Question about Kenmore 20722
Agitator won't work - Kenmore 20722
  • 163 Answers
You need to replace agitator dogs,they are located in agitator.pop top off and one bolt holds it to tub,remove bolt and remove agitator.pop top part off agitator and you will see little plastic agitator dogs.should be 4 of them.that is what grabs agitator to circulate your clothes.very cheap part to replace.
Posted on Mar 09, 2009
Kenmore washer model #111092581200 won't stop filling and won't agitate
Please recheck that model number. It is coming up as a microwave.
Oct 31, 2012 | Washing Machines
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
Sep 30, 2012 | Roper Washing Machines
Frigidaire Fex831cs Top Load Stacked Washer won't agitate
I worked on one last week which was completely dead. Some wires were cut. Took a few pics: Laundry Center repair
Service manual
Jun 21, 2012 | Washing Machines
Washing machine won't fill. i filled it by hand with water, it won't agitate either, only spins.
The inlet solenoid is probably bad. And it won't agitate unless it fills and stops filling automatically.
May 17, 2012 | Whirlpool Washing Machines
What should i look for on my whirlpool washer if it hums but won't spin, agitate, or drain?
The motor may be shot if it is getting current and won't operate the washer.
Nov 04, 2011 | Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Agitator won,t work tub will fill, and empty but won't spin and agitator won't work
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Dec 01, 2010 | KitchenAid Washing Machines
Washing Machines Logo
119 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
