Question about LG LRFD25850 French Door Refrigerator
Lg DIOS 2 DOOR FRIDGE GUTTTED MY WHOLE HOUSE
LAST YEAR MY WHOLE HOUSE GOT TOTALLY DESTROYED DUE THE BRAND NEW lg FRIDGE THAT WE PURCHASED. tHE 2 DOOR, DIOS MAKE HAD A FAULT, WHEREIN IT GENERATED SO MUCH OF ICE AND GOT ITS WHOLE BODY WOULD HEAT UP, AFTER SEVERAL COMPLAINTS TO lg WE ARE TOLD THAT THEY HAVE TO CHANGE THE LITERAGE FROM 700 LTRS TO LESS AS WE WERE NOT FULLY UTILISING THE SAME.
SOME CHANGES MADE AND THE NEXT THING WAS A MAJOR FIRE IN MY HOUSE WHICH DESTROYED THE WHOLE PLACE DOWN,
ON INFORMTING THE LG THEY ARE SO THICK SKINNED THAT THEY HAVE NO GUTS OR FACE TO SHOW THE PUBLIC. THIS COMPANY SHOULD BE FULLY BANNED WORLD WIDE THEN ONLY WILL THEY KNOW WHAT OUR CONSUMERS PAIN IS.
5 Suggested Answers
  • 210 Answers
SOURCE: LG LRFC22750 Bottom freezer french door refrigerator
6343ed3.jpg The problem is ice build up on the back wall. The noise you hear is the fan blades hitting the ice. On the back wall water gets trapped, it then builds up over time, and a big ball of ice forms and blocks the fan. Take off the back wall, defrost the build up and cut the insulation off as above. The water will no longer get trapped and the problem will not come back.
Sgt 48
Posted on May 31, 2008
huuum
  • 750 Answers
SOURCE: Regrigerator shows error code 1F
Hello tr-6
Welcome
You Wrote,
LFX25960ST LG FRENCH DOOR REFRIGERATOR DATE OF PURCHASE 7-7-07 DELIVERED 7-13-07 ICE MAKER REPLACED ABOUT THIS TIME LAST YEAR AFTER TWO MONTH WAIT. NOT PLEASED WITH PERFORMANCE OR SERVICE TO DATE. REQUEST THIS PROBLEM BE COVERED BY WARRANTY.
Below is the service manual And the explanation for your error.
Thank You for using our site.
Huuum
Please remember to leave a solved rating.
Error Detection Category
ERROR CODE : IF
Abnormality of
BLDC FAN Motor
for Ice Making
Error Generation Factors
It is caused when F/B
signal isn’t over 115
seconds during BLDC
FAN motor operating
Remark
Poor BLDC Motor
connection, DRIVE IC, and
TR
Resource reference located here:
http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
Huuum
Posted on Oct 12, 2008
SOURCE: lg refrigerator LFX25960SW
the answer to the problem from a LG training class is... if the bottom left side of the refer is freezing food the liner has split no fix at this time. some people have beEn able to turn off the ice maker and the food will stop freezing. the ice maker has a fan in the freezer that blows all the cold air up the ice making Cobby.
DO THIS ONLY IF OUTA WARNTEE
for most of you with bad ice makers you could drill a hole in the very bottom of the ice maker towards the front right under the little metal arm in the wight plastic AND DONT DRILL DEEP just enough to put a hole in the outer case then hit it with a blow-dryer for a little bit to remove ice that's blocking the gear on that arm this works 5 outs 10 times
Posted on Oct 29, 2008
SOURCE: Original lamps producing excessive heat.
I also have had the lense warp and fall out some time ago. I have an extended warranty and got a new lense. I mentioned this particular problem to a tech recently and he told me that LG has come out with a new lighting unit that no longer uses a timer to shut off the light, but a temperature sensor. I also replaced the lamps with 40 watt appliance lamps (same physical size) as those that came with the refrigerator which are 60 watt according to the tech. My lighting unit has NOT been replaced with the newer temperature controlled rather than timer controlled switch. I don't know when or why my interior lights stayed on long enough to melt the plastic. Since I still have the extended warranty, I may push for having the lighting unit replaced.
Posted on Jul 27, 2009
  • 7 Answers
SOURCE: LG french door with non working ice maker
Similar problem. Occasionally my ice maker goes on the fritz. Usually I can turn off the ice maker and place a piece of newspaper over the freezer holes for overnight and it starts making ice when I turn it back on. This time that didn't work so I unplugged it this morning for 3 hours and put all the stuff in coolers. I opened all the doors and removed the freezer bin (just the bin maa'm, not the frame) so I was sure the water lines inside the fridge doors and sides would unfreeze. Plus side is the Fridge got a good cleaning. I just heard my first ice drop about a 1/2 hour ago.
Posted on Sep 08, 2009
Recently got 2nd hand Amana side by side model XRSS687BB. Compressor stops when closing fridge door. Freezer working as long as fridge door remains open. Fridge damper closed and won't open though it
I have went through something like this before, the serviceman told me it was in fact a compressor issue. Do you hear some kind of buzzing noise? Is it extremely hot? Then it's a compressor issue. They are pretty expensive to have replaced, would recommend to purchase a different brand. I had the same problems as Frigidaire. I had the compressor replaced twice during a time period of 2 years. It went out a third time and it was out of warranty and they told me that the compressor didn't receive any kind of warranty gain for itself and the company shortened the warranty of the compressor because of the issues they had with them. Since they were aftermarket ones, didn't apply to the original warranty. If you continue to have issues with this brand, please research the brand integrity online before you make another bad investment. I paid more for the new brand but it lasted longer than 9 months. The next fridge that I bought was older and used but lasted 5 years, so I stuck to that brand and it paid dividends stop far.
