SOURCE: braun 360 shaver. How to replace the cutter.
yup, it worked. Just pry it up. I used a heavy duty tweezer.
SOURCE: new foil required for braun 370 travel shaver
Hello MrandMrsInger! You can purchase a new replacement foil for your Braun 370 at the link I've provided below. Basically, you'll be getting a new cutter block and foil for it, as the foils are no longer provided separately.
Braun, now owned by Gillette, discovered that many folks would buy just the new screen (foil) and it would get torn/damaged by a nick in the cutter block blades, so they packaged these wear items as a set to eliminate those very common problems. I had it happen to mine several years ago, so I know why they made the change.
Anyway, here's the website with your replacement parts:
http://www.electricshaverstore.com/get_list_125.htm
Just scroll down to the 2nd item shown, I believe, and you'll see your replacement set.
You can also use the part numbers to try to locate another supplier, if you wish, as these are the actual Braun part numbers provided.
Hope you find this Very Helpful and best regards!
SOURCE: Braun 5785 does not charge or auto clean via docking unit ?
HOW TO REFILL BRAUN SELF CLEAN WITH JUST THE RIGHT BREW. THE MISSING INGREDIENT BRAUN DOES NOT WANT YOU TO KNOW
SOURCE: My Braun shaver 8585 has died. Foil, cable, box,
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
SOURCE: Braun Synchro 7526 Electric Shaver How do I open
You will find an instructional video at shaveroutlet.com. See link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
You will also find compatible batteries at the link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
