Question about Microsoft Windows XP Professional
How to disable usb windows xp in a local user means only one usre
Go to Run command and type regedit
HKEY_LOCAL_MACHINE\System\CurrentControlSet\ Control\StorageDevicePolicies
Now add a new DWORD called WriteProtect and put the value as 0 to disable write privileges to the USB port. To reverse the step, either delete the WriteProtect REG_DWORD or toggle the value to 1 which will enable the port.
Posted on Mar 09, 2009
Why do i have to change my paswort all the time?
You might have it set to change at certain intervals
IE: at log in or after each restart .......
Disable password log in
On both PC and Mac computers, you can set up your system to automatically log in to a certain user account.
As a result, this setting will allow you to bypass the password login that is typically required.
You should only enable automatic login on your computer if it cannot be easily accessed by other people.
Open the Start menu and click on "Run."
Type "control userpasswords2" (no quote marks) into the dialog box and press the Enter key.
Uncheck the box next to "Users must enter a username and password" and click on the "Apply" button.
Enter the username of the account you want to automatically log in with and then type that account's password twice to finish setting up automatic login.
Click "OK." Password login has now been disabled.
Mac Instructions
Open System Preferences by clicking on the Dock icon.
Go to the "Accounts" control panel under the "System" heading.
Click on the "Login Options" button at the bottom of the window.
Select the account that you want to automatically log in with from the "Automatic login" drop-down menu.
also
Depending on what operating system you have, there are several steps you must take in order to disable the administrator account and password on your computer.
Most often, the administrator account and password are disabled in order to minimize security risks on your computer.
This account is often the target of attack if your system is compromised, as it allows access to all of the data and programs on the computer.
In order to disable the administrator account and password, follow the steps below that are outlined for the major operating systems.
If you are using Windows XP, you must be logged on as the administrator in order to disable the account settings.
Microsoft suggests that you set up another account with administrator permissions in the event that you may need to reverse this process.
Otherwise, you won't be able to.
Right-click on the My Computer icon on your desktop and select manage.
Click Users under Local Users and Groups in the left pane, which will bring up all users on the computer.
Double-click Administrator and on the General tab, check Account is disabled.
This will disable the Administrator account and password for Windows XP users.
In Windows 2000, go to Start, select Programs and go to Administrative Tools.
Click on Local Security Policy.
Next, click on User Rights Assignment under the Local Policies option in the left panel.
Double-click Deny access to this computer from the network and then click Add under Local Security Policy Setting.
Click Administrator account under Users and Groups, then click Add.
Click OK to complete the disabling of the Administrator account and password.
In Windows Vista, the Administrator account is automatically disabled.
However, if you have enabled it, you will need to open a command prompt.
Go to Start Menu, click All Programs, select Accessories and right-click on Command Prompt and click run as Administrator.
Open the command box and type net user administrator/active:no. Press enter and you should receive a prompt stating the command was completed successfully.
If you are running a Mac, the Administrator account is enabled by default.
To disable the account and password, go to the Apple menu, click System Preferences.
Choose Accounts from the View menu and click the lock to authenticate with the administrator account password.
Click login options, click edit, and after clicking the lock in the Directory Utility window, click Disable Root User from the Edit menu.
Aug 04, 2013 | Computers & Internet
Tip
Disable Writing to USB Drives
A common security concern at organizations is allowing users to plug in a usb flash drive, because they could so easily copy corporate data.
Since Windows XP SP2, you can disable writing to USB devices altogether using a simple registry hack. Here it is:
[HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlStorageDevicePolicies]
“WriteProtect”=dword:00000001
on Aug 01, 2010 | Computers & Internet
Tip
How to disable user account control in windows 7
It is very easy to deal with UAC Settings in windows 7.You dont need to completely disable UAC, if you really dont want to do. Here is the step to be followed to disable UAC in windows 7 Step
1: Access UAC settings by typing UAC in the start menu or control panel search
OR
Go to start -> Control panel - > user accounts
Once you double click on user accounts you will get a window like below. There double click on Change user account control settings option
Now you will get options to change user account control settings. You can move the slide to 4 different posiotions according to your choice. The first is more secure and the last means its disabled
Disable UAC via Registry Editor
1.Type regedit in the Start -> Search bar. 2.GotothefollowingKey:HKEY_LOCAL_MACHINESoftwareMicrosoftWindowsCurrentVersionPoliciesSystem 3.Locate REG_DWORD: EnableLUA
4.Set the value of EnableLUA to 0.
