Question about Brother MFC 210C All-In-One InkJet Printer
Sending a fax
Having trouble sending fax says busy no response
  • Mary Downes Mar 25, 2009
    Same problem here, and it started a couple of weeks ago so around the same time as the other person. Oddly, during the day we can fax these numbers but at night, no go. The fax on the other end sounds like it picks up and a handshake is initiated, but then it goes silent and a faint "click-click" is heard. The fax send fails and after a couple of tries we get the "busy or no response" error sheet printed.
    We've changed the phone line from the fax to the wall. If I dial the fax number on our phone I get the same thing: fax squeal starts, gets cut off, then silence.
    Is this a phone line/company problem or to do with the Brother unit?
  • 463 Answers
Pick up a plain old telephone. Dial the number to which you are trying to fax. Do you get a busy signal? Does the (other) fax machine answer?
Plug that phone into the phone jack to which you have the fax machine plugged into... do you have dial tone?
Is the fax number valid?
do you have to dial a one or some other sequence of numbers to "get where you're going"?
Reseat connectors going from Fax machine to wall jack...
Posted on Mar 09, 2009
I have a Brother mfc 290c. My problem is it won't send faxes, it keeps saying "no response, busy" I have a duet line. I have tried every combination in the book but still can't seem to find the solutions...
If you get the "busy/no response" message it is because the fax machine does not get a response when it tries to dial out.
Make sure you have a dial tone by pressing the "hook" button. If you do not have a dial tone, make sure the phone line is connected to LINE on the machine.
If you have a dial tone, try dialing the fax number. If you hear a recording, there is a problem with the line.
One of these two possibilities is causing the problem.
Thanks,
Pat
May 12, 2010 | Brother Office Equipment & Supplies
Problem: Busy/No Response on all outgoing faxes
Put the document you want to send into the transmit tray, pick up the handset, listen for a dial tone, and then dial the # on the keypad..
It should ring just like any other phone. When the machine on the other end picks up and you hear the tones, press the start button.
Anything other than fax tones on the other end, it is not your faxes fault.
Nov 05, 2009 | Brother IntelliFAX 2800 Laser Fax
Cant receive fax
FIRST OFF. IF YOU PLUG A PHONE INTO THE JACK DO YOU GET DIAL TONE? IS THE WALL JACK PLUGGED IN TO THE RIGHT JACK ON THE MACHINE? NEXT GO IN TO THE MENUE SET UP FOR FAX. GO TO THE SECTION WHERE YOU WILL SEE EASY RECEIVE AND EASY SEND, ON BOTH OF THEASE PRESS SET OR OK THIS SHOULD NORMALLY DO THE TRICK, IF ALL FAILS, THEN YOU MAY NEED A PHONE BOARD CALLED A NCU BOARD. GOOD LUCK BROTHER SR TECH
Jan 27, 2009 | Brother IntelliFAX 2800 Laser Fax
Can't send out fax
the number you called does not answer or busy-you may have reached a number not connected to fax or it is connected and not activated in receiving mode-check the number and call again.
if you have a message "out of memory"there is no enough memory available to send your fax.press stop/exit print the faxes stored in the memory to delete them then try again.
Mar 18, 2008 | Brother IntelliFAX 885MC Plain Paper...
Can't send out fax
Make sure the phone cord is connected to fax machine in the place marked LINE, then make sure the phone cord is connected to the wall jack. Pick up your handset and make sure you have a clear dial tone also. If you are dialing long distance make sure you have the long distance service.
Nov 09, 2007 | Brother IntelliFAX 1840C Plain Paper...
We can't send or received faxes
Just a suggestion. This effect can happen if you have plugged the line cord into the tel jack instead of line jack.
Oct 30, 2007 | Brother IntelliFAX 2800 Laser Fax
I can't fax! BUSY/NO RESPONSE
go into menu
go to fax settings
find send
click auto not manual, please make sure that when you push the hook key you hear a dial tone. always reminder that every fax machine has the capablitiy of either dial or tone. now if everything is set up properly  the problem will be in the tx portion of the board. if you can link up with somebody close to you and try to transmit back and fourth that will let you know if it is their problem or your. it may not be your problem.
Oct 21, 2007 | Brother IntelliFAX 1840C Plain Paper...
Brother MFC 210C All-In-One InkJet Printer Logo
338 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
