Question about Toshiba E-Studio 161 Copier
I need a master reset code for studio 550 toshiba PLEASE PLEASE P
  • Nike Merritt May 11, 2010
    what is a master reset code? are you asking for an administrator code?
  • didi2005 May 11, 2010
    What is your estudio 550 problem?
    As far as i concern, there is no master reset code...
    Unless u format the hdd and update firmwares....
Error code c37
Posted on Sep 18, 2009
2 Suggested Answers
  • 653 Answers
SOURCE: my toshiba e-studio 550: service recommended for SPC appeared
Check the control status of the surface potential sensor (05-242).
<When “4” is displayed: sensor error>
The sensor detection value is abnormal or the sensor output value is not changed even though
the main charger bias value is changed.
Is the connector of the surface potential sensor connected properly?
Is the main charger grid/wire attached poorly?
Is the main charger attached poorly?
Are leaks and such occurring?
Posted on Mar 06, 2009
C41 Error on Toshiba E-Studio 550
Get a decent piece of equipment. WHY would you throw money away on a bad copier?
Apr 15, 2014 | Toshiba E-studio 550 Copier - Fast,...
Hello, I turn on my Toshiba E-Studio 166 Photocopy Machine and it shows an Error Code C 41, please how can I fix this problem?
Poor contact of the fuser drawer connector may cause the following
error codes: C41~C46, C4A, CD5, E01, E03. To correct this issue, a
spacer (see SPL p25 item 1 attached) has been added between the
fuser connector and the frame; also the springs (see SPL p24 item 8
attached) have been changed to provide more tension.
This change has been applied since January 2003 production:
e-Studio 550 TA314824
e-Studio 650 WA312627
e-Studio 810 XA311627
Model P-I Before Change After Change
e-ST550 25-1 --- 6LA14365000
e-ST650 SPACER-DRW-CNCT
e-ST810 24-8 6LA08946000 6LA14468000
SPC067-070-140 SPC068-080-160
Jan 26, 2011 | Toshiba e-Studio163 Copier
What is the solution for error code c26 on my toshiba e-studio 550 copier?
Hi how are you i hope you are well this is jack ..my personal ID.. (jack_pak@hotmail.com)
C26 Error is scanner error
please check the scanner unite
1 scanner lamps.
2 scanner strip.
3 scanner bord
4 LGC bord.
please check these all goods are working properly.
Thanks
Best Regards,
Jul 02, 2010 | Toshiba E-STUDIO 550 Copier
Toshiba e-studio 550 call for service F10
Do the following.
Hold down 0+8 and turn the copier on.
Type in 690 then hit start.
Make sure there is the number 2 displayed.
Press enter on the touch screen.
Reboot the machine when told to.
Jul 22, 2009 | Toshiba E-STUDIO 650 Copier
I have 2 problems with my toshiba 550. service code CD3 and SPC
The CD3 error is related to the recycled toner unit. the recycled toner is backed up/clogged.
Toshiba made a parts change to the design of the recycle toner unit by replacing a bushing with a roller bearing and a seal. depending on how old your copier is it may or may not have this modification. The copier firmware/software also needs to be updated to the most current version and along with that there are a few internal settings that need to be adjusted.
If you are unable to do any of the above then try this - (it will get rid of the problem short term) clean/vacuum out the toner recycle unit.
If you open the front cover of the copier you will a white plastic pipe sitting at about a 45 degree angle (below the toner cartridge) - this is the pipe that leads to the recycle unit on the right. The whole unit needs to be removed and taken apart and cleaned, inside and out, including the pipe.
The SPC code is related to this issue and should also go away.
Hope this helps.
Mar 31, 2009 | Toshiba E-STUDIO 550 Copier
My toshiba e-studio 550: service recommended for SPC appeared
Mar 05, 2009 | Toshiba E-STUDIO 550 Copier
Admin Password
The master password for the Toshiba e-Studio 45 (using controller gl-1010) is 349845. Use a web browser to open the printer's built-in web access: TopAccess, and click the log-in link on the right hand side to use this password.
Jan 29, 2009 | Toshiba E-STUDIO 450 Copier
Error code c26 on my Toshiba 550 copier
C-26 code it could be your exposure lamp.. when you turn on you copier keep the document feeder open and see if the lamp turns on...if it turns on and the turn off its ok.
Now clean your white reference guide..it's located under the glass..need to take off exposure glass and clean under it..especially a white strip on the edge of the glass.. NOTE: turn of your copier first then clean after adjustment turn on.
May 22, 2008 | Toshiba E-STUDIO 550 Copier
Toshiba E-Studio 161 Copier Logo
609 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
