Question about Hitachi Televison & Video
Need schematic for Convergence PWB of Hitachi
Need schemtic for Convergence PWB of Hitachi 53UWX10B. Convergence Board is ''DP1X Convergence PWB''. Model # JK07132-A.
    Filmmaker:
    Uploaded 5 video answers.
  • 162 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergenNeed schematic for Convergence PWB of Hitachi - 2c07611.pnge bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos aroundimages.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Mar 28, 2012
    Sergeant:
  • 254 Answers
DP14G BOARD
Part Store is good choice to get many kind of TV boards.
Check required board there please.
Sep 25, 2008 | Hitachi 53UWX10B 53" Rear Projection...
I need to find the value of rx50 rx54 rx58 on hitichi dp1x convergence board
The DP1X was used in various Hitachi Models and those resistors have different ratings depending on the Model number. Post your model number and I can list the ratings for those resistors for you. Also do you mean RK50, RK54 and RK58 as those are convergence resistors board location prefixes that usually get blown. Double check the Prefixes.
Nov 26, 2009 | Televison & Video
Convergence settings on hitachi 53uwx10b
Yes - You will need to either remove the circuit board or lift up the tray. If you are not sure how to do it yourself read the link below.
  • This is a very common failure on Projection TV sets.
  • Screen looks 3D
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 10, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Incorrect resistors on DP1X PWB?
Assuming this unit was never worked on and it was actually working properly before the IC's decided to take a vacation I would recommend leaving them alone as there may have been an engineering change after the service manual was printed.
Apr 15, 2009 | Hitachi 43FDX15B 43" Rear Projection...
Convergence i.c. board
Yes, you need two convergence ICs for your model STK392-110 heres the link to the site.
http://servicemanuals.vstore.ca/
Apr 29, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53uwx10b template
Hi, first what exactly are you looking for? the convergence board of the STKs number? If you have convergence problem, you will need to change the STKs for sure and check the resistence to the STKs and generally all of them have same low value. check it out and replace the faulty onces. switch on and adjust convergence and you have a good working picture on the screen. Visit www.fixurtvs.com for more FAQs.
Jan 11, 2008 | Hitachi Televison & Video
Set will not turn on!! please help
No, all you need to do is notice all led and see which goes off first and which stay on. Then I can help you.
Oct 09, 2007 | Hitachi 61SWX12B 61" Rear Projection...
Televison & Video Logo
663 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
