Question about Bunn CWTF15-TC
No coffee.....but hot water spiggot is OK.
We have a Bunn CWTF15.
Water is supplied via house water line, which is filtered before coming into the Bunn.
Anyway, the hot water spiggot functions.....and we get hot water.
However, we cannot make coffee. When depressing the brew switch.....nothing happens.
Is something clogged?
    New Friend:
  • 18 Answers
Yes there is clogged inside its either the hose or the keypad / connection of the control is corroded.
Posted on Mar 09, 2009
  • Bunn Master
  • 2,237 Answers
There is a gallon and a quart tank inside and will need to be filled before it'll come out. open the top and make sure it is filling the trough and going down. if it isn't, the solenoid is not working or the in-line filter in the back (brass) is clogged.
Posted on Nov 27, 2014
Water not coming out hot
If you have a hot water tap on the brewer, then most likely the thermal fuse is blown. You can get one from www.bunn.com. It's above and almost behind the tank, and most likely brown by now
Mar 22, 2015 | Bunn CWTF15-TC
My bunn cwtf15 won't put out hot water from tap, and won't brew hot enough water even after adjusting thermostat?
your thermal fuse has blown. it's in what is now brown tubing and is located in the top right rear of the machine. remove the top lid, remove the trough drain nut and trough to get to it. you can either bypass it with a jumper, or call (800) 352-BUNN (2866)
Jan 06, 2014 | Bunn CWTF15-TC
I have cwtf15-aps older model. Device is wired and plummbed in. lights are working but i get no hot water. Has not been used for about 3 years.
thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
Dec 12, 2010 | Bunn CWTF15-TC
I have a Bunn CWTF15. Water does not fill the coffee pot full anymore. Is there a float that needs to be adjusted? Would descaling help this problem? Thank you.
If u haven't cleaned it out using 3/4 vinegar to 1/4 water, some times this will happen. after running this thru ur coffee maker, (u won't believe the junk that comes out), then run full pots of water to rinse out (2x's). This should help it perform better.
Sep 12, 2010 | Bunn Automatic Coffee Brewer CWTF15 1
I have the 5 place warmer Bunn auto coffee maker. I changed out the in line water filter and when I tried to make coffee it would only trickle out about a cup of hot water ant then shut off. Help. Am I...
Check the big fitting on the back of the brewer, there is a micro filter in there, that might be blocked, if not then check the solenoid behind the front panel. Easiest way to make sure tank is full is to pour water in through the manual fill and let it flow out the sprayhead.
Mar 15, 2010 | Bunn Automatic Coffee Brewer CWTF15 1
Leak from hot water faucet
Replace the water faucet. Contact the company the unit was sold or installed by. they should have the part in stock.
Dec 14, 2009 | Bunn Automatic Coffee Brewer CWTF15 1
Bunn model CWTF15 brews coffee but coffee not hot enough
Check the setting on the thermostat behind the front panel, it might not be set correctly, turn it all the way high the back 1/4 turn.
Nov 05, 2009 | Bunn Automatic Coffee Brewer CWTF15 1
Can you turn a CWTF15-APS Airpot Coffee Brewer to a pour thru
Yes, most Bunn CW models have the ablilty to be used as a pour over. There should be a lid on top.
www.kaldi.com
Jul 20, 2009 | Coffee Makers & Espresso Machines
If I can't get the water t6o come out when the
Try this, use the manual fill in the top of the machine, remove the sprayhead, put an airpot under machine and pour water into the machine at least 3 liters, until it pours out of brew tube. If that works, then the problem lies in the solenoid or the ling bringing water to the machine.
Jun 18, 2009 | Bunn CWTF15-TC
Bunn CWTF15-TC Logo
342 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
