Sound is sporadic, sometimes fine, sometimes very low. No amount of adjustment of knobs does anything.
It sound like you need the thing reprogramed or the amp out puts are inopra.My try killing the power completly for about 5min.
Posted on Mar 15, 2009
Volume doesn't work on bose radio in car all the time
Sue,
I had the same issue with a car I owned and had to replace the unit.
May 04, 2017 | 2009 Nissan Rogue
Air condition
sounds like a freon re charge is in the offing...or your pressure regulator is not working..
May 31, 2008 | Mercury Marquis Cars & Trucks
How to send effects to microphones
You CAN'T send ANYTHING to microphones since they are INPUT devices.
If you want apply effects to the audio coming FROM them then this is what you do:
Adjust the trim and faders for normal use and verify the mics are working.
NOW for those mics you want to put effects on, turn the knob labled "FX" above EACH mic FADER that you want effects on... it will be the orange topped ones... about the fourth one up ablve the PAN and the two MON knobs. Adjust these to send each mic into the effects mixing buss. Start by setting them at 12 o'clock. You will use these to proportion the amount of effects applied to individual mics.
Next, advance the FX fader/slider to around the Unity mark... this controls the amount of the FX mix buss goes into the FX processor.
Next adjust the knob above the MAIN fader that says FX to Main. This controls the amount of the FX that is sent into the MAIN mix buss...
We are almost there... Select the effect you want with the effect knob to the number of the effect you want... it will be blinking AFTER a change... the effect will NOT have changed yet... WHEN you want the effect to take effect, PRESS DOWN on the effect knob and the effect number will stop blinking and you now have the effects on those mics... ADJUST the three level things... the knbs under each channel to proportion between the mics... adjust the FX fader for the USUAL control of effect amount... and finally the FX to main knb to set the limit of the effect going to the MAINS.
Feb 13, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
I have a Sylvania SRD3900 DVD Player / VCR Combo that I purchased about 6 years ago. The VCR part is causing problems. When I try to play movies the picture is distorted with no sound, but it plays back...
The tracking needs to be adjusted. Sometimes it's a knob on the VCR, and sometimes it's a control on the remote. Adjust it for the best picture, and the sound shoud be restored.
Good luck, and hope this helps..
Nov 01, 2010 | Sylvania SRD3900 DVD Player/VCR
Volfenhag amp adjustments
Firstly, you will want to set all options to a low pass, so the high frequencies are filtered away from the subs, avoiding damaging the voice coil. Start with the Gain of the amp about 3/4 of the way up, and all other knobs, such as the bass knob to the lowest setting. From there, test your subs for soujnd, and then change the gain and amount of bass for the sound you desire, since each person is different. I have my gain about 1/2 way up and the bass about 1/4 of the way up. If you have a crossover knob, set it to the highest frequency available, since the low pass will filter all the high frequencies out anyway.
Sep 23, 2009 | Volfenhag ZX-5007 Car Audio Amplifier
Sw 1501 no sound output
in my dvd dts audio is not playing
Feb 13, 2009 | Mackie SWA1501 Subwoofer
Volume control for model TXD1972
This may sound stupid but try this turn the volume knob to high and low continously for a few seconds sometimes the contacts become dirty and just a little movement back and forth quickly repairs it. I said SOMETIMES.
Sep 04, 2008 | Samsung TXD1972 19" TV
Electrical question
I bought a AlohaBreeze Pedestal fan from yard sale, been told that it works fine. It did worked fine for sometime. Since it was too dirty, I tried opening it & cleaned it. Works fine for sometime but when switched off for a while & on it, I can just hear the motor sound but the blade doesn't move. If I open it & adjust the knobs, works out for sometime. Everything inside parts seem to be fine. Can anyone suggestion some solution that could make work fine thru'out.
Jul 01, 2008 | Dryers
 Grubhead
Grubhead