Dec 18, 2014 | Amana Refrigerators
LG LMX28988ST freezer at 30 degrees
What it the reason that my fridge is freezing my food. The temp. IS set to 37 F. Why
Mar 14, 2012 | LG LMX28988 (27.5 cu. ft.) Bottom Freezer...
We have a 25.4 cubic Whirlpool side-by-side fridge/freezer stainless steel look. Since the last 2 weeks....the display lights showing temperatures in fridge and freezer the front water/ice dispenser unit...
the clicking is from the lamp relay which makes the lights flicker and its located on the units rear area in the back,without a model number i cant tell what this boards model number is but you need to replace this whole board as they are non repairable(this is usually caused by a power surge or outage,which can destroy these boards,also even if a lamp in the unit burns out this can destroy this board too)
Mar 23, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Our LG microwave (LMA 1560SW?LMA1560SB) has a door that won't open. The open button will push in, but not release the door - the plastic button cover pops back out, but just the cover - not the whole...
Mine did this too. Also, at times when I would shut the door, the whole keypad would go dark and the clock would have to be reset. There were also times when I would push Start and it would do nothing. I'd have to unplug it so it would reset itself.
I used a screwdriver and forced the door open. Mine is about 2 years old and it's now dead. Biggest piece of junk I've purchased in years. Really ticked me off, no more LG products for me. I had a Toshiba that lasted me 22 years and the only thing that went bad on it was the light stopped working and the fan cover fell off.
Mar 20, 2011 | LG LRM1230W Microwave Oven
My lg refrigerator just gave out. Its plugged in but its not working. I have checked the circuit brakers and everything is fine. Is this fixable or do i need a new fridge? I have owned this one 2 years
I had this problem a while ago. It may not be the circuit breakers but the outlet where fridge is plugged may have gone bad. Plug fridge into another outlet and see what happens. A 2-year old fridge is almost brand new.
Jan 23, 2011 | LG LSC27910 (265 cu ft) Side by Side...
We have a 4 year old LG fridge obviously out of warrenty. Repair man was just here. Why does LG wire lights into main board? Why does LG install TWO 60 watt bulbs (120 watts!!) when the notice in the...
LG issued a service flash about this very problem, so you may be in luck. The last one I did for a customer was paid for by LG.. In a nutshell, LG screwed up. The control board that the lights tie into has a bad relay, which causes the lights to stay on all the time. The fix is to get a new control board and a new light harness. The new harness has a thermal switch that shuts off the lights should they not shut off in the future. I'd try LG customer service and see if they can help you out.
Good Luck!
Sep 29, 2010 | LG Refrigerators
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
Inside lights do not go off when doors are closed
Good day,
All refrigerators have light switches, that depress and shut off the lights when the doors are closed.
First, make sure the bulbs are left out. I would replace all of the light switches because of the newness of the machine.
They are easy enough to replace, and you can purchase them at any appliance parts house or a Sears service facility.
They pry out, and may be destroyed on removal. Unplug the machine.
After connecting the wires, the new ones just push in.
To test, close the doors slowly. The lights should go out just before the door closes.
Some states have what is called "Implied warranty of serviceablity". Which means what should a consumer reasonably expect irregardless of the warranty limits.
You might want to contact Sears and express your opinions regarding this matter, and if they'll consider making you whole.
The above paragraph are my thoughts only. They in no way reflect the law, Sears policy or liability or this site's policy.
Dec 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
When I press BAKE to preheat the oven or CLOCK to set the time the display goes blank, then the number 30 appears, and then the clock time resets itself. I can still use the oven to preheat or bake, but...
I have the same problem. I bought it new in the fall of 2007. They replaced the control panel but that didn't help. Next they replaced the whole range with a new one, same model, still the same problem. They told me it was a problem with my electric in my house. Then they said it was a strange electro-magnetic field in my neighborhood and I would have to buy a different brand?
One time with the original stove the oven quit working and I had to re-set the breaker. Everything still works but the clock is always wrong.
We bought all Maytag stuff, including fridge, stove, microwave, dishwasher, washing machine, and dryer. The kitchen stuff is 4 years old. The washer and dryer are 3 years old. We have had this issue with the stove, the washing machine broke and they had to replace the whole drum assembly, and last week my refrigerator broke. Very disappointed with Maytag stuff.
So has anyone found a solution?
May 17, 2009 | Maytag MES5752BAW / MES5752BAB Electric...
Lights would not go out,overheated and burned out
Yes it is a stuck relay. LG has also come out with a new thermal disk in the light housing as well. This will stop it from melting, but at times you may not have a light on when you open the door. Get the new board and it will solve the problem.
Sgt48
Nov 12, 2007 | LG LRFD22850 Bottom Freezer Refrigerator...
LG LRFD25850 French Door Refrigerator Logo
210 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
