Question about Samsung ML 1610 Laser Printer
The paper has jammed in my ML-1610 printer. - Samsung ML 1610 Laser Printer
  • bhardwajk May 11, 2010
    plz send an engineer to solve my paper pick up problems
  • 45 Answers
The paper jams mostly, because the rubber band that feeds the paper to the printer is broken/split. Check the rubber band. It's located within the plastic wheel that feeds the paper.
Posted on Apr 29, 2009
  • yawak Jan 21, 2012
    The culprit is indeed the rubber band. It was totally dried out. Put some vaseline on that rubber band for some extra stickyness.
Have a samsung ML-1610 and used to work fine. Now every time I print something the paper keeps getting jammed.
Get a package of roller cleaner papers at an office supply store or online. Run it thru the printer as directed to remove the fine paper dust that has accumulated on the rollers and the paper path.
Jan 03, 2015 | Samsung ML 1610 Laser Printer
Paper didnot pull or paper jam
I had success on a canon printer by taking a can of air and blowing out the paper receiving area. It started picking up paper and no longer saying there was a jam. I think I must have had dust or a piece of paper blocking sensor.
Dec 21, 2011 | Samsung ML 1610 Laser Printer
My samsung ml-1610 printer always getting paper jam on print job. Is this problem related to fuser or something else? please help me...
There are a series of rollers which are made of rubber in the unit. When these rollers become dry or covered with dust (usually from cheap paper) they arent able to pick up paper correctly any longer.
Think of it as though you are trying to turn a page, and you have to lick your finger to do so.
Its the same concept. When your printer grabs the paper, it cannot hold it while it is rolling it through the printer.
There are kits available through your manufacturer or a local print shop which can clean your printer and help to restore it to its working order.
Hope this helps!
Feb 23, 2011 | Samsung ML 1610 Laser Printer
Why the printer is taking more papers at a time and gets jammed. I am using 75 GSM paper
This is caused usually by dirty or faulty/worn out rubber paper pick roller. Try gently cleaning it with damp soft lint-free cloth. Moreover, it is better to use 80GMS paper.
Hope this helps!
CreativeTECH
Dec 09, 2010 | Samsung ML 1610 Laser Printer
The online error light is red on my ML-1610 Mono Laser Printer any ideas how to fix this?
It probably has a jam somewhere. Open each flap, remove the toner cartridge and check the paper path is clear.
Jul 16, 2010 | Samsung ML 1610 Laser Printer
Samsung ml-1610
There's probably a small bit of paper jammed in the paper-out sensor (hopefully. Otherwise the sensor may have been snapped off).
Extract the paper tray and look inside with a strong light. The paper out sensor should be a dark gray or black piece of plastic dangling from the upper left side. Remove any paper bits you find with a pair of tweezers, then blow on the mechanisms with a compressed air canister for good measure.
Oct 27, 2009 | Samsung ML 1610 Laser Printer
Jammed paper Samsum ML1610
Take down the front cover, pull the toner cartridge out and pull the paper to remove it. Check the plastic wheel that feeds the paper (use a flashlight). It has a rubber band that might be broken. Replace it if necessary.
Apr 10, 2009 | Samsung ML 1610 Laser Printer
Printer indicates paper jam. Cannot find any evidence of papejam.
if you as service man you can unerstand my solution
follow up
1.your printer lamp thermostate or thermostater is cuttoff or printer cartridge is not properly instald. it is a technical problem
Feb 05, 2009 | Samsung ML 1610 Laser Printer
Fake paper jam
the roler, which picks the paper need to clean, try it
Oct 28, 2008 | Samsung ML 1610 Laser Printer
Samsung ML-1610 Does not print after a paper jam
after checking no paper left on rollers etc, turn printer of for a while and then turn back on and press the paper release button
Oct 17, 2008 | Samsung ML 1610 Laser Printer
Samsung ML 1610 Laser Printer Logo
806 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
