if the issue persist than Replace the Power supply for your product.
Jul 06, 2010 | HP Officejet 4315 All-in-One Printer
When trying to print up an email message ,it only prints half of the page
pleace disconect the power cable from the wall outlet the press and hold the power botton for 20-30 sec then restart and try to print test page
if still it not work then follow this instrution mention from the below URL
HP.COM/GO/SMARTWEBPRINTING
and install it and then try to print it should print
even after that if it does not print try and add a printer (deskjet 990c) from the printer page
follow the instructions
1.go to the printers page
2.click on ADD A PRINTER
3.click next
4.select local printer
5.afetr that select HP from the left side
6.select deskjet 990c from the right colloumn
7.click on next
8.click on next
9.after that it will prompt to print a test page and set the printer as default (yes)
10.if the test page prints out
11.try and print the e-mail
it should work
get back to me if you still have problem i will help you
dont forget to vote for me (sincerely be appreciated )
Thanks
Regards
Hamid
Feb 28, 2010 | HP PSC 1510 All-In-One InkJet Printer
I have installed a new black cartridge but print is not clear. i think i need to realign cartridges but dont know how. it is a lexmark x73. can you pls help
1 Select Print Control Program Cartridges Align Cartridges. For help, see page 8.
An alignment page prints and the Align Cartridges dialog box displays on the screen.
A number appears under each pattern. The test page that prints is similar to the one
shown.
2 For each alignment group on the test page, find the number that comes closest to
forming a straight line.
3 In the Align Cartridges dialog box, enter the numbers you selected on the test page.
4 After you have entered a number for all of the patterns, click OK.
http://www.lexmark.com/publications/pdfs/2007/x73/user_guide_en.pdf
Oct 23, 2009 | Lexmark X73 All-In-One InkJet Printer
Jun 18, 2009 | HP PSC 1410 All-In-One InkJet Printer
It keeps on printing test pages
Uninstall the PRINTER'S DRIVER SOFTWARE completely from your system, MAKE SURE YOU USE THE PRINTER'S DRIVER DISK FOR IT OR ANY UNINSTALLER SOFTWARE FOR IT DONT UNINSTALL IT FROM CONTROL PANEL.... DISCONNECT PRINTER, TURN IT OFF. Clear All Temp And Prefetch Files. Restart Your System, Turn On Printer, Hook It Up To Your System,,, Go To The Manufacturer's Website And Install The Latest Driver Software And Firmware If Available....
May 21, 2009 | Kyocera Mita FS 1000+N Laser Printer
Printing blotchy
reinstall both cartridges again and close housing, if it does not print test page turn off the printer and wait a few seconds and turn it back on.
Dec 23, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP deskjet 5550 printer not printing.
could be low on ink or toner. dont you just love that? itll print out a test page which is a waste of ink but wont print out anything else.
Nov 17, 2008 | HP DeskJet 5550 InkJet Printer
MY PRINTER TM U200PD DONT PRINT
i search the driver in the page http://www.yoreparo.com it is the driver thank you
Oct 06, 2008 | Epson TM U200PD Matrix Printer
Not working dtc550
Since the printer prints the test page from the driver, most likely the problem is with your Cardfive software. To test this, try printing a card on the printer from Microsoft Word or Notepad. Just remember to set your page size or you will get multiple cards printed. The Fargo printer is just a windows printer and may receive output from any windows software.
Aug 02, 2008 | Fargo DTC550 Thermal Card Printer
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP PSC 1410 All-In-One InkJet Printer Logo
Ben Johnson
