Question about Xerox 5500/DT Laser Printer
Xerox 5500 paper jam at A
The first print jobs that come out jam right as it is coming out of the printer by door A.
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
Check out this video for detail on what is happening and an explanation of that part and how to fix it">
Posted on Jan 07, 2011
Replace the exit sensor. The earlier versions of the exit sensor had this problem all the time because the printer had to heat up in order to get the sensor to loosen enough to get paper by it. Xerox remodelled it and the new ones should work just fine.
Posted on May 01, 2009
WHAT IS 007-243 code error
This fault code isn't specific to one location/function on your machine, however, I believe it is directly related to your paper trays. Other fault codes begining with 007-??? state a tray sensor error, misfed media in a tray etc...
If you're trying to print to a specific tray and it won't print giving this error, you may want to try printing using a different tray. It is entirely possible you have some jammed up paper in the paper path and this will stop all trays from printing.
Potential solution:
Ensure you don't have any paper jams related to your paper path and trays, herre is a link that provides you all iinstructions to clear any paper jam on your device http://www.support.xerox.com/support/workcentre-7328-7335-7345-7346/support/enus.html?associatedProduct=workcentre-7328-35-45-46-built-in-controller
NOTE: The above link is a support knowledgebase and you can search on any problem you may have with your product by typing the natural language query in the search field, paper jam, can't print, scan fails transferiing etc...
Once you have determined there isn't a paper jam or if so gently remove any misfed paper.Reboot the device PO/PO power off/power on.
If the print jobs fail again, check your job status and see if there is any info listed for your print job, could be a media mismatch.
Try printing to another paper tray, if your job is calling for paper from tray 3 try using tray 4 or tray 5 etc..
I have provided a generic response to this question and kind of throwing ideas out there, if you could provide additional information I may be able to give a better solution.
Check the details of your job in the job status list?
A lot of times the machine will provide good direction on potential issues with a print job.
Are you trying to print on a custom paper size?
If you tell the print driver to print to tray 3 and you have 8.5X11 loaded in tray 3 and your print job from ypour PC is actually 8.5X14 then the job will not print simply put the media has to match the job.
I hope this helps.
Mar 10, 2015 | Xerox Workcentre 7345 Printer, Copier,...
Why does my Xerox Phaser 5500 print distorted watermarks?
Click caret ro right of friend's post, click unfollow without unfreinding.
Feb 26, 2015 | Xerox Phaser Office Equipment & Supplies
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
Xerox Phaser 5500 will only print if started in the manual tray.
Check your printer setup/default settings on the printer. Make sure you are using the right paper in the trays and that they are set properly to the proper paper tray & size. You have to have it right in all locations for it to work right, or it will default to by-pass tray. 1st in the settings, 2nd in the trays, and 3rd in your printer software. Good Luck!!
Jun 07, 2012 | Xerox Phaser 5500 Laser Printer
First print job, first page jams on output area
Please note that paper absorve humidity, try to keep you equipment in a dry place.
When the paper is that condition, and while passing thru the hot image drum, the sheet hedges sometimes curves and jams...
Sorry for my bad english !
Jun 23, 2009 | Xerox 4150V_P Printer
Printer jams at back door of printer everytime
ouch, those printers are a bit of a pain
first thing that comes to mind is, make sure your not putting too much paper in, 20-40 sheets of paper at once should be fine
im guessing even just 1 peice of paper is getting stuck?
in that case i would call a technician, something just doesnt sound right
what messages are coming up on the printer before, during and after printing?
May 19, 2009 | Dell 968 All-In-One Printer
Xerox 5500 Jamming when Duplexing
HAVE A PRINTER AND IT WILL NOT PRINT
May 01, 2009 | Xerox 5500/DT Laser Printer
Xerox Phaser 5500 printer...paper stops halfway thru fuser unit.
Are the paper tray settings correct? If you have the tray mis adjusted, such as the tray thinks it has 14 inch paper in it and it has 11 inch, it will just shut down like that.
Make sure the settings are correct on the computer and the printer.
Also, its unlikely but the latch for the load springs in the fuser may be unlatched, but you shold NOT be able to close the covers like that.
Jan 06, 2009 | Xerox 5500/DT Laser Printer
5500 xerox phaser
Check the paper path for any and all debris. Use canned air to remove any debris. Also check the paper tray guides to see if they are matched correctly.
Oct 30, 2008 | Xerox Phaser 8500N Printer
Paper jam
open the front and rear access door and try to pull the paper gently you can also unplug and replug your print so it would spit out the paper.
May 28, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Xerox 5500/DT Laser Printer Logo
610 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