5.Locate REG_DWORD: ConsentPromptBehaviorAdmin
6.Set the value of ConsentPromptBehaviorAdmin to 0
7.Restart
Disable UAC via Group Policy
  1. Type “gpedit.msc” in the Start -> Search bar.
  2. Double-Click: Computer Configuration -> Windows Settings -> Security Settings -> Local Policies -> Security Options.
  3. Locate: “User Account Control: Behavior of the elevation prompt for administrators in Admin Approval Mode” and modify to “Elevate without prompt”
  4. .Locate: “User Account Control: Detect application installations and prompt for elevation” and modify it to “Disabled”
  5. Locate: “User Account Control: Run all administrators in Admin Approval Mode” and modify it to “Disabled”
  6. Locate: “User Account Control: Only elevate UIAccess applications that are installed in secure locations” and modify it to “Disabled”
  7. Restart.
on Mar 03, 2010 | Computers & Internet
Plesse help
How to Disable the Local Administrator Account on Windows XPNote Before you disable the local Administrator account, make sure that there is at least one other local or network user who can gain access to the computer with administrator permissions. Otherwise, you will not be able to reverse this action in the future.
  1. Log on as Administrator, or as a user with administrator permissions.
  2. Right-click My Computer, and then click Manage.
  3. In the left pane, expand the Local Users and Groups node, and then click Users.
  4. In the right pane, double-click the Administrator account.
  5. On the General tab, select the Account is disabled check box, and then click OK.
  6. Quit the Computer Management console. The new setting takes effect the next time you attempt to log on to this computer.
Source: http://support.microsoft.com/kb/281140
May 25, 2013 | Computers & Internet
How to remove administrator in WINDOWS XP? i need an immediate answer right now.. thanks..
You can disable the Administrator account using the following procedure:
The full article is here: http://support.microsoft.com/kb/281140
Sep 22, 2011 | Computers & Internet
Windows live messenger
use the admin account to reset the password
Open Local users and group.
Double click on Local users and group
Click usres.
Right click on account that you neen to reset the password about.
Click Set Password
Type and confirmm new password.
Apr 02, 2010 | Microsoft MSN Messenger Connect Service
The message light on the MD110 is not working. I think I pressed something that disabled it. How to I get it back on?
detail_no-screenshot.gif Erlang R11B
Erlang is a full-featured programming language developed at the Ericsson CS Laboratory. more>> Erlang is a programming language designed at the Ericsson Computer Science Laboratory.
Open-source Erlang is being released to help encourage the spread of Erlang outside Ericsson.
Installation
When installed, the entire system, except for a small start-up script, resides in a single directory tree. The location of this directory tree can be chosen arbitrarily by the installer, and it does not need to be in the users $PATH.
The only requirements are that the file system where it is placed has enough free space, and that the users who run Erlang/OTP have read access to it. In the example below, the directory tree is assumed to be located at /usr/local/erlang, which is here called the top-level directory.
It is assumed that you have the compressed tar file, the name of which is < PREFIX >.tar.gz, where < PREFIX > is a string denoting the particular Erlang/OTP release, e.g. otp_LXA_11930_sunos5_R9B.
Wherever the string < PREFIX > is used below, it should be replaced by the actual name prefix of the compressed tar file.
The tape archive file does not have one single directory in which all other files are rooted. Therefore the tape archive file must be extracted into an empty (newly created) directory.
1. If the top-level directory does not already exist, create it:
mkdir /usr/local/erlang
2. Change the current directory to the top level directory:
cd /usr/local/erlang
3. Create the installation directory with an appropriate name. For example:
mkdir otp_r7b
4. Change to the installation directory, e.g.
cd otp_r7b
5. Assuming the compressed tar file resides in the directory ,. extract the compressed tar file into the current directory:
gunzip -c / .tar.gz | tar xfp -
6. Read the README file in the installation directory for last minute updates, before proceeding.
7. Run the Install script in the installation directory, with the absolute path of the installation directory as argument,
./Install /usr/local/erlang/otp_r7b
and supply answers to the prompts.
In most cases, there is a default answer in square brackets ([]). If the default is satisfactory, just press . In general you are only prompted for one thing:
- "Do you want to use a minimal system startup instead of the SASL startup?"
In a minimal system, only the Kernel and STDLIB applications are loaded and started. If the SASL startup is used, the SASL application is included as well. Normally, the minimal system is enough.
8. Make Erlang/OTP available for users, either by putting the path /usr/local/erlang/otp_r7b/bin in users $PATH variable, or link the executable /usr/local/erlang/otp_r7b/bin/erl accordingly, e.g.:
ln -s /usr/local/erlang/otp_r7b/bin/erl /usr/local/bin/erl
Enhancements:
- Among other things, SMP support was added.
<<less Download (10.3MB) Added: 2006-05-18 License: GPL (GNU General Public License) Price: 1259 downloads
Mar 05, 2010 | Lands Phones
How to disable Cd drive windows xp in a local user
you can disable the CD drive and USB in the BIOS or go to
regedit:
Hkey_Local_machine\system\CurrentControlSet\dervices\cdrom\start
1=eable, 0=disable
hkey_local_machine\system\CurrentControlSet\devices\usbstor\start
3=enable, 4=disable
Mar 09, 2009 | Microsoft Windows XP Professional
Microsoft Windows XP Professional Logo
101 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
